Old 05-11-2004, 01:52 PM   #1
FSelekler
Member#: 41410
Atlas Gray
Default ECU Modifications in Street Prepared?
I have been looking through the rules for Street Prepared class and could not find something that would give me a clearer idea on ECU reprogramming.
Unless I somehow missed it, I should then asssume that it is not allowed I guess. However, in STS/X rules, it clearly says that it is allowed within certain limitations, so.... some hope may be ?
Thank you for any clarification in advance.
FSelekler is offline   Reply With Quote
Old 05-11-2004, 02:08 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
You can change timing and fuel but you can't touch boost control.
Old 05-11-2004, 02:18 PM   #3
ElGranBanò
Member#: 38910
The Cobb AcessPORT comes with an STX map just for this!
ElGranBanò is offline   Reply With Quote
Old 05-11-2004, 02:26 PM   #4
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
that may or may not be legal
TyrannoSullyRex is offline   Reply With Quote
Old 05-11-2004, 02:32 PM   #5
FSelekler
Member#: 41410
Atlas Gray
That is my fear We have AccessPort on the way, but I am not sure we will be able to use it. And we cannot use a Turboback without porting the wastegate and that is not allowed either.
So, we may be stuck with cat-back
Old 05-11-2004, 02:33 PM   #6
Watkinsm3
Member#: 51740
2004 STi A-Stock #24
Same as my Coffee : Black
You can make pretty extensive ECU changes in Street Prepared. Some of the factory parts must be retained for legality (I can't remember as its been over a year since I read those rules). I ran a Tec3 Electromotive ECU in my DSP integra but had to retain the stock VTEC engagement ( which would be similar to retaining your stock boost levels in a WRX ).
D.
Alternate computer control modules may be used whenever an equivalent change to the conventional system is allowed. For example, alternate computer module control of ignition settings or fuel injection is allowed. Direct turbocharger boost control by alternate computer control is not, since there is no equivalent mechanical allowance.
Watkinsm3 is offline   Reply With Quote
Old 05-11-2004, 02:53 PM   #7
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
You might be able to install a fuel-cut defender in SP where it is not legal in say STX. I know guys that ran DSMs in ESP a few years ago would run catless exhausts and find ways to make the boost spike via means other than boost control. Spike = more power
Old 05-11-2004, 02:55 PM   #8
FSelekler
Member#: 41410
Atlas Gray
Should I take it that "boost control" is different than running a "higher boost pressure", or am I stretching things a little here ?
Thank you for the enlightment all.
Old 05-11-2004, 03:10 PM   #9
MNbiker
Member#: 18148
'08 WRX
Dark Gray
You can't touch stock boost maps, wastegate settings, bleed valves or anything that directly controls boost. Any legal changes (exhaust, intake, intercooler) that happen to increase boost are legal.
The bottom line is you can make some changes that will result in legal boost spikes. However, you'd better have a REAL good explanation for anything that causes your car to consistently generate higher than stock boost levels.
-Steve
MNbiker is offline   Reply With Quote
Old 05-11-2004, 03:13 PM   #10
FSelekler
Member#: 41410
Atlas Gray
I understand thank you very much.
Old 05-11-2004, 03:53 PM   #11
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
You can run a turbo back without porting the wastegate for autox, you are not going to hit boost cut untill you get out of 3rd gear. It just means no highway runs on the way home.
Oh and FCD's have been illegal for awhile.
afpdl is offline   Reply With Quote
Old 05-11-2004, 04:31 PM   #12
FSelekler
Member#: 41410
Atlas Gray
Yes of course
The issue is that we do quite a bit of track testing as well, and I don't want to be installin/uninstalling a TBE from event to event
Thank you for the reply however.
Old 05-11-2004, 05:14 PM   #13
sotti
Member#: 33474
04 M3
Imola Red
What't the issue with the TBE?
Is it that you get too much boost creep, or is it that you worry about the boost taking you over stock levels.
If it's caused by the bellmouth downpipe you could always use a HKS downpipe that has the stock style wastegate flange.
sotti is offline   Reply With Quote
Old 05-11-2004, 05:23 PM   #14
FSelekler
Member#: 41410
Atlas Gray
Boost Creep is the worry.
And we need to use the Cobb one when it comes out.
Old 05-11-2004, 05:27 PM   #15
Prestige Motorsports
Member#: 13158
2002 Impreza WRX
Sedona Red
None of the TurboXS turboback exhausts have boost creep issues to my knowledge due to the tapering down at the end of the intermediate pipe.
Prestige Motorsports is offline   Reply With Quote
Old 05-11-2004, 06:53 PM   #16
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
If you keep the stock muffler on except for events it may be enough to keep the creep down. With an HKS downpipe and stock cat back I dont have creep issues unless its cold and Im at the top half of 5th gear.
Getting the cobb downpipe with a cat may also be enough to keep boost cut from occuring.
Old 05-11-2004, 11:46 PM   #17
FSelekler
Member#: 41410
Atlas Gray
I certainly do hope so We'll see when it comes out. Also, without proper ECU modifications, would a TBE still help in power delivery? We are not necessarily looking at a peek hp/trq increase, but a broader delivery across the RPM range; and oh-boy, would it be nice if we could somehow get 4-500 more RPM with AccessPort, We have been riding the rev-limiter for some time now
Old 05-11-2004, 11:48 PM   #18
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
You get more top end and low end with the downpipe. When I went to an hks downpipe I stopped feeling that drastic drop in power over 6k rpms that I felt when it was stock. The power still tapers but not nearly as much.
Old 05-12-2004, 12:23 AM   #19
FSelekler
Member#: 41410
Atlas Gray
:thumbup:
Old 05-12-2004, 10:05 AM   #20
wrrrx
Member#: 23993
2004 STi, Surgeline
WR Blue
This kind of silliness is exactly why I bypassed STU and went straight from AS to SM!!
Can't play w/ boost on a turbo car? Phooey! What fun is that?
Russ R
wrrrx is offline   Reply With Quote
Old 05-12-2004, 12:12 PM   #21
FSelekler
Member#: 41410
Atlas Gray
Russ R
I certainly can relate to it, but we have to stay in Street Prepared, and no doubt it is slightly more cost-effective.
Old 05-13-2004, 10:35 AM   #22
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Yep! esides, who says a STX/SP car can't be fun to drive around town?
DrBiggly is offline   Reply With Quote
Old 05-13-2004, 10:51 AM   #23
zoomfactor
Member#: 30440
03 WRX
WR Blue
Yeah, but it would also be cool to drive "12-sec" sleeper around town too.
zoomfactor is offline   Reply With Quote
Old 05-13-2004, 11:20 AM   #24
rsotak
Member#: 42432
Have you looked into twin dump style downpipes? I'm running a BPM unit and have not seem the boost creep issues your talking about. I'm runningnthe stock ECU with stock boost controll for STX and have had good luck with the power deliver. If only I could get the car pointed in the right direction faster
rsotak is offline   Reply With Quote
Old 05-13-2004, 11:24 AM   #25
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Miranda (Midnight_Gold) is running the stromung divorced wastegate 3" (sweet looking setup btw) with a 3" midpipe and high flow cat into a 2.5" straight pipe w/o a muffler and is not getting any boostcreep.
-Tom
trhoppe is offline   Reply With Quote
Is the WRX (non STi) in E Street Prepared? RS_Racer Motorsports 49 07-20-2006 12:31 PM
ALK in Street Prepared limeylight Motorsports 23 06-23-2004 01:03 PM
a unichip for street prepared or the new STX? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-22-2002 05:54 PM
SOLOII - Street Touring or Street Prepare? iBlueVirus Motorsports 11 01-04-2002 11:42 AM
why no street prepared for WRX? stratos Motorsports 24 09-27-2001 07:29 PM
