Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 08-26-2000, 06:44 PM   #1
JP Money
Member#: 909
Post Installed S-AFC, Check Engine light came on... HELP!
The wiring is correct. I followed the instructions off of Kartboy's site.
We took it out for a test-run with lo-throttle correction settings at 0%, and Hi-throttle settings at -1% for 3K, -2% for 4k, -3% for 5k, and -4% for 6K. After a few WOT runs, the Check engine light came on.
What does this mean? I didnt have it correcting too much... How can i get the light to go away?
What are some good settings for MY00? I have an intake, exhaust, and U-pulley.
Help!
-JP
JP Money is offline
Old 08-26-2000, 07:29 PM   #2
prezios
Member#: 407
1999 Outback Sport
Post
Someone else can answer better than me but the same thing happened to me. It was the setting for the pressure sensor. It needed to be set to 4. You will need to reset the ecu to get rid of the check engine light. Then try again. I don't know of anyone that has tuned the my2000 yet. I will after getting my A/F Gauge intalled along with a third O2 sensor. I hope this helps.
prezios is offline
Old 08-26-2000, 10:20 PM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Don't waste your time with adding another O2 sensor or by trying to interpret the AFC's O2 voltages. Just get an EGT gauge, RalliSpec & I installed mine today, & it's much easier to tune with, IMO, since it's not bouncing all over the place like an A/F gauge.
RidinLow is offline
Old 08-27-2000, 06:43 AM   #4
prezios
Member#: 407
1999 Outback Sport
Post
Does the A/F gauge bounce around that much that its hard to tune by? I thought if I had a seperate O2 sensor for the A/F that it would be a somewhat steady reading.
prezios is offline
Old 08-27-2000, 10:29 AM   #5
Avenger
Member#: 1234
Post
EGT?? is that Exhaust Gas Temperature?? How you tune this?
Avenger is offline
Old 08-27-2000, 02:43 PM   #6
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I'm still trying to figure this out myself, but I'm shooting for EGT's of around 1400 deg F. Too low means too rich, too high means too lean. If you've ever seen an A/F gauge in action, you'll know what I mean by it bounces around a lot. And like Shiv said in SCC, with just an A/F gauge, you have no idea how lean or rich you are if you're way out of the ballpark.
~G
RidinLow is offline
Old 08-27-2000, 05:18 PM   #7
NYEJ25
Member#: 1876
Question
I am getting a AFC for my 2000 RS. I have a intake and cat back system. Is this a worth while buy? Also does anyone have settings for the unit. I dont know how to set it up. Thanks alot
drew
NYEJ25 is offline
Old 08-27-2000, 10:27 PM   #8
tk__427
Member#: 2164
Post
where is the ecu located?
tk__427 is offline
Old 08-28-2000, 09:16 AM   #9
JP Money
Member#: 909
Post
jake- you gotta ask me all your Q's at the next redline meet.... Hey are you 19 yet? I think Tim wanted to go to Canada after we meet on Friday...
The ECU is located behind the carpet and a metal plate beneath the passenger's side footwell. Just remove the plastic clips from the door sill and also in the carpet, then pull it back and Voila! there it is!
The S-AFC wasnt very hard to install at all. Theres a great wiring diagram at www.Kartboy.com, as well as plenty of wiring and settings info at www.lagging.com I have yet to install my A/F gauge (i'm waiting on the A-pillar pod) But when I do, I'll post my best settings so that other MY00 owners may benefit.
See ya!
-JP
JP Money is offline
Old 09-03-2000, 12:58 PM   #10
nizz
Member#: 188
2004 Forester XT
24k gold on white
Question
Do all of us MY2000 people have to use In=7 and Out=7 for the pressure sensor settings? I got a CE light after I installed my AFC right when I started my car. Please advise. TIA.
nizz
nizz is offline
Old 09-04-2000, 06:17 AM   #11
prezios
Member#: 407
1999 Outback Sport
Post
Hey Nizz, I have a 99 OBS but I think the same settings should apply. I am useing in=4 and out=4. I hope this helps.
Carmine
prezios is offline
Old 09-04-2000, 07:59 AM   #12
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I'm using i=7 & o=7 for my MY00 RS too, per RalliSpec's recommendations.
RidinLow is offline
Old 09-04-2000, 09:32 AM   #13
prezios
Member#: 407
1999 Outback Sport
Post
It must be different in the RS than the OBS because RalliSpec installed mine and when set at 7 in and 7 out it thew the check engine light on me. We reset the light (code for MAP sensor) and reset the S-AFC for in 4 and out 4 and no problems ever since.
prezios is offline
Old 09-06-2000, 10:39 AM   #14
nizz
Member#: 188
2004 Forester XT
24k gold on white
Question
prezios,
How did you reset the CE light?
nizz
nizz is offline
Old 09-06-2000, 10:52 AM   #15
rpone605
Member#: 1669
2004 WRX Sport Wagon
Post
ecu resets are easy.
pull the cable off the battery let sit for 35 minutes. start the car..it should stall as soon as you start it. then let it sit for 10 minutes or until the fan kicks in.
hope this helps...and once you start modding expect ce lights to be normal.
rpone605 is offline
check engine light came on help trinistyles Normally Aspirated Powertrain 2 03-30-2005 01:15 PM
('93-'01) Check Engine Light came on 96Imprezer Impreza Forum 1 04-16-2001 11:25 AM
check engine light came on. go go go Normally Aspirated Powertrain 4 01-26-2001 03:28 AM
