Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 05-12-2004, 03:30 AM   #1
Member#: 24690
Default STi axle back on a RS?
Hi there,
What modification needs to be done to fit a STi axle back muffler on to a 02-03 RS?
Or is it just a direct bolt on?
AAU is offline   Reply With Quote
Old 05-12-2004, 05:03 PM   #2
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
You have to modify the hangar closest to the front of the car (near the swaybar) and rotate the flange of the axle-back. Its easier to get the whole cat-back section and use that... though that may not bolt up perfectly to the cat section. Any exhaust shop should be able to do it for you.
phattyduck is offline   Reply With Quote
Old 05-12-2004, 06:18 PM   #3
Member#: 45994
2002 WRX Wagon
I am thowing one of thse on my 01 RS very soon, everything look like it will line up, but I am going to goto a shop and have them make some 2.5" mandrel bends from the cat to the axle back. Should be less then $100.
WeSTI is offline   Reply With Quote
Old 05-12-2004, 06:55 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
If you did a search for this in the proper forum: The Normally Aspirated Forum, you would have found the answer quite easily...
PRODRIVE AXLE BACK on my RS shinjyo Member's Car Gallery 23 04-09-2008 02:56 AM
Finally PRODRIVE AXLE BACK on my RS shinjyo Normally Aspirated Powertrain 2 04-07-2008 04:40 PM
sti axle back on gc8 maumau Subaru Conversions 3 12-12-2007 03:09 PM
04 USDM Sti axle back on 02 LGT ttatsumi Legacy Forum 10 04-27-2006 11:51 AM
STi axle back on 2.5RS questions or muffler suggestions bisonjr Normally Aspirated Powertrain 23 01-30-2006 12:18 PM
