Old 05-12-2004, 11:59 AM   #1
anti.team
Member#: 55812
2002 WRX - Silver
Warren:Throw your dubs up
Default Autocross tire fittment question
Well, I am running SM in my WRX wagon and I need to roll my fenders to fit some 225 Victoracers. What class would that put me in? A prepared class I am sure...
This question was posed in the AutoX rules thread. I didn't want to make that any longer, so I thought I would ask my related question here:
I am planning on getting 225 Victoracers on stock WRX wheels for my MY02 sedan. Am I going to run into clearance issues? Did this guy need to roll his fenders because he has a wagon, or is he just misinformed?
Thanks
-Doug
anti.team is offline   Reply With Quote
Old 05-12-2004, 12:03 PM   #2
jmott
Member#: 6713
2007 Prius
brown
Default Re: Autocross tire fittment question
Thanks
-Doug
wagons don't have flared fenders
I ran 225s on a stock wrx without clearance issues.
jmott is offline   Reply With Quote
Old 05-12-2004, 12:49 PM   #3
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
You won't have clearance problems running 225 on a WRX sedan, and on 16" wheels, I don't think you'd have trouble on a wagon either.
The issue you will have with 225's on the stock wheels is that a 6.5" rim really isn't very good at holding onto all the tread of a 225 series tire. You'd be better off, in my opinion, running a 205 if you want to stick with the stock wheels.
heffergm is offline   Reply With Quote
Old 05-12-2004, 07:57 PM   #4
dadswrx
Member#: 37135
1999 Crown Vic
I run 225s on my stock wheels with stock suspension with no problems.
Mike
02 WRX Wagon
dadswrx is offline   Reply With Quote
Old 05-13-2004, 01:06 PM   #5
lo-buck
Member#: 28913
1990 H2 civic
white
235 on sedan. no rubbing.
lo-buck is offline   Reply With Quote
Old 05-13-2004, 01:18 PM   #6
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
It will depend on the tire's true tread width, the offset of your wheel and tire pressures - but on lowered springs, 225's Kuhmo MX on OEM wheels presented no problems on my old WRX wagon. Except for one time when it was way overloaded for a road trip and then all that was needed was about 5 more psi of air in the rear tires to correct it. The rear tires were deep in their wells but no problems on OEM offsets.
turboICE is offline   Reply With Quote
Old 05-15-2004, 02:14 AM   #7
Call_me_Tom
Member#: 60972
I'm running 225/50-16's on stock rims on my wagon. I have no rubbing issues at all. BTW it's also on a stock suspension. I plan to AutoX as well with these.
Call_me_Tom is offline   Reply With Quote
Old 05-15-2004, 08:19 PM   #8
Scoobie Doogie
Member#: 9805
2009 Bimmah 135 eye
Silvuh
Do not run 205's. You NEED a lot of tire on the front of the WRX. I have toyed with the idea of running a staggered setup with 225's up front and 205's in the rear. OR 215's up front with 205's in back. I know the tire height is different (we though of doing that on purpose) in order to force the center diff to send more torque to the rear. I figured with AX courses being short I wouldn't burn up the center diff too quickly.
If you want a proven setup go with 225's or 215's. The absolute best tire on a WRX is the Hoosier 215/40/16. It REALLY helps with the gearing. But they are expensive. If you are just running regionally or don't have the budget you can run with 225's.
Dave
Scoobie Doogie is offline   Reply With Quote
Autocross tire fit question odoprelude Motorsports 20 03-01-2007 03:30 PM
suspension fittment question.... gavinjay Brakes, Steering & Suspension 6 09-20-2005 01:23 PM
Custom FMIC fittment questions ebeck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-04-2005 10:29 AM
HKS downpipe fittment question Ft_Laud_wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-24-2003 07:45 PM
Autocross tire pressure question (newbie alert!!!) Davenow Motorsports 5 10-01-2002 08:43 PM
