![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 13704
Vehicle:2006 EVO MR Apex Silver |
I know that Rear camber is not adjustable.
Has anyone used camber bolt for alignment for REAR in 04STI? I am thinking I might need to add a little more negative camber to STI due to large wheels. fyi- I will be running 18X8.5 +48 offset rims with 235's this week. I plan to get an alignment if there are rear rubbing issue... Tell me: 1. Where you bought the kit? 2. URL for website? 3. Who performed install? My current setup has -1.2 degree of camber in rear.. Thanks!
#2 |
Member#: 43010
Vehicle:1974 2002tii silver |
camber bolts suck. IMO I would either leave it stock -1.2 is perfectly fine in the back, (I run -1.5 in the back for auto-x and it feels perfect) or some other form or camber adjustment (plates, lateral links).
The reason camber bolts suck is because they can come loose easily causing them to be ineffective and require frequent realianments. |
#3 |
Member#: 37599
Vehicle:Comm ando Brigade.. Bring it isshes! |
Man, I need some camber plates bad......
- Miranda |
| Thread Tools | |
| Display Modes | |
| Installed d-specs on 04 sti...now questions | kenlee | Brakes, Steering & Suspension | 7 | 12-22-2008 12:41 AM |
| Camber bolts needed? JDM STi Stuts and RCE Yellow on 07 WRX | lackofhp | Brakes, Steering & Suspension | 5 | 11-09-2007 05:27 PM |
| Anyone using rear camber bolts on their 04 STi? | g0tb00st | Tire & Wheel | 3 | 04-19-2005 09:36 PM |
| Has anyone installed fog lights on an 04/05 STI | mrl859 | Interior & Exterior Modification | 17 | 09-20-2004 12:21 AM |
| Anyone install sway bars on '05 STi | ChrisF | Brakes, Steering & Suspension | 10 | 07-21-2004 02:44 PM |
