Old 05-12-2004, 07:15 PM   #1
gravel
Member#: 11962
SILVER
Default Toyo T1-S pressure recommendations?
What pressures are people running in T1-S for street and auto-x?
I'm running 224/45 17 on a WRX sedan, currently set at 36 F/34 R.
I'm looking for a good starting point for even wear. I'm not running any outrageous camber and 0 toe all around.
Thanks
gravel is offline   Reply With Quote
Old 05-13-2004, 05:05 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I just recently retired a set of 215/45-17s that I was running on my Legacy. I generally ran them around 40psi front and rear on the street, and got good even wear. Like you, I have "normal" camber (-1.0 or 1.2, sumthin' around there) and 0 toe all around.
I did run them on the track a couple times, one weekend on my sister's all stock WRX wagon, and a couple sessions at two different tracks during the 2002 OTC. I think on track I only bumped up the fronts a little bit, maybe 42 or 44psi cold (can't really remember). I think I left the rears where they were. They did quite well on track, tire wear was very good, and at Buttonwillow I was only about 1sec per lap slower than I had been on Yoko A032Rs earlier in the day.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 05-13-2004, 09:03 AM   #3
Carl AMG
Member#: 32109
WRX TurboXS Stage 3
246.1 whp, 229.7 wtq
Pat Olsen
Agreed. The Toyo's have a relatively soft sidewall and need higher pressures than a lot of tires to feel sharp and show their true potential.
Carl AMG is offline   Reply With Quote
Old 05-13-2004, 09:51 AM   #4
subrew2
Member#: 2883
2004 STi
Silver/Gold
I ran on some 215/45-17 T1-S in a STX class 2.5RS for autocross. We ran on both asphalt (local events) and fairly grippy concrete (California Speedway and Atwater ProSolos) and settled on 46psi front and 40-42 rear.
We were at -3.2 camber in the front, zero front toe, 1/8th rear toe-out, Tein HA with 400#F/360#R, 19mm front bar, 22mm rear bar, 17x7.5 rims.
Huge difference with how the tires felt at 46 in front compared to 40.
Chris H.
www.subrew.com
subrew2 is offline   Reply With Quote
Old 05-13-2004, 10:21 AM   #5
Carl AMG
Member#: 32109
WRX TurboXS Stage 3
Chris H.
www.subrew.com
I'm assuming you're quoting hot tempratures. Correct?
Toyo Proxes T1-S pressure ? gravel Tire & Wheel 1 05-10-2004 12:48 PM
How Much Tire Pressure for 18" Rims w/225-35-18 Toyo T1-S? clsmooth71 Brakes, Steering & Suspension 3 02-21-2003 06:18 PM
Toyo T1-S- Consensus? ChrisDP Motorsports 0 05-23-2001 07:51 PM
Toyo T1S 17" pressure recommendations Ken Brakes, Steering & Suspension 1 03-12-2001 05:29 PM
Street/Auto-x tire pressures for Toyo T1-S? efoo Technical Forum Archive 1 05-05-2000 01:28 PM
