Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 09-04-2000, 11:35 AM   #1
horseflesh
Member#: 690
2000 Impreza RS 4 dr
Rallye blue!
Post MY00 bogs at launch (sorry for the dead horse beating!)
(Let me preface this by saying it COULD be operator error, I guess -- but it sure FEELS wrong... Also, the car is bone stock, and I run 87 gas.)
Anyway -- my MY00 RS bogs when when I engage 1st gear. For about a second the power will smoothly engage, and then my power and RPMs drop. This happens below about 2000 RPMs. (I have to take precise notes next time I drive.)
I can counter this by revving higher prior to disengaging the clutch, but I shouldn't *have* to start the car at 2500RPMs, right?
If I give it more gas when the power drop starts, I can partially compensate, but I have to put my foot WAY into it. The power and RPMs will then surge after about 1-2 seconds in the low-power zone.
The problem is noticeable, though MUCH diminished in 2nd gear.
I have read about other people with this problem. They have listed these things as helping:
NGK platinums
Bosch platinums
Aftermarket air filter/intake
High-octane gas
Anyone here have any experience with this? I am extremely reluctant to take the car to a dealer until I know more about what is going on... Is this my knock sensor? Or something else? Will resetting the ECU clear this up temporarily?
horseflesh is offline
Old 09-04-2000, 11:59 AM   #2
SkinMask
Member#: 1801
2000 2.5RS
Post
yeah, same thing happens to me, but I'm pretty positive it bogs a bit right as the clutch and engine equal out, so I just try to run the clutch a bit more if I am launching fast, or right as you feel is dying, push the clutch in a tad more and it will be fine.
-Jeff (SkinMask)
SkinMask is offline
Old 09-04-2000, 01:12 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
Ummmm, dont think changing your gas grade has anything to do with the bogging, its clearly relevent driver input.
The bogging is from not giving it enough gas as related to you rpms or vice versa, giving it gas but letting the clutch out to fast, youll just half to practice finding the correct amount of gas and how fast to let the clutch out.
The clutch is very sensitive and you have to let it out very slow and smooth.
Slow and smooth is the key with the gas and clutch. Once you master that you should have no problem, then you can move onto qwick and smooth! good luck, I had the same probem when I first got the car.
Practice practice practice
Jay McDade
MY00 BRP RS coupe
munkis is offline
Old 09-04-2000, 02:18 PM   #4
chrisww2
Member#: 2144
2006 B9 Tribeca
Post
No, I didn't reset the ECU after changing grades of gas. I think what McDade hit the nail on the head.
chrisww2 is offline
Old 09-04-2000, 03:06 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I drop the clutch about 4250 rpm's and barely ever get a bog. I do get them if I'm much higher or lower then that though. I think what is it is that is a good RPM to launch, sping the tires a little, and then hook at about the same RPM when you get going.
8Complex is offline
Old 09-04-2000, 09:08 PM   #6
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Post
Anything higher than 3 grand and you will not get a clean launch, unless you have power to break the wheels loose. N/A need to let the clutch out fast without dropping it, then power shift 1st to 2nd to 3rd to get a the most out of the engine. You have to know your RS to it right. All wheel drive is completely different than FWD or RWD. But, a turbocharged street RS will most likely cover more ground in a shorter time than a turbocharged GSR, because of less slippage.
Sunrise City Rider is offline
Old 09-05-2000, 12:04 AM   #7
horseflesh
Member#: 690
Rallye blue!
Post
Thanks for the data point.
A friend at work has an identical RS, I will have to take it for a spin and see how it feels as well.
Old 09-05-2000, 12:19 AM   #8
chrisww2
Member#: 2144
2006 B9 Tribeca
Post
I have the MY00 and had the same hesitation problems at launch. According to Trey at Cobb tuning the 2000 year models react differently to the type of gasilone you put in the car vs other years. This is really the case with any car. I was running 87 and switched to 93. The hesitation is gone now that I am using a different grade of gas. I have also got the K&N panel filter and the underdrive pulley and the performance exhaust from Subaru on that car as well. the problems are no longer there. Runs like a champ! Hope this helps!
-Chris
chrisww2 is offline
Old 09-05-2000, 12:56 AM   #9
horseflesh
Member#: 690
Rallye blue!
Post
After you switched gas grades, did you reset the ECU?
VF34 on my 07 WRX - yes I am beating the dead horse. snowflowmfg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 03-25-2010 12:21 AM
sorry to beat the dead horse bartx Normally Aspirated Powertrain 17 12-27-2004 06:57 PM
CARTER is the worst! All of you please read...sorry for the long complaint CJK North West Impreza Club Forum -- NWIC 38 07-30-2003 04:00 AM
sorry to keep beating the dead horse! Lordhowe Newbies & FAQs 8 05-02-2003 09:54 PM
Dead horse beating avonrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-05-2001 08:36 AM
