Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 09-03-2000, 09:40 PM   #1
Member#: 1992
Question O2 voltage question
MY 99RS W/ S-AFC I have my settings running in the plus's and i'm wondering, I hooked the blue wire to the B136 #7 at WOT i get about .83...but the reading isn't steady i know it'll decrease with throttle position but at wot it never stays at .8*** it jumps a little, Is this normal??
tmaler13 is offline
Old 09-03-2000, 10:04 PM   #2
Member#: 329
1995 325i
Arctic Gray
I'm not sure if this is what you're asking or not, but you can only reliably monitor the O2 sensor voltages at WOT. At any other throttle position, the ECU is constantly changing the A/F mixture to try to achieve optimum results, so the readings will bounce around enough so they're meaningless.
RidinLow is offline
Old 09-04-2000, 10:49 AM   #3
Member#: 248
Well when you are at true WOT it should stay steady. If you are increasing speed and RPM's it will jump slightly...but when you absolutley have the gas down all the way it shouldn't move.
Ps- Possible cuases if it does still move i have no idea.
Mumbles is offline
Old 09-05-2000, 06:42 AM   #4
Member#: 759
2004 WRX
2000 SV650
How much does it jump? I look at my Jumptronix A/F meter when tuning, and it has a lower resolution than the AFC, but I noticed with the stock intake that voltage can go from say .85 to .87. It always stays pretty close to the same number, but can move around .01, .02 V or so. If this is all the movement you see I wouldn't be too worried, but if it is like .05V or more that might be a different story. Of course since I put my JC Sports intake on I see a lot more variation in voltages at WOT, but since they are all nice and rich I am not concerened.
Nat is offline
link ecu O2 voltage and Map limit question. scooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-08-2003 09:51 AM
Link Plus o2 voltage range? Midwayman Engine Management & Tuning 1 04-17-2003 10:40 AM
How does one read o2 voltage from the LINK ECU? ScoobieSnaX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-27-2002 11:24 AM
O2 voltage always around .7 Tim Prudence Technical Forum Archive 13 10-04-2000 12:39 AM
Tuning/EGTs/O2 voltage Tim Prudence Technical Forum Archive 8 07-06-2000 04:42 PM
