Old 05-12-2004, 10:41 PM   #1
virpacalis
Member#: 19214
'07 STI
in the slow lane
Question Cusco Zero-2Rs (with Hoosiers coming in a few weeks)
With just a bit over a year of local auto-x, I run SM with good power, stock struts, and decent street tires. I know there's a lot more to learn from driving and EVO schools. I still want a faster setup for my car.
I've just bought coilovers and am preparing for the installation. A reputable shop will do this. I'm trying to figure out what to ask for.
I've read that a ride height of 13.5"+ (from fender to hub center) is good. 13" or lower is too low. (Correct me if I'm wrong.)
After the height is set, I guess they'll pull out the scales. What sort of results should I look for? What's ideal? What's too far off?
Should I have another adjustment for height and weight after the springs have settled? If so, how long should I wait? (I drive ~350 city/suburb/highway miles a week; auto-x once a month with a 2 driver car.)
When it comes to the alignment, how long should I wait? Can I get a good alignment even from someone who's skillful but won't adjust the ride height and corner weights? (Yes, I already have a good idea what street and auto-x settings are good.)
Is there anything else I should consider in setting up my daily driver/local auto-x fun car's new coilovers?
Thanks,
JD
virpacalis is offline   Reply With Quote
Old 05-12-2004, 11:13 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The corner weighting will help but it's not as important as having a good alignment, imho. From the couple times I've had my car corner weighted the corner balancing wasn't very far off to begin with, like less than .3%. If you are going to corner weight the car do so after the springs settle. What size tires are you running? You need a lot of camber in the front to make use of wide tires, at -2 I still had problems with riding the outside edges of the fronts.
Old 05-12-2004, 11:44 PM   #3
virpacalis
Member#: 19214
'07 STI
in the slow lane
Not very aggressive here. My Rotas (17x7.5) have Blizzaks or Michelin PS2s (225x45) depending on the season. I'm about to put Hoosier A3S03s (225x45) on my SSRs (17x7.5). If there's a better sized Hoosier for my SSRs, let me know. BTW I already have RA gears from RalliSpec.
Jacksonville, FL - Cusco Zero-2Rs with 2 sets of Cusco Springs digitalseance Suspension/Brakes/Handling 5 04-28-2009 11:07 AM
how to adjust Cusco Zero 2Rs? ommmjido Brakes, Steering & Suspension 6 07-04-2004 04:08 PM
Cusco Zero-2Rs starting to get noisey downeyer Brakes, Steering & Suspension 7 07-07-2003 12:12 AM
Tein HAs vs. Cusco Zero 2Rs (GC8) moss Brakes, Steering & Suspension 11 11-20-2002 02:12 PM
