Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 06-23-2000, 01:21 PM   #1
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
Cool
Actualy its the opposite.
When the gas cools down it gets more dense and slows down. The slower a liquid flows through a pipe the higher the pressure. Remember when you are washing your car and you stand on the water hose. When you squeeze the handle and the water is flowing quickly you will compress the hose. When you let off the handle the hose will fill with water and you will be picked up by the hose.
Slower moving fluids can apply a greater pressure to the walls of the pipe/hose. So if the exhaust gasses cool and slow down, they effectively can 'block up' the hotter faster moving gasses.
One of the reason that subaru puts so many darn heat sheilds around our stock exhaust is not only to keep it off our feet, but to keep the heat in the exhaust pipes, allowing the gas to remain hotter longer, and thus moving faster.
I might try leaving my 2.25" Stromung midpipe on and finding a low restriction muffler with a 2" or 1 7/8" connecting pipe. Just for kicks and see what I get.
Hope that helps JasonY
SCRAPPYDO
stephen
SCRAPPYDO is offline
Old 06-23-2000, 05:30 PM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Can't you just wrap the whole exhaust system with heatwrap? That would keep the gases hot throughout the system would it not?
Keiho is offline
Old 06-23-2000, 08:35 PM   #3
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Cool
sure you could do that.. or send the entire exhaust to JetHot and get it performance coated.. either way, but nothing will keep the gas from slowing down. Heat will help but you cant keep it from cooling down. I would be interested in doing some simple thermo on this.. be right back on this one..haha...
SCRAPPYDO
Old 06-24-2000, 12:35 AM   #4
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Cool exhausting idea....
Its no secret that when fluids passing through a narrow pipe flow faster than the same amount of fluids flowing though a big pipe. Basic fluid dynamics.
An old hot rod trick was too start the exhaust with a three inch diameter pipe off the header collector. At this point the gasses were hot and were flowing quickly. As the gasses cool they take up less volume and slow down.
What we used to do was to gradually decrease the size of the pipes going through the exhaust system. By reducing the diameter of the exhaust pipes, the velocity is kept high and and gasses were expelled more efficiently.
Just a thought...
SCRAPPYDO
Old 06-24-2000, 12:45 AM   #5
jasony
Member#: 1238
1996 Explorer XLT
Red
Post
You're probably right, but I wonder: if the pipe is the same diameter all the way, doesn't that mean that the cooler end will have lower pressure, and effectively help suck the higher pressure, hot end out?
I might be wrong, but if you can give some more explanation, I'd like to read it...
jasony is offline
An exhaust idea of mine...let me know what you think Rally_WRX1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 07-20-2006 08:21 AM
exhaust idea imprezar25 Normally Aspirated Powertrain 11 08-29-2005 08:36 PM
Exhaust Idea compfool Normally Aspirated Powertrain 23 07-11-2003 05:27 PM
brilliant exhaust idea wistful Normally Aspirated Powertrain 20 04-05-2003 02:39 AM
Exhaust idea, gimme some feedback MattDell Normally Aspirated Powertrain 17 12-16-2002 05:03 PM
