Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 09-03-2000, 08:27 AM   #1
gumball
Member#: 1209
Question help! Water from air conditioner?
Has anyone had this problem or does anyone have any insight?
I was running the A/C yesterday for a couple hourse in really really humid weather- we're talking disgustingly hot & sticky mid-atlantic stuff. Anyhow, my passenger noticed ice cold water dripping into the passenger side footwell. I figured it was condesnation from some A/C component. Before long, there was so much water I could hear it sloshing on hard left turns and when I accelerated it would "spill-out" from somewhere into the footwell.
I'm wondering if the extreme humidity just created so much condensate that it overflowed some drainage reservoir somewhere? Or is there something clogged? I know in home units the condensate has to drain freely. Anyhow, the carpet above the ECU is now soaked and there's standing water.
I know nothing about the A/C system and couldn't identify the components under the glovebox to save my life.
'97 GT, Rio "gumball" Red
[This message has been edited by gumball (edited September 03, 2000).]
gumball is offline
Old 09-03-2000, 09:49 AM   #2
AaronRS
Member#: 1362
99 2.5 RS
Post
gumball
I have had water drip in the driver side footwell after long air-conditioned runs. The shop told me it was condensation from the AC. Your problem sounds quite a bit worse than mine. I would have that looked at if you are getting enough to cause standing water! I only experienced a few drops. By the way, I drive a MY99 RS. Good luck.
AaronRS
[This message has been edited by AaronRS (edited September 03, 2000).]
AaronRS is offline
Old 09-03-2000, 10:23 AM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
There should be a drain on the evaporator so the water can get out, sounds like its clogged, take the car back to the dealer, if its under warrenty, you should be able to get new carpet and floor mats, argu w/ them about mildew and all that good stuff.
hope that helps
Jay McDade
MY00 BRP RS coupe
munkis is offline
Old 09-03-2000, 08:32 PM   #4
ARG
Member#: 386
1999 Impreza RS-S
Rally Blue & Supercharged
Post
Every car that I have ever owned that had air conditioning also had a drain tube for the water that builds up inside the evaporator. The Japanese cars have a "drain" in the bottom of the black box that contains the evaporator. Either your hose came off, ot it is clogged.
ARG
ARG is offline
Old 09-04-2000, 12:17 AM   #5
gumball
Member#: 1209
Talking
Thanks for the tips! Unfortunately its past warranty (57K). I did look under the dash and there's a black box of sorts and in the way back of the box by the firewall/footwell there's a tube (drainage?) that goes into a hole, right where the top of the ECU is. Talk about a silly place to allow water to flow. I'll see if I can disassemble. The seams of the black box are foam and are soaking wet.
gumball is offline
Old 09-05-2000, 12:38 AM   #6
sol
Member#: 1721
Post
It sounds like your drain tube is clogged. Chances are it's blocked by rotting leaves that blew in. Open the hood and look for the AC lines going thru the firewall. Look about 6 inches below them for a short black tube. Try to clear it out.
Another cause for AC leakage inside is when the optional vent air filter is put in wrong. The filter has a tab on the top that has to fit in a slot; otherwise the cover doesn't seat all the way and water drips onto the carpet.
sol is offline
Old 09-05-2000, 12:48 AM   #7
gumball
Member#: 1209
Exclamation
Thanks for the help everyone!
I found the drain tube and disconnected it, more water drained out of the black box into the footwell
I then pulled the drain tube off from the engine compartment side and sure enough it was clogged. I finally blew out the obstruction and it turned out to be a big dead spider- yuck!
Seems like there's a one way valve somewhere inside the tube- water flows fine from the evaporator, but not vice versa. So the spider must've got caught in the valve, died and totally stopped it up! hopefully a once in a lifetime occurrence.
gumball is offline
04 FXT AC Air Conditioner issues? KENLUDE97 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-01-2010 04:29 PM
Chirp when air conditioner is on - help lowkey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-29-2007 01:49 PM
swamp/stagnant water stink from air conditioner. HELP! ChosenWon Off-Topic 18 09-03-2004 05:35 PM
help! my air conditioner isnt working dashiet Service & Maintenance 3 01-10-2004 06:24 PM
Air Conditioner needs help Kilalee Service & Maintenance 7 09-26-2002 10:22 AM
