Old 05-13-2004, 03:40 AM   #1
SubaruTech707
Member#: 46067
97 GTI VR
66 F-85; 67 Cutlass
Default Will STi pinks/18x8 superleggeras be OK on STi?
I've read somewhere on this forum that according to [email protected] the 18x8's will work, I'm planning on the STi pink springs with stock struts. Anyone know if there's any rubbing problems with 225/40/18 or 235/40/18?
SubaruTech707 is offline   Reply With Quote
Old 05-13-2004, 10:25 AM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
OZ is currently working on an 18x8 with a 48mm offset that will fit an STi but, the current model which has a 51mm offset will not clear the brakes
Old 05-13-2004, 04:38 PM   #3
STIgeorge
Member#: 22040
12 FJ Cruiser
Rent-a-car White
Its either a hit or miss w/ rubbing issues. I recently went through the same thing as you, trying to figure out what will and wont work, only to come to the conclusion that there is no way to tell unless you try it. If you get lucky, they wont rub, if you're not lucky, theyll rub.
That being said, the chance of the 225s rubbing is less then that of the 235s rubbing.
I'm getting my 18x8 GC010E's this week and will report my results with Pinks/strut tops and Toyo T1S 235/40/18 once they're on.
-Geo
STIgeorge is offline   Reply With Quote
18x7.5 et35 will i be ok on my 03rex? NVSPRELUDE Tire & Wheel 24 07-04-2008 05:57 AM
will these be ok on my wagon? phoenix1112 Tire & Wheel 12 07-21-2006 11:37 PM
will sti pink injecters make a difference on a stock o2 wrx?big small? h_p Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-19-2006 07:58 AM
Will a 225 45 R17 fit ok on a 17X8", or would a 235 45 R17 be better? SolidSnake Tire & Wheel 15 04-15-2006 12:57 PM
Will 205's be OK on a 7.5" wheel? Corey Brakes, Steering & Suspension 6 10-12-2001 04:11 PM
