Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 05-13-2004, 04:10 AM   #1
zavala
Member#: 44371
Default can my wrx live with out the charcoal canister?
with this cause any problems other than a cel? and if not how do you take it off? just plug all the hoses?
zavala is offline   Reply With Quote
Old 05-13-2004, 08:10 AM   #2
1DOWNCLOWN
Member#: 50287
02 WRX
not to high jack but what is a charcoal canister and what does it do?
1DOWNCLOWN is offline   Reply With Quote
Old 05-13-2004, 08:35 AM   #3
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
Yeah, what are you talking about?
rankink is offline   Reply With Quote
Old 05-13-2004, 08:46 AM   #4
Wires
Member#: 36677
2003 WRX Wagon
Sedona Red
A charcoal canister is literally a canister filled with charcoal that is is used to trap fuel vapors.
Different manufacuturers use them in slightly different ways - oten involving solenoids and engine vacuum. The point is to avoid releasing fuel vapors into the atmosphere and many systems introduce them into the engine for combustion.
I haven't studied the system used on Subarus, so I can't get more specific. I would think you should understand exactly how the factory system operates before you removed it. Maybe "plugging all the lines" would work, maybe not.
Wires is offline   Reply With Quote
Old 05-13-2004, 09:43 AM   #5
geronimo66
Member#: 26929
2000 Impreza
with Gremilins
Why would you want to remove it... no performance increase there.
geronimo66 is offline   Reply With Quote
Old 05-13-2004, 10:25 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Besides this, the evaporative emission system is rather complex and has many other components besides the canister.
You will have a permanent CEL from several evap-related codes that can't be bypassed, and the crankcase and fuel tank won't be vented properly.
I can think of no good reason to do this.
Old 05-13-2004, 10:28 AM   #7
sc00by71
Member#: 5362
2004 OBS
Green
Gasoline vapor has to go somewhere. I definitely wouldn't plug it. As mentioned previously there is no performance benefit.
Shawn
sc00by71 is offline   Reply With Quote
Old 05-13-2004, 02:39 PM   #8
SQC 155
Member#: 52622
2002 WRX stage IV...
Silver and now wrecked :(
Mulder....did you go to scooby college or what??
SQC 155 is offline   Reply With Quote
Old 05-13-2004, 03:39 PM   #9
BeeGee
Member#: 27724
1970 F100
Black/White
I'm still curious why you wanted to do this in the first place.
BeeGee is offline   Reply With Quote
Old 05-13-2004, 03:41 PM   #10
HD-sw20
Gone But Not Forgotten
Member#: 37056
Shawn
WEIGHT is the only one i can think of. In my other cars i just eliminate the charcoal canister. No problem at all.. Once in a while i will smell fuel vapor but nothing strong.
HD-sw20 is offline   Reply With Quote
Old 05-13-2004, 03:44 PM   #11
02WRX03060
Member#: 19897
You will throw a CEL, I have the exact number at home if you want it. I had body work done to the back right corner and the shop did not put it back in right, so my car threw a CEL. If the canister hoses are punctured you will throw a CEL also.
02WRX03060 is offline   Reply With Quote
Old 05-13-2004, 05:25 PM   #12
sick1.8t
Member#: 22345
2003 RSX
black
just for knowledge, my 93 L with the 1.8L DIDNT throw the cel when i removed the canister.
i just plugged the input tube right into the output tube, and bypassed the now non-existant canister.
i did it just to clean up the engine bay a little.
sick1.8t is offline   Reply With Quote
Old 05-13-2004, 09:45 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A '93 is OBDI. The evap system is a lot less complicated and isn't monitored as closely by the ECU. Newer cars ('96-up) are OBDII, there is a lot more hardware and more parameters are monitored.
Old 05-14-2004, 03:00 AM   #14
UGotBoost?
Member#: 45735
2002 Impreza WRX
That's funny, EXACT same thing happened to me.
I'm putting a drawtite hitch on my car soon, it re-mounts the Charcoal Canister (Carbon Canister, according to Draw-Tite)
UGotBoost? is offline   Reply With Quote
Old 05-14-2004, 04:34 PM   #15
zavala
Member#: 44371
i was wondering just purly for weight savings. i took the rear bumper beam out (i know i know please no commments) and the bolts that held on the bumper beam also held on the charcoal can. so now it's held up with zip ties. i was just wondering if it could be removed
Old 05-14-2004, 06:36 PM   #16
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Leave it alone. Not worth the problems that will result for those few pounds. You should find a better way to hold it in place though.
You've already removed far more weight with the bumper beam than you would with the canister.
BTW unless you remove stuff from the front of the car also you're changing the front/rear weight bias of the car in the wrong direction. If you're that serious about weight you should at least relocate the battery to the trunk, if you haven't done so already.
Old 05-15-2004, 12:40 PM   #17
zavala
Member#: 44371
i removed the front and rear bumper beams, took out the spare and tools and i'm buying a 15 pound optima battery.
Old 05-15-2004, 01:11 PM   #18
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Since nobody ever pops a tire, needs to make a roadside jack, or ever gets in a accident those mods you made sound good.
cdvma is offline   Reply With Quote
Old 05-15-2004, 01:11 PM   #19
UGotBoost?
Member#: 45735
2002 Impreza WRX
Old 05-15-2004, 02:39 PM   #20
wrxited
Member#: 58289
removind the charcoal canister.......
wrxited is offline   Reply With Quote
anything happen when you take out the carbon canister turbocolin Normally Aspirated Powertrain 29 04-18-2009 10:33 AM
What's the solenoid just above the charcoal canister? mc2 Normally Aspirated Powertrain 3 02-25-2009 04:38 PM
whos got pics on the charcoal canister removal? White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 18 07-05-2006 02:14 PM
Does the charcoal canister need replacement? mpaone Service & Maintenance 12 03-16-2005 08:20 AM
can I do this with out lowering the car wrex03 Brakes, Steering & Suspension 10 12-17-2002 11:05 PM
