Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Vancouver Impreza Club
Old 05-13-2004, 12:09 PM   #1
dunny
Member#: 4115
2002 Impreza WRX
Exclamation Cost for 48K service?
Well, my WRX is up for its 48,000 km service. I phoned DD, who've done a great job so far--excellent wrenching and good pricing and service--and the rep said, "oh, this is a big one." She then said it would run $700, including an alignment.
My eyes almost bugged out right there and then. I said I'll get back to you. A quick look at the Subaru service manual shows they estimate 3.5 hours for the labour and the following items are replaced:
engine oil and filter
air filter and fuel filter
engine coolant
brake fluid
Excluding the alignment (about $100), which I just had and Subaru doesn't think I need, are we really looking at $250 for the filters and fluids, assuming $100 an hour in labour?
What have you guys been paying?
dunny is offline   Reply With Quote
Old 05-13-2004, 12:36 PM   #2
youthanasia
Member#: 1883
2013 R60S All4
The labor varies from $60-80 (sometimes more) per hour.... if you do your own engine oil/filter change and air filter change, it might end up cheaper.
youthanasia is offline   Reply With Quote
Old 05-13-2004, 01:03 PM   #3
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
dealer is usually charging about $85 to $100/ hour...i forgot what is the rate for DD...but they will definitely be higher than others
48k service should includes:
oil and oil filter change
gear oil (for MT)
front differential fluid and automatic transmission fluid (for AT)
rear differential fluid
brake fluid
coolant
pcv valve
fuel filter
maybe:
spark plugs
air filter
4 wheel alignment
e-brake adjustment
tire rotation
the list can go on and on (like front and rear brake pads need replacing, tires etc)
also if u choose to use synthetic oil (for engine, transmission and differential, say using Motul)...K&N air filter or Iridium spark plugs or whatever (while u are doing all these anyways)...anything like those will bring up the service cost...and of course...DD would probably only use OEM parts only
and i will say...always use OEM (standard) or above quality parts...
5 Zigen is offline   Reply With Quote
Old 05-13-2004, 01:06 PM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
6-700 is about right for 48K form the dealerships. Although most people don't bother with the allignment it may be worthwhile. Take a good look at your tirewear. You can get the things needed from the service done much cheaper from a non-dealership garage, just make sure you know exactly what really needs to be done.
tora is offline   Reply With Quote
Old 05-13-2004, 01:08 PM   #5
Blackskull
Member#: 5616
2002 Impreza WRX
Did it myself.
The fuel filter's cheap.. $38 or so. Fairly straight forward to change out. There are some guides floating around.
The brake fluid looked good still, so I just used a turkey baster and suctioned out as much fluid as I could thru the reservoir and refilled with some fresh fluid... $7
Oil change... simple. Mobil1 and filter $36-$40
Coolant change... simple. $10
Total just under $100.
Took me maybe 2 hours... I don't really recall cause I also changed out my front pads.
Blackskull is offline   Reply With Quote
Old 05-13-2004, 01:30 PM   #6
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
i would not pay $700 to do those stuff for sure..
KIMUTAKU is offline   Reply With Quote
Old 05-13-2004, 01:35 PM   #7
Ken
Member#: 34
2005 WRX STi
World Rally Blue
It should be $600-700 as others have said. I'd think it would be $700 if they used all synthetic fluids.
Ken is online now   Reply With Quote
Old 05-13-2004, 03:02 PM   #8
Gethin
Member#: 2998
Most of that you can do yourself.
If you're not into that you can split it over the 48K and the next service.
Tire rotation, Air Filter, Oil and Filter change, coolant change is simple for you to do.
Spark plugs are not due until 96,000Kms on the WRX.
Gethin is offline   Reply With Quote
Old 05-13-2004, 03:15 PM   #9
Shishkabobo
Member#: 18723
2002 impreza 2.5TS
green
my 48k at DD for my TS.
labour = 377.40
parts came to 234.62
tax = 90
grand total came to 700.77.
Shishkabobo is offline   Reply With Quote
Old 05-13-2004, 04:35 PM   #10
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
Ouch!
This sort of thing makes a $2g hoist look like a good investment.
steve is offline   Reply With Quote
Old 05-13-2004, 05:54 PM   #11
holam
Member#: 8878
98 wagon white
99 2.5RS white
Anybody know about the 96,000km service? How much would it cost?
holam is offline   Reply With Quote
Old 05-13-2004, 06:05 PM   #12
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Old 05-13-2004, 06:55 PM   #13
dunny
Member#: 4115
2002 Impreza WRX
Thanks for the link Ken. It looks like someone freaks over this bill every six months or so. Gotta keep the tradition alive.
I think I'll go with DD anyhow--but I've read enough about Total to give them a shout. Have people been happy with the work, service and price? And how does it compare to the dealerships?
I'll probably start doing some of my own maintenance in the future, but right now I don't have the tools or the time.
And as for the 96,000km service, if you've got a SOHC engine it's the same as the 48k, if you've got a DOHC then you've got to replace the spark plugs. Subaru lists 5 hours as the recommended time as opposed to 3.5 for the 48k. Add that extra 1.5 hours and the cost of spark plugs and you're probably looking at just under $1000 for the service. Ouch.
Old 05-13-2004, 07:52 PM   #14
madmanslegacy
Member#: 25911
89 R32 GTS-T
Give Cody @ TOTAL a call, he'll know
Depending on what u NEED!
(604) 980-9800
MM
madmanslegacy is offline   Reply With Quote
Old 05-14-2004, 02:54 PM   #15
banman
Member#: 12408
2006 Legacy GT
Is there an objective way to measure when your brake fluid needs replacing? I'm using DOT5.1 fluid . . . which IIRC needs replacing more often than standard fluid because it's not hygroscopic?
Originally posted by Blackskull
Did it myself.
banman is online now   Reply With Quote
Old 05-14-2004, 02:58 PM   #16
2wheelsx2
Member#: 44045
2004 Impreza WRX
Yeah, clear fluid = good to go
Dark, murky fluid = replace
Brake fluid is cheap, and it's easy to do. I would do it myself whenever it looks dark.
2wheelsx2 is offline   Reply With Quote
Old 05-14-2004, 06:49 PM   #17
dunny
Member#: 4115
2002 Impreza WRX
Alright, booked with Total. The price is a good sight better than the dealerships. This is their chance to show me the work measures up. We'll see!
Old 05-14-2004, 07:43 PM   #18
Tricky
Tu ne cede malis sed contra audentior ito
Member#: 28960
2002 Stock WRX Wagon
MBP with door dings
Let us know your impressions!
I know a few of us are fast approaching that same maintenance point.
BTW all is good... Thanks again!
Props to Dunny.
Tricky is offline   Reply With Quote
Old 05-14-2004, 08:20 PM   #19
Koyo
Member#: 19332
Wait til you got the 96K service. I just got back from Specialty and the bill comes out to 1200. 5.5 hour of labor plus another 500 bucks in parts. Yeah it's expensive but I don't have the skills or the time to do it myself.
Koyo is offline   Reply With Quote
Old 05-14-2004, 08:45 PM   #20
dunny
Member#: 4115
2002 Impreza WRX
Tricky:
Good to know all is working out, now lets see some pics!
Old 05-15-2004, 10:54 AM   #21
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Actually the colour of brake fluid has nothing to do with the amount of water that's in it -- only how long it's been exposed to air. With our weather it's a good idea to replace that stuff every year or two.
Necromancer is offline   Reply With Quote
48K service due ForEveR2.5 Vancouver Impreza Club Forum -- VIC 9 10-13-2005 04:26 PM
WRX 48k Service Uncle Ben Vancouver Impreza Club Forum -- VIC 24 04-22-2005 11:15 PM
Cost for 72k service differ from 24k Mirage Vancouver Impreza Club Forum -- VIC 12 01-13-2005 10:59 PM
48k service Rudypoo Vancouver Impreza Club Forum -- VIC 2 12-05-2002 03:56 AM
$600+ for 48K Service? Warz Vancouver Impreza Club Forum -- VIC 8 04-06-2002 06:08 PM
