Old 05-13-2004, 02:12 PM   #1
geronimo66
Member#: 26929
2000 Impreza
with Gremilins
Default L drum to disc swap check list??
I have a set of rotors, calipers, and mics brackets from a MY02. I know I will need the H-brake cable and I think the rear knuckles, I plan to upgrade the lines and pads. Question what else do I need? Also anyone know the going price for a rear knuckle?
Thanks
geronimo66 is offline   Reply With Quote
Old 05-13-2004, 02:17 PM   #2
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Merasian auto wreckers in Zeeland can hook you up with some Legacy knuckles for about $45. Unknown condition or mileage.
The ebrake cable should come from an impreza for better fit. You also need the ebrake assembly which is very expensive for new parts. Otherwise you have the complete list except for the tools necessary to get the old knuckle off. It can be a challenge.
linsavy is offline   Reply With Quote
Old 05-13-2004, 02:27 PM   #3
geronimo66
Member#: 26929
2000 Impreza
with Gremilins
cool thanks!
Old 05-13-2004, 09:49 PM   #4
redwagon
Member#: 2181
2008 SpecB
If your L is an ABS car, make sure the knuckles you get are for ABS (check for the hole for the sensor and the tone wheel on the hub).
If the knuckles have been sitting outside for a while, the bearings will probably be shot. Check carefully and replace as necessary. Much easier to do this before install. Ditto on the warning about e-brake parts. Make sure to get knuckles with a full e-brake setup, shoes, springs, clips, adjusters etc etc.
Obligatory link to tutorial
Have fun
redwagon is offline   Reply With Quote
Old 05-14-2004, 09:54 AM   #5
linsavy
Member#: 11620
No ABS on a 2000L, but something to be carefull about for those who do.
wtb: parts for rear drum to disc swap danotakulus Private 'Wanted' Classifieds 0 07-01-2008 01:11 PM
drum to disc swap Dr. J Brakes, Steering & Suspension 3 10-07-2004 09:24 PM
Any estimates on how much a drum to disc swap would cost ? Karlos Brakes, Steering & Suspension 5 10-21-2003 10:25 PM
I wonder if you do more harm than good swapping from drum to disc in the rear ciper Brakes, Steering & Suspension 12 06-03-2003 10:40 PM
Drum to Disc brake swap?? k2snow Brakes, Steering & Suspension 2 10-18-2002 09:07 AM
