Old 05-13-2004, 08:36 PM   #1
legzy
Member#: 55807
1993 Legacy Sedan AT
AWD Turbo maroon
Default help.........car running on 2 rear cylinders,can both go bad @ once?
Driving to work yesterday and found out that there was not enough power in the car.
I test the plugs and found out only the two plugs closest to the dash are working,while the 2 closest to the radiator are not working.
I tested the distributor, found out no current is been supplied to the two closest to the radiator.I replaced the distributor and the problem persists.
why would 2 cylinders go bad all at once?Is it an eletrical problem?
Pls help
legzy is offline   Reply With Quote
Major Issues 2.2 Only Running On 2 Cylinders After I Cleared Cel Codes (iacv) bcustom561 Service & Maintenance 2 05-20-2010 08:17 PM
Running on 2 cylinders v9 swap SpinIce Subaru Conversions 2 07-01-2008 11:25 PM
P0303 & P0302 Codes, Misfire, Running on 2 Cylinders bigbird Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2004 12:44 PM
please help car running on 3 sometimes 2 clinders turbocolin Normally Aspirated Powertrain 9 08-18-2004 06:38 PM
help.........car running on 2 rear cylinders,can both go bad @ once? legzy Engine Management & Tuning 4 05-19-2004 06:17 AM
