Old 05-13-2004, 10:42 PM   #1
virpacalis
Member#: 19214
'07 STI
in the slow lane
Question best auto-x tire size for 17x7.5
What do you recommend: 225/45 or 245/40? If the latter, is there a problem and/or a fix for rubbing with my '02 sedan with stiff springs? (BTW I have RA gears.)
virpacalis is offline   Reply With Quote
Old 05-14-2004, 08:11 AM   #2
KC
Member#: 442
16 SS
00 S2000
It all depends on what kind of tire you're looking for. Street or R-Compound? (Ie: is budget an issue? )
Also, what do you define as stiff springs? Are you running a coilover setup or just springs with stock struts?
245/40's might be too wide for an R compound (I'm saying R-compound becuase you're probably in SM). R-Compounds are generally wider than their street counterparts.
225/45 is best suited for a 7.5" wheel, but a 245/40 can fit, but wouldn't be square on the wheel (would be rounded more at the corners)
Hoosier S04 245/40 $212 -- 225/45 $202
Kumho Victoracer V700 245/40 N/A -- 225/45 $160
Kumho Ecsta V700 245/40 $159 -- 225/45 $156
Kumho MX 245/40 $129 -- 225/45 $122
TA/KD 245/40 $186 -- 225/45 $165
Falken Azenis 245/40 N/A -- 225/45 $115
KC is offline   Reply With Quote
Old 05-14-2004, 05:14 PM   #3
virpacalis
Member#: 19214
'07 STI
in the slow lane
Thanks for the helpful info. Indeed I'm a slow local in SM. I'm definitely going for an r-compound for my SSRs while running Rotas with Michelin PS2s daily. In terms of springs, I'm installing Cusco Zero-2Rs with the usual 7/5 setup next week.
Old 05-14-2004, 05:37 PM   #4
zoomfactor
Member#: 30440
03 WRX
WR Blue
Boy, when you look at the $$ don't your eyes water
Sure would be nice to have a budget for a few sets of each per year, especially the Hoosiers!
JD <---- never tried a set of the legendary Hoosiers
zoomfactor is offline   Reply With Quote
Old 05-14-2004, 07:44 PM   #5
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
You can also shove a 255/40/17 victoracer on there.
afpdl is offline   Reply With Quote
Old 05-15-2004, 09:31 AM   #6
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Wink
You too???
-mykr.
mykrrrr is offline   Reply With Quote
Old 05-16-2004, 07:48 PM   #7
MRF582
Member#: 48219
. Always drive
the race line .
is that a bad thing if the tire isn't square over the wheels? 245's will have a bigger contact patch than 225 for sure. but is there more sidewall flex that happens b/c of that?
MRF582 is offline   Reply With Quote
Old 05-16-2004, 09:23 PM   #8
SolbergWRCfan
Member#: 56229
2001 Subaru Forester
Blue Ridge Pearl
A squirmy feeling, slower turn in, and the possibility of the tire falling off the rim.
Jon
SolbergWRCfan is offline   Reply With Quote
Old 05-16-2004, 10:33 PM   #9
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Tell that to all the stock class autox competitors at Nationals.
- Steve
zzyzx is offline   Reply With Quote
Old 05-17-2004, 07:48 AM   #10
virpacalis
Member#: 19214
'07 STI
in the slow lane
- Steve
Are they putting 245s on stock rims?
Old 05-17-2004, 03:53 PM   #11
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Hes not just talking about stock wrxs, in most of the stock classes at nationals you will find a few people with tires way way larger then the reccomended size shoved on stock rims.
Old 05-18-2004, 11:00 AM   #12
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
If you're still learning, get the 225's because you won't notice much with the 245's until you get better. If this is your first season, I would even reccomend giving the Azenis a shot first.
trojan9x is offline   Reply With Quote
Old 05-18-2004, 12:11 PM   #13
virpacalis
Member#: 19214
'07 STI
in the slow lane
I'm well into my 2nd year and have a whole lot to learn. I'm sure EVO driving schools will help.
I'm still trying to figure out a good match for my 17x7.5 rims, but it's interesting to know that some who are competitive put a 245 on a stock sized rim.
Since it seems like a plausible compromise, what about the Toyo PROXES RA-1 in a 235/40? Is that even an r-compound tire?
Best autoX tire size for 17x7,5 wheels ? elberoth Autocross 11 06-04-2010 07:37 PM
What tire size for 17x7.5 Tarmac II? OceansPorch Tire & Wheel 1 11-07-2004 02:51 PM
Best tire size for 17x7 rims? Jfloyd Brakes, Steering & Suspension 2 12-28-2002 01:48 AM
Tire Size for 17x7.5 and 18x7.5 ScoobyWRX Brakes, Steering & Suspension 3 08-16-2001 11:50 AM
