Old 05-14-2004, 10:05 AM   #1
Barticus
Member#: 57709
97 Legacy 2.5 GT
green
Default sad news and glad news
The sad news is I have a beautiful ej20 in my garage equipped to go into my legacy. It seems that the clip I got from japn was to early of a model so the wiring won't work . The good news is I'm taking the turbo etc. and putting it on my legacy, so now I will be in your "club". I'm planing on runing about 6 psi, any wisdom would be useful.
Barticus is offline   Reply With Quote
Old 05-14-2004, 10:07 AM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
i think u might be better off parting that thing out or selling it as a whole after u quad confirm that wiring issue
then buy stock wrx parts <american>
Old 05-14-2004, 10:10 AM   #3
Barticus
Member#: 57709
97 Legacy 2.5 GT
green
I am actually trying to sell the longblock right now.
Old 05-14-2004, 02:29 PM   #4
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
and the good news is, I just saved a hundred bucks by switching to geico!
cRayZee is offline   Reply With Quote
Old 05-14-2004, 02:43 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Old 05-14-2004, 09:47 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
what exactly do you mean won't work
you will be better off using the ej20 long block and ej25 harness than turboing the ej25
things like
oil and water lines
lower compression
oil cooler
correctly sized injectors 425cc vs 280cc
Old 05-14-2004, 10:43 PM   #7
Aphex
Member#: 146
'16 WRX Limited
Even if you got the same year EJ20 engine as your car, the wiring still will not work. This isn't a honda swap, any engine swap in a subaru requires new wiring to the ECU
Aphex is offline   Reply With Quote
Old 05-16-2004, 04:25 PM   #8
Barticus
Member#: 57709
97 Legacy 2.5 GT
green
I know this. I got a obd-1 engine, not two. The wiring would be basically impossible. Especially since it was from a 94 jdm wrx. Maybe if I knew japanese and had fsm for it.
Old 05-16-2004, 07:36 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
welll
not exactly
ther are both dohc
both have the same crank and cam sensors
same water/oil sensors
same plugs on the injectors
you will need a piggy back to adjust the fuel and spark but you are going to have to do that any way ..
i know of several people that ran ej22t motors off 1.8 ecus for extend periods of time
and for what its worth who ever told you the wireing won't work in your 97 (assuming you haev it all) is WRONG. it will work ..
Good news and bads news serious Legacy Forum 13 03-17-2003 01:24 PM
WRX Wagon fender rolling w/pics- good news and bad news JohnW Brakes, Steering & Suspension 21 05-01-2002 01:44 PM
good news and bad news fooie8 Tri-State Area Forum 6 01-27-2002 09:00 PM
('93-'01) Good News and BAD news!! Andre Vandenberg Impreza Forum 16 06-09-2001 01:38 PM
Bad news and good news Rudypoo Vancouver Impreza Club Forum -- VIC 3 02-11-2001 09:58 PM
