Old 05-14-2004, 03:06 PM   #1
Barticus
Member#: 57709
97 Legacy 2.5 GT
green
Default Turboing ej25
I'm wondering what other people have done to give there turbos oil and water. I am using a stock wrx setup (exhaust and turbo). Dose the turbo need pressurized oil and water lines or does it suck them in?
Barticus is offline   Reply With Quote
Old 05-14-2004, 03:51 PM   #2
rbehny
Member#: 1908
as far as i know some turbo kits come with oil pan attachments that direct oil to the turbo. So using that idea, i believe it would be pressurized, well it would be the same pressure as the engines circulation.
I doubt the turbo sucks it in because that would require the turbo to use some of its energy to draw in fluid. That would take away from the power it could make and also the flow would vary depending on the turbine speed which could lead to over heating.
I'm not sure but thats the best answer i can give, right now.
rbehny is offline   Reply With Quote
Old 05-14-2004, 04:35 PM   #3
Tats
Member#: 5692
WTF? YES! I am
better than you!
The turbo gets oil from the block and drains back to the pan or valve cover.
It gets it's water from either the TB hoses or the heater hoses.
The oil feed is pressurized and the drain is gravity.
Water is pushed into the turbo by the water pump.
Tats is offline   Reply With Quote
Old 05-16-2004, 04:32 PM   #4
Barticus
Member#: 57709
97 Legacy 2.5 GT
green
So, I'm guessing I should just bung a heater core hose or something and then run the oil drain into the pan. On the water return is there any specific spot that would be best?
Old 05-18-2004, 07:33 AM   #5
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
Hey Barticus,
Click this link, lots of similar questions and answers here: http://forums.nasioc.com/forums/show...hreadid=335174
Hope this helps.
JoeT is offline   Reply With Quote
Old 05-18-2004, 02:11 PM   #6
Barticus
Member#: 57709
97 Legacy 2.5 GT
green
thanks
WTB: Turbo or non turbo EJ25 block & crank bugeyes Private 'Wanted' Classifieds 0 12-30-2006 03:41 AM
turbo EJ25 DOHC waren Canada Region Forum 2 04-16-2002 01:46 AM
Properly Tuning a Turboed EJ25? MY99 2.5GT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-23-2001 11:26 AM
turbo EJ25 in the Chevy Borrego concept? KooshDogg General Forum Archive 6 01-06-2001 11:54 AM
Twin turbo EJ25? 8Complex Technical Forum Archive 51 09-19-2000 12:16 AM
