Old 05-14-2004, 11:51 PM   #1
commador
Member#: 59227
1998 Legacy GT
Black w/ gold pearl
Default fuel pump, rrfpr question
If I order a FAT stage1 from kastleskorner.com, does anyone know if the walbro pump in the GC8 can handle the rrfpr with the kit?? I emailed FAT and they said an 8:1??? does this sound right at all? OR if anyone has experience with that kit, do you know what rrfpr comes with it?
commador is offline   Reply With Quote
Old 05-15-2004, 02:11 PM   #2
xleratedwrx
Member#: 61964
2002 impreza 2.5 Rst
Default RRFPR
I got a vortech with mine and I was told it was 10.1 and my car was running lean so I would suggest that you get the 12.1 kit instead
xleratedwrx is offline   Reply With Quote
Old 05-15-2004, 02:16 PM   #3
commador
Member#: 59227
1998 Legacy GT
Black w/ gold pearl
12:1??!? what kind of kit did you get? wouldnt a 12:1 be too much pressure for the pump at 5 psi? at full boost that 60psi + base (which I dont know what the base is...) How much pressure can the walbro pump handle?
Ok, I checked out the walbro pumps, and they have two kinds, a standard, and an HP. the 225HP can go as high as 140psi
So then I guess the question is, does the FAT kit come with the standard 225, or the 225HP?
fuel pump relay question imprezaclipse Subaru Conversions 3 06-13-2007 04:57 PM
Fuel pump wiring questions WRC1 Electrical & Lighting 1 01-20-2005 06:17 AM
Quick fuel pump replacement question Daveish Normally Aspirated with bolt-on Forced Induction Powertrain 1 12-09-2002 08:41 AM
Fuel Pump Relay Question NickSTi Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-03-2002 03:31 PM
Fuel pump install question roybfr Factory 2.0L Turbo Powertrain 1 05-12-2002 03:22 AM
Message Board Statistics All times are GMT -4. The time now is 06:57 PM.
