Old 05-15-2004, 01:58 PM   #1
FastWagon
Member#: 20898
2002 WRX Wagon
Default CEL after catback install??
Here's my Scooby's breathing setup:
PDE uppipe and downpipe (catless)
Removed intake silencer
Stock Turbo
Stock injectors
Blitz SBC-iD EBC set at 16psi
Now I've replaced the stock catback with a Bosal (same as SPT) 3" single tip catback. Things have been running well for probably ~400km, now this morning driving home form work I throw a CEL. EGT reading normal, Boost not higher than ~15psi. there was no fuel cut or anything, just a slight change in the exhaust note....maybe a little more flat sounding for a moment..?
Anyway, I pull over, stop the engine, check for any obvious problems and find nothing. Drive home normally, check a little closer, and go for another test drive... CEL won't clear after multiple restarts, but nothing seems to be out of the ordinary otherwise...
I'll probably have to wait 'till monday to get the code read, any ideas of what might be happening?? Could it be a cat insufficiency, or EGT code that is showing up now due to the increased exhaust flow??
Any help or suggestions would be greatly appreciated!!
Thanks!
FastWagon is offline   Reply With Quote
Old 05-15-2004, 04:42 PM   #2
Mr. Fancypants
Member#: 17626
2005 STI
Probably P0420. Time for the mechanical fix. Also if you are using stock EGT sensor, you might want to take it out and plug it with a bolt because its going to fail with that higher boost.
Mr. Fancypants is offline   Reply With Quote
Old 05-15-2004, 05:13 PM   #3
FastWagon
Member#: 20898
2002 WRX Wagon
Thanks, that's what I'm thinking too... I know the ultimate fix will be to get the Cobb accessport, and dump the EBC ....just have to wait for my budget to permit that !!!
Old 05-20-2004, 02:59 AM   #4
FastWagon
Member#: 20898
2002 WRX Wagon
Got the code read today at the dealership, "High EGT" They cleared the code, and are going to "replace the sensor" under warranty apparantly they had someone else in a while ago with similar mods and it worked for them.... Still can't wait to get the Accessport, and be done modding ....for a while
Misfire in Cylinder 1 CEL after Flywheel install?? Scoobs2002 Engine Management & Tuning 19 05-13-2008 09:14 AM
CEL after header install?? TrizzyDizzy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-09-2004 04:20 PM
no CEL AFTER header install...? jefersun Engine Management & Tuning 1 03-13-2004 10:15 PM
No CEL after DP install wrxpeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-22-2004 12:00 PM
P0136 CEL after Clutch install 02GatorWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-09-2002 12:08 PM
