Old 05-15-2004, 08:00 PM   #1
Rev1
Member#: 51240
08 Lexus IS350
Smile Steering wheel alignment issues? No more!
I was fed up of having to drive with my steering wheel cocked slightly to the right on the freeway and on straight lines, so I finally managed to correct this myself by adjusting the steering tie rods for both the driver and passenger side.
And yes, it is an alignment issue. Correcting the toe, basically.
I basically followed the service manual alignment tips, and managed to make the car track perfectly straight now.
You just need a 14mm wrench for adjusting the tie rod, and I used a crescent wrench for undoing the tie rod lock nut.
It is torqued lightly (~60lbs-ft) so, no issues here. Fairly easy to undo.
Here's an excerpt from the manual:
Here's the steering tie rod:
As the manual says, undo the tie rod lock nut first (righty tighty, left loosey rule applies, from below the car and facing the wheels)
Then, grab your 14mm wrench and adjust the tierod, clockwise to increase toe, counterclockwise to decrease.
After 3 runs, I was able to adjust it perfectly. Talk about a ghetto alignment
As my steering wheel was cocked to the right, and when I held the wheel straight, the car will drifted left, I increased the toe slightly (about 2 threads) on the right wheel, and decreased toe for the left wheel.
Rev1 is offline   Reply With Quote
Old 05-15-2004, 10:13 PM   #2
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Crap, i might have to do this tomorrow... My steering wheel is cocked ever so slightly to the right when i'm driving
Old 05-15-2004, 10:32 PM   #3
Rev1
Member#: 51240
08 Lexus IS350
Yeah, pretty easy to do. Everyone I asked kept telling me "take it to the dealer"... I'd rather do it myself and it was so easy
Old 05-15-2004, 10:32 PM   #4
Psydotek
Member#: 44168
2003 Yellow WRX
Actually, i've got a clarification question... Since the Tie Rod is located forward of the drive shaft, you'd "decrease" the length to increase the toe-in and vice versa.
So since your car went left when the wheel was straight, you would shorten the driver side tie rod and lengthen the passenger side tie rod...
[all the clockwise/counter-clockwise stuff was confusing since it all would depend on how you look at the tierod... ]
Old 05-15-2004, 10:39 PM   #5
Rev1
Member#: 51240
08 Lexus IS350
Well if you are crawling beneath the car (head first like I did)
Yup. That's about it. A couple of threads increase/decrease makes a difference. I first made a large adjustment (3-4 threads) and made the car pull to the right. I did that so that I knew the "magnitude" of the adjustment.
So then I corrected a couple more times, and I got it exactly dead on center.
Old 05-16-2004, 03:53 PM   #6
TexasForester
Member#: 59203
1999 Forester
Just to be clear I understand, your complaint before adjustment was the wheel was cocked but the car tracked true, if the wheel was not loaded by driver? If wheel was forced to correct position, the car tracked left.
I'm no alignment guru, but I thought I understood that to correct a drift required adjustment of camber.
I've frequently had the problem of cocked steering wheel, but lived w/ it unless I had a drift. I can stand a cocked wheel better than a drift.
The reason I wanted to be sure was I want to try to correct a slight drift right in my wife's 99 Subara Forester.
Regards
TexasForester is offline   Reply With Quote
Old 05-16-2004, 04:12 PM   #7
Rev1
Member#: 51240
08 Lexus IS350
Before the toe alignment, with the wheel in the center position, the car drifted left.
So on a perfectly straight road with no crown, I had to hold the steering wheel slightly (3-4 degrees approx) to the right, to make the car track straight.
I don't think camber adjustment will make a difference in drift when your car is tracking straight.
Old 05-16-2004, 06:01 PM   #8
Psydotek
Member#: 44168
2003 Yellow WRX
Just finished adjusting it on my car and finally the steering wheel is straight. (was more like 1 or 1/2 a degree for me, but enough to notice).
Now if i can just get rid of the toe out... Any tips on measuring it short of taking it to a shop?
Old 05-16-2004, 06:53 PM   #9
Rev1
Member#: 51240
08 Lexus IS350
It's not actually correcting toe if you adjusted both left and right tie rods equally, I think in this case the thrust angle will need to be corrected.
The last section of the front wheel alignment in the manual tells you how to correct thrust.
Old 05-18-2004, 10:09 PM   #10
Psydotek
Member#: 44168
2003 Yellow WRX
Well, looks like i'll be taking it to an alignment shop next week just to be sure. Steering wheel is straight and i've been tweeking it every day and keeping an eye on my tire wear to make sure the toe in/out isn't eating my tires.
It's a performance alignment shop but all the guys in the SCIC forum say he's the best. And for $85 (for the alignment and not per hour) it's cheaper than $150 at the dealer. I'll post up here when i get it done.
Old 05-18-2004, 11:00 PM   #11
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Kind of off topic: If you have the whiteline Anti-lift kit, do you need to mention that to the person doing the alignment because of the .5 degrees of negative castor?
MYfirst00 is offline   Reply With Quote
Old 05-23-2004, 02:41 PM   #12
Evets76
Member#: 62549
Is there a way to adjust the steering wheel itself? I just had an alignment done, the car goes straight but the wheel is cocked at least 10 degrees to the right. Very annoying.
Evets76 is offline   Reply With Quote
Old 05-23-2004, 04:14 PM   #13
Rev1
Member#: 51240
08 Lexus IS350
Just follow my tips above. My wheel was cocked 5* approx, and that corrected it.
Old 05-23-2004, 05:56 PM   #14
Hayes
Member#: 11808
If I paid for an alignment and the wheel was off center I'd take it back. That is the third thing a good alignment speciallist does after driving onto the rack and setting tire pressure. ed
Hayes is offline   Reply With Quote
Old 05-23-2004, 06:11 PM   #15
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
I got my car aligned, and the alignment sheet clearly indicated adjustments were correct, and the steering wheel centered.
Oddly though, at certain times, the sterring wheel is cocked to the left. I'm still having trouble deciding if it's because I'm running more negative camber in the front now, and I'm following the crown/camber of the road, or if it's really off.
At other times, it tracks perfectly fine.
heffergm is offline   Reply With Quote
Old 05-23-2004, 06:24 PM   #16
jlevy
Member#: 15696
2015 WRX 6 speed
Do you still have the stock rack bushings? If so, it sounds like memory steer.
-my 0.02
jlevy is offline   Reply With Quote
Old 05-24-2004, 06:55 PM   #17
Lever2ooo
Member#: 51708
**** your hippy
WOW I AM SO DOING THIS SOON!!!!! mine is cocked like 5 degrees right
Lever2ooo is offline   Reply With Quote
Old 05-24-2004, 06:57 PM   #18
Rev1
Member#: 51240
08 Lexus IS350
Let me know if it works for you or not.
Old 05-24-2004, 07:49 PM   #19
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
-my 0.02
Yes, still the stock bushings. How difficult are they to replace with the whiteline versions?
Old 05-24-2004, 09:34 PM   #20
jlevy
Member#: 15696
2015 WRX 6 speed
Default whiteline rack bushing install time
It's not the kind of thing you can do with one hand tied behind your back, but it's not really that bad. There are several different methods (bending the p/s lines, not bending them, etc). I chose not to bend the p/s lines and it took maybe 1 to 1.5 hours.
-JL
Steering wheel alignment problem subaru_terrence Brakes, Steering & Suspension 3 03-23-2008 01:54 AM
Steering Wheel Alignment (Need Help!) Tunaboy Brakes, Steering & Suspension 1 12-11-2006 10:56 AM
Power Steering Lines are here...no more fires.. CBRDSpeedfactory Engine/Power/Exhaust 5 08-06-2005 03:47 PM
steering wheel alignment atotten Interior & Exterior Modification 7 07-10-2005 07:46 PM
Subaru vehicles and Wheel Alignment issues wwso Tire & Wheel 28 02-26-2004 01:17 AM
