Old 05-15-2004, 09:46 PM   #1
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
Default OEM trailer hitch install, 02 WRX sedan
I wasn't quite sure where to put this, but hopefully a search will show it if someone is looking in the future.
Contrary to popular belief, the Subaru L1010SS00 Impreza hitch will in fact fit the 02 WRX sedan. All the parts sites list it for wagon body only, because only the 02 wagon has the pre-wired 6 pin conductor set up for the converter.
As an FYI, the hitch cannot be installed with the factory underspoiler on the car (the piece that is gray and looks like a diffuser). The mounting brackets interfere greatly. I'm holding out hope that a body shop may be able to cut/trim and make it work, but if not...oh well.
From a wiring perspective, I have one tiny question: in the main harness that services the tail lights, blue/red is said to be the 12v (battery) lead for the wagon. The sedan does not have this in the harness. Anyone know of a place I can tap other than the battery itself? Everything else was a snap.
Let me know if you have questions. If I need to, I'll just bust out the multimeter and go for it. I can take some pics if you want to see them.
Scott
sdecker is offline   Reply With Quote
Old 05-16-2004, 08:54 PM   #2
MRF582
Member#: 48219
. Always drive
the race line .
how much is this hitch? and will it fit an 04 you think?
MRF582 is offline   Reply With Quote
Old 05-17-2004, 08:02 AM   #3
sdecker
Member#: 14717
2002 WRX, WR Blue
The instructions I received had an addendum for 2004 Impreza, so I'd say that yes, it will fit. It will drop right in on a wagon, and from a mounting standpoint, it will fit the sedan, too. Electrically, the sedan will require you to splice some wires...possibly. I have heard that 03 and later cars all have the 6 pin connector in place, but can't confirm it. The 02 sedan certainly doesn't, which is my problem.
Bump for info on the 12v lead in the back of the car.
Scott
Old 05-17-2004, 08:29 AM   #4
avk
Member#: 17252
'06 WX8
59E
If the sedan has a trunk light, there should be an always-on wire for it in the rear harness. Maybe someone with a wiring diagram could confirm this.
avk is offline   Reply With Quote
Old 05-17-2004, 12:17 PM   #5
UGotBoost?
Member#: 45735
2002 Impreza WRX
I'm doing the same install (with a draw-tite hitch). I could really use a "how to" for finding all the correct lighting wires in the back.
Thanks in advance
UGotBoost? is offline   Reply With Quote
Old 05-17-2004, 12:24 PM   #6
sdecker
Member#: 14717
2002 WRX, WR Blue
Thanks in advance
This is what I used...
http://www.scoobymods.com/forums/arc...php/t-192.html
It's good for everything but the 12v lead...which I am working on.
The trunk light may be a possibility, assuming it's not switched...I'll meter it this afternoon and see.
Old 05-21-2004, 08:55 PM   #7
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
That hitch will work on a STi as well. I just installed mine. Don't cut the bumper you don't need too. FYI. And I am about to try to wire the harness in because the STi does not have the 6-pin connectors.
Just thought I'd let everybody know.
Thanks for the info,
Justin
crystalhelix is offline   Reply With Quote
Old 05-22-2004, 04:16 PM   #8
sdecker
Member#: 14717
2002 WRX, WR Blue
Rock on!
Old 05-22-2004, 08:17 PM   #9
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Everything works!! - The power and brakes of the STi make it feel like the trailer isn't even there. Don't cut your bumper. And you will have to wire up the relay box your self.
Good luck everybody,
Justin
Old 05-25-2004, 07:17 AM   #10
sdecker
Member#: 14717
2002 WRX, WR Blue
Justin
Justin, what did you use for 12v back there? Just wondering.
Thanks,
Scott
Old 05-25-2004, 07:55 AM   #11
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I had to run a power line from the battery.
The trunk light isn't constant and neither was anything else I found back there
But it wasn't so bad, I only removed the front door plastic.
Good luck,
Justin
Old 05-25-2004, 08:17 AM   #12
sdecker
Member#: 14717
2002 WRX, WR Blue
Good luck,
Justin
Arghhhhh
Oh well, not a big deal. It's not like I need to use 000 or anything.
Thanks!
Scott
Old 05-25-2004, 09:59 AM   #13
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I don't even know where you can get 000
Have fun,
Justin
Old 05-25-2004, 01:50 PM   #14
avk
Member#: 17252
'06 WX8
59E
Justin: do you mean the light doesn't come on if you open the trunk with ignition switch in the "off" position?
Old 05-25-2004, 02:44 PM   #15
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
If you wire to the trunk light and shut the trunk, it loses power regardless to the ignition. I tested it with meter and shut the trunk. Do you plan on towing with your trunk open?
Old 05-25-2004, 03:20 PM   #16
avk
Member#: 17252
'06 WX8
59E
If the switch is on the ground side, one of the wires at the light should always have 12V. If the switch is on the positive side, you get nothing at the light when it's off but then there should be 12V at the switch. I only said there should be 12V in the rear harness, not necessarily at the light.
Old 05-25-2004, 04:30 PM   #17
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
ahh, yeah but I was too layz-e
So Cal: Oem Trailer Hitch for 02-07 Impreza.....$100 local pickup only PartsDept Exterior/Styling 4 10-21-2007 10:24 PM
FXT DC-MD-VA area help with OEM Trailer Hitch Install? JDaltonRobertson Forester Forum 1 10-18-2005 09:38 AM
Subaru OEM Trailer Hitch Installation jmcomp124 Forester Forum 5 06-08-2004 07:09 AM
trailer hitch on '02 wrx sedan lettucemanatee Newbies & FAQs 1 03-18-2004 11:21 PM
does subaru sell a trailer hitch for the WRX sedan? Mr.Freeze Interior & Exterior Modification 1 05-28-2002 08:03 AM
