Old 05-16-2004, 12:30 AM   #1
RS25Tuner
Member#: 59920
2004 STI
Question Help With Boost Nanny!!!!CEL P1143: Any Ideas?
I installed the Boost Nanny mod this afternoon hoping to clear my “108 - Manifold Absolute Pressure/Barometric 11” CEL error code. (Click here for the mod-> http://wac.addr.com/auto/obs/boostnanny/boostnanny.html ) Imagine my surprise when I ended up with a new CEL when I was done! Here is the new CEL code I got this afternoon.
“P1143 manufacture control fuel air metering”
After installing the mod, the car hesitated and finally turned over on the second attempt. Within seconds the CEL popped on and I received the above CEL. When I remove the mod, the error message goes away. I am still left with my “108 - Manifold Absolute Pressure/Barometric 11” CEL error code. Anyone have any ideas of what it is I did wrong when installing this mod?
Any help with this problem would be much appreciated.
RS25Tuner is offline   Reply With Quote
Old 05-16-2004, 12:36 AM   #2
Aaron'sWRX
Member#: 34150
02 WRX
maf=fisted
Aaron'sWRX is offline   Reply With Quote
Old 05-16-2004, 12:42 AM   #3
RS25Tuner
Member#: 59920
2004 STI
maf=fisted???
Old 05-16-2004, 04:41 AM   #4
Unsung Boxer
Member#: 37196
boost nanny in wrong, let me guess, a 98?
-Jake
Unsung Boxer is offline   Reply With Quote
Old 05-16-2004, 06:45 PM   #5
RS25Tuner
Member#: 59920
2004 STI
Unsung Boxer - yeah a 98... Have you ever installed the Boost Nanny mod before and if so, do you have pictures so I can reference my install to yours?
Old 05-17-2004, 12:04 AM   #6
RS25Tuner
Member#: 59920
2004 STI
I used the following parts
http://www.partsamerica.com/PartDeta...rtnumber=47327
http://www.partsamerica.com/PartDeta...rtNumber=47149
From the pictures listed on the boost nanny site, can anyone confirm which way the Motormite 47149 Check-Valve is suppost to be oriented? The top of the Motormite 47149 check valve has Vacuum stamped at the top.
Old 05-18-2004, 12:00 AM   #7
RS25Tuner
Member#: 59920
2004 STI
Bump - Still no luck with the Boost Nanny. I have tried every way possible but no luck. I either pop a P1143 CEL or a P0106 CEL. Can someone tell me what I am doing wrong? Please PM me or post here.
Thanks!
04 STI CEL (P0223) any ideas why?? schmecky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-30-2007 02:36 AM
CEL P0461 any ideas? Vanagon_S Subaru Conversions 2 03-30-2004 03:30 PM
Got a CEL - any ideas? BeavisNuke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-12-2002 07:04 PM
CEL P0420 - any ideas wrxtremeWGN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-12-2002 06:00 PM
CEL PO447 & PO457...any ideas? bingo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-04-2002 10:08 AM
