#1 |
Member#: 59227
Vehicle:1998 Legacy GT Black w/ gold pearl |
Yes, I looked at the sticky. That thread on plugs got confusing to follow. So anyhow, with about 6 psi Will the NGK "7" be good? What is the part number for this plug? Thanks!
#2 |
Member#: 37196
NGK BKR6E-11's are stock
NGK BKR7E-11's are one step colder. using one step colder is similiar to retarding timing slightly, or using higher octane. It will make the spark plugs spark later. A by-product of this is that they will fould sooner. Expect to pay 1.00 to 1.50 @ NAPA for either of these plugs. They will tell u that the number is not right, but trust me, it is. |
#3 | |
Member#: 9436
Vehicle:05 Saab 9-5 Aero |
that's the funniest shizzle I've ever heard! colder spark plugs don't fire later, and hotter plugs don't fire sooner. Electricity travels through a conductor at the speed of light, no hotter or colder plug can modify that basic law of physics. A spark plug can in no way delay or speed up the spark timing, it can only stop the spark by going completely open circuit or shorting to ground = no spark = misfire.The difference between colder and hotter plugs is the amount of ceramic in contact with the metal shell. More ceramic in contact with the shell means more heat bleeds off into the cylinder head. This means the tip of the plug runs colder, and is less likely to get superheated enough to become it's own ignition source. Last edited by yamarocket630; 05-16-2004 at 10:13 AM. |
#4 |
Member#: 59227
Ok, so I want to get the NGK BKR7E-11. Thanks for the info!
#5 | |
Member#: 37196
But thanks anyways for trying to make an @$$ of me ![]() -Jake |
| Thread Tools | |
| Display Modes | |
| FS: Hella Super-Tones with custom bracket and plug-n-play harness | foureyedlameo | MWSOC Private Classifieds | 4 | 06-09-2010 10:36 PM |
| FS: Hella Super-Tones with custom bracket and plug-n-play harness | foureyedlameo | Exterior/Styling | 6 | 06-02-2010 06:38 AM |
| NEED: Plug/Clip that plugs into WRX spark plug coil | BeBop86 | Private 'Wanted' Classifieds | 16 | 07-16-2008 03:05 AM |
| Ignitions, spark plugs & plug wires? | scubaracer | Normally Aspirated Powertrain | 8 | 03-19-2002 04:17 AM |
| Sparg Plug wires and plug question | sparco | Normally Aspirated Powertrain | 4 | 02-13-2002 01:41 PM |
