Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-16-2004, 02:00 PM   #1
sideways slut
Member#: 21085
2.5 rs-t
Default stainless steel exhaust valves or oem
the machienest has my motor right now and it apears that ive ended up with 8 bent exhaust valves. so now i have the option of replacing them with oem or trying to find stainless steel ones, yes stainless steel are more resistant to heat and could possibly be lighter but are they really nessasary? im going to be pushing limits with this motor so this might be a good time to upgrade, but only if its something worth doing. also my mechanic thinks they bent from my high lift cam and not having the pistons machiened down enough to clear.
can someone direct me to somewhere that might carry these so i can price them out and check on availability...
thanx, jay
sideways slut is offline   Reply With Quote
Old 05-16-2004, 02:10 PM   #2
inpreza kid
Member#: 3334
oem valves are stainless. not sure if there is any aftermarket valves available for the SOHC head.
inpreza kid is offline   Reply With Quote
Old 05-16-2004, 02:13 PM   #3
sideways slut
Member#: 21085
2.5 rs-t
oh, thanx, i didnt know that. maybe ill just stick with oem, not to mention that i can get them shipped to me by tuesday.
Old 05-16-2004, 02:28 PM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
cobb makes them i believe but theyre 1g
Old 05-16-2004, 02:29 PM   #5
sideways slut
Member#: 21085
2.5 rs-t
compaired to??
Old 05-16-2004, 02:33 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
huh
Old 05-16-2004, 02:35 PM   #7
sideways slut
Member#: 21085
2.5 rs-t
and what are the stock?
Old 05-16-2004, 02:37 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
stainless?
Old 05-16-2004, 02:40 PM   #9
inpreza kid
Member#: 3334
here's the link to the cobb valves http://cobbtuning.com/impreza/enginehead3.html#valves
off the site
If you plan on running extremely high combustion temperatures, from turbo or nitrous, then upgrading the stock valves to our Extreme-Duty Valves will give you the protection you need against bent or warped valves.
Custom built from Nickelvac Super Alloy material, these valves are an exact replacement for the stock units to hold up to extreme heat of 1850 degrees F while maintaining light weight, high tensile strength and excellent resistence to thermal fatigue. These valves are the only suitable replacement weíve found for the high quality Stainless Steel valves Subaru uses in the stock cylinder heads. Donít be fooled by others trying to make an easy sell, there are lesser quality aftermarket stainless steel valves which donít compare to the quality of the stock valve Ė nor do they come with a hardened tip required for long life. (ask before you buy!)
For valve head diameter, we experimented with many different sizes in a quest to find higher flow rates, and ultimately found that the stock size makes the most sense. The higher weight from bigger valves could not offset the marginal flow improvements. Additionally, research in valve to seat angles and undercutting the valve with proper dimensions have shown significantly higher flow improvement without increase valve size and weight. These valves are not cheap, and we realize itís easier to sell an oversized valve. However, we offer real solutions, and the reality of it is that oversized valves are not necessary in these heads. Flow benches and dynos donít lie.
Old 05-16-2004, 02:47 PM   #10
sideways slut
Member#: 21085
2.5 rs-t
ya i just finished reading that.
sorry my bad, i didnt think you could possibly mean $1000 cause i can get the stock ones for $180
Old 05-16-2004, 02:56 PM   #11
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Old 05-16-2004, 02:59 PM   #12
sideways slut
Member#: 21085
2.5 rs-t
stock it is. maybe if my bank account had a couple more zeros on it id get cobb's
Old 05-16-2004, 03:09 PM   #13
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
word
SO CAL: Invida Full Stainless Steel Exhaust System legendr34 Private 'For Sale' Classifieds 7 02-03-2004 03:09 PM
Stainless Steel Exhaust Guard Handsdown Interior & Exterior Modification 6 03-06-2003 07:43 AM
I want a Stainless Steel Exhaust! lucien2 Legacy Forum 120 03-19-2002 08:36 AM
how do i make my stainless steel exhaust look new again? Keirik Interior & Exterior Modification 20 05-13-2001 11:53 AM
Stainless Steel Exhaust system jogilvie Canada Region Forum 0 09-30-2000 07:42 AM
