Old 05-16-2004, 09:46 PM   #1
ej25_pwr
Member#: 62013
Default limit of phase 2 SOHC spring/retainer?
i'm working on a budget built up right now. i was wondering what is the power limit of the stock valve springs/retainers before valve float occurs? it seems a lot of people upgrade to twe or cobb springs/titanium retainers. also are the stock retainers strong enough to hold upgraded springs or do i need to upgrade the retainers as well?
ej25_pwr is offline   Reply With Quote
Old 05-16-2004, 10:05 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I don't know of any vendors who sell springs without retainers, nad you are probably going to save like $50 by reusing retainers. The stock heads will start to float between 6500-7000rpms, and that is partly dependent on how much boost you are pushing as well...
Old 05-16-2004, 10:10 PM   #3
ej25_pwr
Member#: 62013
probably upwards of 10+psi on a sti block. techworks sells springs separate from the retainers.. not sure how well these springs will work with stock retainers.
Old 05-17-2004, 08:24 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
So,
YOU are spending $1400 of an STi block and then going to skip retainers? There are budget builds and then there are budget builds. I don't mean to flame, But just pay for the Ti retainers. Everything on the EJ25 heads is up to FI use except the spring and retainers...
Old 05-17-2004, 06:45 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yeah if they did separate them itd probably like 100 bucks, and for that kind of drop in mass on moving parts its worth it
Old 05-21-2004, 09:44 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
I'm currently looking into the feasability of using USDM STi spring/retainers on OEM DOHC 2.5 heads. I know you're looking for SOHC info, but I thought I'd throw this out as an option.
Stock retainers are beefy.....TWE springs should work fine with them, but they would likely be the ones to ask for detailed information.
Jay Storm
There's a fine line between "hobby" and "mental illness"......
ej25 DOHC to Phase 2 SOHC JDM Importers Subaru Conversions 4 04-11-2014 06:44 PM
Early SOHC intake manifold bolt to phase 2 SOHC heads?? Will ECU work with cam sensor ciper Normally Aspirated Powertrain 7 08-26-2008 05:35 PM
FS: Phase 2 SOHC EJ25 aspect VIC Private Classifieds 19 06-01-2007 02:03 AM
FS: Phase 2 SOHC EJ25 aspect Canada Region Private Classifieds 2 05-21-2007 01:26 PM
WTB: EJ25 Phase 2 SOHC Block BossGVR4 Private 'Wanted' Classifieds 3 08-02-2006 04:45 AM
