Old 05-16-2004, 09:57 PM   #1
Lordhowe
Member#: 35265
Default Ported and polished stock turbo
What are the main advantages of porting and polishing a stock 03 wrx turbo? What type of gain can i expect to get out of it? A few hundrad rpm faster spool or a few extra hp?
thx ahead of times.
Lordhowe is offline   Reply With Quote
Old 05-16-2004, 10:11 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
500 RPM (or so) quicker spool.
0 HP gain.
15ish torque gain down low.
Old 05-16-2004, 10:35 PM   #3
kitbar
Member#: 41411
2004 WRX Sedan
Java Black No Spoiler!
sounds lik ea good mod if you can do it yourself but if not, the cost is about 1/2 the way to a new vf22!
kitbar is offline   Reply With Quote
Old 05-16-2004, 10:36 PM   #4
electricpork
Member#: 9498
03 Bugeye
Junkyards are fun!
hey thanks master of FAQ. I was wondering too.
are there any distinct advantages of ball-bearing turboes over equivalent non-bb ones?
EDIT: OH WAIT. I just read the faq... nevermind.
electricpork is offline   Reply With Quote
Old 05-17-2004, 12:22 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I used a deadbolt P&P TD04 with a 'light clip' for almost a year and it was a great step up for the stock turbo.
The car felt like it had a small N/A V8 under the hood
If someone HAD to stay with the stock turbo, for whatever reason, this is what I'd do/have done....no doubt.
Old 05-17-2004, 03:52 AM   #6
Happy_Days
Member#: 35049
2013 Nissan GTR
Super Silver
As a person running cobb stage 2 would I need custom ecu tuning to take advantage of this P&P of the stock TD04?
Happy_Days is offline   Reply With Quote
Old 05-17-2004, 06:27 AM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
No. I asked Cobb myself about this and it will work fine.
Old 05-17-2004, 07:35 AM   #8
TheMadScientist
Member#: 23717
2005 Big red
I know someone that is having a hard time with a P&P VF34. I think he is kinda happy with it now. But it took ~1month of back and forth with logs and maps to get it right. This was with the AP.
TMS
TheMadScientist is offline   Reply With Quote
Old 05-17-2004, 08:16 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
TMS
I think way too many people "poo-poo" the P&P as a nothing mod on a turbo....different turbo's respond differently...some benifite a LOT from a P&P...some less so... in actuality it really can and does change the characteristics of the turbo quite a bit.
Old 05-17-2004, 04:45 PM   #10
Lordhowe
Member#: 35265
what are the risks of messing up if i were to port and polish it myself, from my understand, all p&p is you put the gasket on the flange and trim the metal so it is lined up with the gasket.
Old 05-17-2004, 06:43 PM   #11
pityr
Member#: 31719
You could cut too far and put a hole or a weak spot in the turbo's casing. I guess if you cut out the wrong shape you might cause the exhaust to flow worse than stock and hurt performance.
I did a mild port and polish on my stock turbo. Mostly all I did was take about 1mm of material off all the way around and the smoothed out all the rough spots. I also smoothed the WG port. I would have taken more off but I only had a dremel with the regular grinding stones. If I had a carbide bit I might have take more off.
I noticed some small gains in spoolup after doing this. Also for some reason the EGTs seem to be alittle lower. I dont know if the p&p was the cause of that though.
pityr is offline   Reply With Quote
Old 05-17-2004, 07:07 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
That is NOT a P&P....by any means...that is more of a 'port matching'....see deadbolts website and you can see some of what he does to the exhaust housing. It is an extensive milling of the turbine outlet and the wastegate port as well as some machining of the inlet.
Old 05-17-2004, 09:37 PM   #13
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
Link to Deadbolt site please
cky211 is offline   Reply With Quote
Old 05-17-2004, 09:46 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
You have got to be kidding??!!!??
You have been on this board for HOW LONG and you can't find it in under 20 seconds??!!??
UNBELIEVABLE.
FULL STOP.
http://deadboltspeed.com/indexmain.htm
Old 05-17-2004, 10:01 PM   #15
cky211
Member#: 31129
02 WRX MPB
Thanks for your help Uncle Scotty
Old 05-17-2004, 10:09 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
N/P
Old 05-17-2004, 10:20 PM   #17
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
You can get a VF22 for $400? What about injectors and fuel pump?
I can ship my turbo to deadbolt and get a P&P for $200
I am not trying to be obnoxious, it's just that everyone seems to overstate the cost of the P&P. It could cost more but doesn't have to.
HerculesPeanut is offline   Reply With Quote
Old 05-18-2004, 01:18 AM   #18
pityr
Member#: 31719
Its because $200 is alot to spend for the gains that you get. For another $200 you can get a reflash that will have produce much more power than a ported stock turbo will.
Then again if you have a reflash and other mods and you dont want to fully upgrade the turbo then this is probably your next step.
WTB port and polished stock turbo *please move to WTB forum" Jason Temple NESIC Private Classifieds 0 01-18-2006 01:14 PM
Ported and polished stock turbo SubWRX2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-26-2005 03:11 PM
Port and Polish Stock Turbo AK SloPok Alaskan Impreza Club Forum -- AKIC 3 03-17-2005 08:40 PM
port and polish stock turbo? louis53123 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-06-2004 05:52 PM
Port and Polishing my Turbo... where??? Oo DaRk StAr oO Southern California Impreza Club Forum -- SCIC 3 04-28-2003 06:03 PM
