Old 05-17-2004, 12:05 PM   #1
cowlypso
Member#: 61786
Question idle and no cel
I GET A CHECK ENGINE LIGHT ON MY 93 LOYALE. STILL TRYING TO FIGURE OUT FLASH CODE. MY QUESTION IS THAT I COULD LET IT IDLE AT STATRTUP FOREVER AND CEL WON'T COME ON. WHEN I BEGIN TO MOVE AND PUT IT IN GEAR IT ALWAYS COMES ON IN A ABOUT FIVE MINUTES. I WONDER IF NO LIGHT AT IDLE IS A CLUE TO WHATS WRONG. ANY IDEAS? THANKS
cowlypso is offline   Reply With Quote
Old 05-17-2004, 01:13 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
First- please don't type in all caps, it's very distracting and against the forum rules.
As for your problem, you need to follow the procedure for reading the code through flashing of the check engine light. I know it's been posted on here and if you have access to a service manual it's in there as well. You could try searching for threads on this subject although you may have to dig around a bit, pulling CEL codes on older cars isn't discussed nearly as frequently as on more recent OBDII ones.
Perhaps someone with the needed info will read this and post it.
Other than that any speculation as to the cause is pointless, as there are too many different things that can set a code and turn the light on.
Newly assembled hybrid with cranking and no start and no CEL, suggestions? 240sxguy Built Motor Discussion 7 08-20-2012 10:00 PM
04' STi idle issue, no CEL downshift1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 03-18-2008 01:15 PM
CEL Flashing P0301 Rough Idle and NO Power WRXerist Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 02-05-2008 11:33 PM
Gutted stock UP install, no EGT and no CEL??? klie5111 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-18-2005 10:04 AM
Rough idle, but no CEL dan_j_b Normally Aspirated Powertrain 18 04-24-2005 12:45 PM
