Old 05-17-2004, 08:30 PM   #1
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Angry Fuel Pump Dead??? PLEASE HELP!!!!
OK... I already did searches on key words: fuel-pump-fuse-relay-etc... I checked all SBFs and they're good; checked under the driver's side dash but could find the supposed 3 relays/fuses.
There's no humming sound coming from the Walbro pump. Fuel pressure is 0 at the fuel gauge.
Could it be that the pump (2 years old) is DEAD???
I am FREAKIN' OUT...
PLEASE HELP!!!
saludos
Mariano
Mariano is offline   Reply With Quote
Old 05-17-2004, 10:07 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
You have been around long enough to know the rules....
http://www.nasioc.com/Default.cfm?Action=Rules
kastle is offline   Reply With Quote
Old 05-18-2004, 01:40 AM   #3
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
I really dont get it?
What's wrong with this post?
Old 05-18-2004, 10:57 AM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Your title. I edited it.
Old 05-18-2004, 11:05 AM   #5
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Talking
Sorry! My bad...
...Now can anyone help me! Bueller, Bueller, Bueller.
Mariano
Old 05-18-2004, 12:36 PM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
This is easy to test. Pull the fuel line of the fuel rail and stock it in a bottle. Turn the key to on and the pump should prime- see if you get gas in the bottle. If you do then the pump is working if you dont then the pump is dead. Next check the electrical connections back by the pump.
Drac9 is offline   Reply With Quote
Old 05-18-2004, 01:58 PM   #7
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Angry UPDATE
I pulled out the fuel pump from the tank. Took off the pump from the fuel delivering system and checked it; IT WORKS.
I figure that the problem is not in the back... somewhere between a blown fuse/relay (which I can't find) and a broken wire?
Guys come on I know a couple of you had this same problem. Please give me some BRIGTHER LIGHT on this matter... Any other specific posibilities...
saludos,
Mariano
Old 05-18-2004, 07:08 PM   #8
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Angry Afternoon UPDATE
Found two round relays close to the inside fuse box, which according to the "service manual", these are the fuel pump relay(s). One with a pink connector and one with a light blue connector. Changed them with brand new ones and..... NOPE! no humming sound from the pump...
I even got an amp/volt meter and I found something unusual. The plug/connector of the fuel pump has 6 pins. Power was being delivered to only two, which in theory are 3 positives and 3 negatives. So only one set has power; the gas gauge. When unplugged the gas gauge goes empty; plugged 3/4 tank where it should be.
I think I'm starting to loose my mind & patience...
Could SOMEONE PLEASE solve the mystery....
Mariano
Old 05-19-2004, 11:28 AM   #9
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
try connecting your stock pump to see if it works
Elliot
Elliot is offline   Reply With Quote
Old 05-25-2004, 09:21 PM   #10
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Talking
FIXED!
Details? ... A BROKEN WIRE!!!
Old 05-25-2004, 11:26 PM   #11
Aphex
Member#: 146
'16 WRX Limited
DOH! where was the wire broken at? and any theories as to how it was broken?
Aphex is online now   Reply With Quote
Old 09-23-2005, 10:43 PM   #12
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
Help, I have this problem now - can't find a bad fuse - 2003 WRX. Which wire was broken?
AntiochCali is offline   Reply With Quote
Old 09-26-2005, 11:35 AM   #13
AntiochCali
Member#: 30185
2003 320 whp
Okay, the problem was the ground bolt on the engine was loose...ugh, this took forever to find, but it's really important.
Question on fuel pump wiring. Please help! RicerJim Mid Atlantic Impreza Club -- MAIC 12 04-12-2004 11:58 AM
Fuel Pump Dead? JaMa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-17-2002 04:09 PM
fuel pump dead, ***? i'm dying here jsmonet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-02-2002 06:43 PM
fuel pump dead, ***? jsmonet Southern California Impreza Club Forum -- SCIC 5 03-02-2002 02:52 PM
my wrx is dead please help credit xtc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 50 05-24-2001 05:40 AM
