Old 05-17-2004, 09:20 PM   #1
thunder3dan
Member#: 62157
Default WRX making Wierd Whining sound in 5th gear
Hello,
I have 2004 WRX. At 60 mph in 5th gear it makes a fairly load whining sound. It usually occurs when I'm just barely pressing the gas. When I accelerate it goes a way. Is this normal?
Thanks for you help,
Dan
thunder3dan is offline   Reply With Quote
Old 05-17-2004, 09:24 PM   #2
I_say
Member#: 55122
its probably your turbo your hearing....is it like a woooooooooooosh ...cuz thats your turbo you should hear it especially in lower rpms when its not spinning to fast for human ears
I_say is offline   Reply With Quote
Old 05-17-2004, 09:29 PM   #3
thunder3dan
Member#: 62157
I don't believe it's the turbo. You can hear the turbo working under hard accelerations. This more like a whinnning..... It goes away when you press the gas but comes back when you let off. And it only happens around 60 mph and goes away at 65 mph and above.
Old 05-17-2004, 09:37 PM   #4
I_say
Member#: 55122
do you mean let off the gas completely or just a little....really i have no idea, i jsut think this peice of info could help people figure it out..
Old 05-17-2004, 09:57 PM   #5
thunder3dan
Member#: 62157
when I let off a little not completely.....
Old 05-17-2004, 11:14 PM   #6
Guru Imakuni
Member#: 58773
Does it do it in other gears too and has it always done this or has it just started to?
Guru Imakuni is offline   Reply With Quote
Old 05-18-2004, 12:06 AM   #7
thunder3dan
Member#: 62157
It's always done it.. only noticeable in 5th gear
Old 05-18-2004, 01:54 AM   #8
Lee Chun
Member#: 32639
Do you notice it more when your AC is on?
I hear something like what you're describing when I'm on the freeway with the AC on.
Lee Chun is offline   Reply With Quote
Old 05-18-2004, 03:06 AM   #9
QwikRex
Member#: 40284
2007 370z sport 6MT
Magnetic Black
I have the same whine around 60mph cruising. Sounds like driveline resonance or something.
QwikRex is offline   Reply With Quote
Old 05-18-2004, 12:39 PM   #10
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
Check your tire pressure, make sure it is up to spec on all 4 wheels according to the sticker on the door jamb. If any of the tires have a different rolling diameter (and inflation is just one thing that can cause this) the diffs will be trying to compensate (as though there were slip) and you may hear some whining.
Craig
c_hunter is offline   Reply With Quote
Old 05-19-2004, 10:07 AM   #11
TheJonesBoy
Member#: 55779
2004 WRX Wagon
WR Blue
Final drive whine sounds anywhere between a high pitched whirr or wheeee, and it changes with speed/engine load. Turbos usually sound even higher pitched, closer to a canister vacuum and it follows boost pressure. I don't think viscous coupling LSD units make noise while slipping, but that can be ruled out by measuring tire circumfrence (they should be within roughly a centimeter or 2, IIRC)
What you are describing sounds like a typical final drive whine. If the ring and pinion gears are not lined up perfectly (both up/down and front/back), they make noise. When you accelerate, you are stressing these components which changes their interference angle slightly, and the noise goes away. I dunno about subaru, but several other manufacturers have allignment marks and shims that have to be installed/alligned to prevent this.
The good part is, it doesn't do any damage. The bad part is, I doubt you will get it fixed under waranty.
Try changing your front diff oil, or your rear diff oil as these cars have 2 of these gears. This usually does the trick on higher mileage cars.
TheJonesBoy is offline   Reply With Quote
Car started making wierd rumble sound *video Rayme Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-06-2008 11:42 AM
Whining sound from 1st gear? Hyper Transmission (AT/MT) & Driveline 0 02-25-2007 04:03 AM
EJ22 making wierd ringing sound after timing belt swap Subiverted Normally Aspirated Powertrain 2 04-29-2006 12:26 AM
WRX RPM at 75-80mph in 5th gear??? e28fixer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 09-04-2004 09:03 AM
more n00bness OR my car makes a whining sound! mr_yellow Normally Aspirated Powertrain 12 09-15-2003 07:27 PM
