Old 05-18-2004, 10:19 AM   #1
Tats
Member#: 5692
WTF? YES! I am
better than you!
Default 1st auto-x on so'3's...question...
What tire pressures do you guys reccomond to start with?
Car: 2001 RS-T Coupe
24mm rear bar.
Eibach prokit w/ agx's.
215/45/17 PP so-3's.
Any one??
Tats.
Tats is offline   Reply With Quote
Old 05-18-2004, 10:24 AM   #2
Midnight_Gold
Member#: 37599
Comm ando Brigade..
Bring it isshes!
I always put 60-65 in the rear and 50-55 in the front.. but that's on my STi... you could probably get away with something close to that..
S-03's roll like a sonoffab****
That, and you get a little better rotation...
- Miranda (the backwards S-03 Queen)
Midnight_Gold is offline   Reply With Quote
Old 05-18-2004, 10:27 AM   #3
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
OK - I am certainly NO expert on this matter WHATSOEVER, but *MY* opinion is that the S03 sidewalls are pretty damned stiff, so I actually run like 40/36. Just my opinion, of course!
CirrusWRX is offline   Reply With Quote
Old 05-18-2004, 10:40 AM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
When I ran S-03s on my car I ran them at 50F and like 48R. They are much grippier tires once they are almost completely worn out.
Old 05-18-2004, 10:55 AM   #5
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Rollover depends on few things:
A) Sidewall height (40 series, 45 series, etc)
B) Camber on the car
C) Air pressure
A is fixed for whatever tire you have on the car, leaving B and C to be adjusted. In stock classes, you can't get enough of B so you use C to compensate. B is preferrable to adjust first, then use C for fine-tuning.
Edit: You're also trying to balance rollover with maximum grip and even wear.
DrBiggly is offline   Reply With Quote
Old 05-18-2004, 01:17 PM   #6
Tats
Member#: 5692
WTF? YES! I am
better than you!
Thanks for the input.
I know my RE-92's liked a lot of air. My RE-950's liked a lot less air.
I guess I'll start 46F and 42R and see where I go from there.
Like I said...my rear bar is 24mm and I have some adjustability with the AGX's so getting the car to rotate should not be an issue.
Old 05-18-2004, 02:04 PM   #7
thechickencow
Member#: 16840
14 Outback
True.
thechickencow is offline   Reply With Quote
Old 05-18-2004, 02:09 PM   #8
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Usually what I do is start out with too much pressure and just bleed it off as necessary. This will give me higher grip on later runs and save some of the edges (less rollover) on my initial runs where I'm not as likely to be at my maximum speed for the course.
1st auto-x on new suspension... lettucemanatee Brakes, Steering & Suspension 30 10-11-2005 11:21 AM
1st Auto-X on new set-up Georgethefierce Brakes, Steering & Suspension 3 07-28-2004 05:41 PM
auto-x on saturday question p7r4e7y Texas Impreza Club Forum -- TXIC 4 06-24-2002 03:59 PM
NE1 got room for 2 guys to camp for Oct 1st Auto-X?? omahasubaru Mid West Subaru Owners Club Forum -- MWSOC 6 09-25-2000 04:04 PM
Auto-X on RE92's Questions! Dan00RS Technical Forum Archive 19 05-18-2000 06:47 AM
