![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 38932
Vehicle:2003 WRX WRB - Cobb Stg2 |
Hello,
I've had my 03 WRX for about a year now (15k miles) and I am about to attend my first track event. I have not done much to my suspension: lowered on eibach, subzeros w/ yoko avs es100's. My main concern will be my brakes. I will be going to Willow Springs, CA and riding Big Willow which is a considerably 'fast' track. I actually want to know if I'd be ok using my stock brake pads for this event, mainly because I don't want to put a lot of money into this event and find out that I won't be doing another one any time soon. I would like to try it first before I invest. With that said, do you feel that I will be fine stock or would it be in my interest to spend some money on some brakes before the event? The event will be an all day event w/ 20 minute sessions, so I imagine my brakes will eventually fade. I just want to know how well the stock brakes will hold up. If I do enjoy the event, which I'm sure I will, I'll be looking to upgrade for sure. Any advice will be greatly appreciated. Thanks.
#2 |
Member#: 7492
South East
Vehicle:No race cars www.tomhoppe.com |
You will NOT be ok with stock brakes. Not even CLOSE. Your fluid will boil and your pads will dangerously fade.
Please invest in some quality brake fluid such as ATE Super Blue or the Motul 600 and go with some real pads. Carbotech Panther Plus would be an excellent choice for a street tire shod car on track. -Tom |
#3 |
Member#: 36117
Vehicle:2003 WRX Wagon WRB |
If it's your first track event, I really don't think you'll need aftermarket pads. Just make sure you have enough pad material left on the stock pads to last the entire day. The main thing I'd recommend is for you to replace your brake fluid with some fresh fluid.
#4 |
Member#: 24472
Vehicle:2001 Miata White |
Tom's right.
I did my first track event on OEM pads. They were overheated after two turns on the first hot lap in the first session. Had to run the rest of the event very conservatively, which doesn't help much with learning. A set of pads will set you back about 100 bucks and a litre of ATE DOT4 should be around 10 bucks. With experienced help, you can change the pads and flush the fluid in about an hour. It's well worth the effort and cost. Also make sure you follow the bedding procedures for the pads. Again, takes another half hour but well worth the time. You can switch back to the OEM pads after the event and put the track pads on a shelf until the next time. I highly recommend going with full race pads. The street/track compromise pads can cost about the same and aren't nearly as good. |
#5 |
Member#: 38932
Thanks for the advice so far. I think I'd be better off investing in some pads rather than 'test' the stock pads and find out they'll be done after a lap.
So are the Carbotech panther+ a track pad or is it a street/track pad? I don't know if I want a strictly track pad or a stree/track pad due to the fact that I'm unsure how often I'll be going to the track. |
#6 |
Member#: 24472
Panther+ is what I'm using.
It will work on the street but it's noisy has hell. I previously used Hawk HP+ but the Panther+ has been much better. In fact, I experienced some fade with the Hawks but I never maxed out the Panthers. I only had one track event with the Panthers last November at VIR. I have one coming this Friday at Summit Point so I'll have a better basis for comparison, since that's where I've done all of my other events. |
#7 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
#1.) brake fluid is a must ..... ATE Super Blue or Motul 600 or something else with a wet boiling point about 450 degrees
#2.) pads ..... Hawk HPS is a street pad that can perform adequately on the track or even better the HP Plus pads which are more of a "track friction material" and less streetable. A true track pad would be a little over kill for your situation |
#8 |
Member#: 7492
South East
The carbotech panther + is a light track/driver ed pad.
The carbotech bobcat is a street/autox pad that will go up to 900 degrees before fade. After thinking about it, the bobcat along with ATE Super Blue fluid would be perfect for your first track experience. Then if you decided you want to go on track more, you can get the panther + dedicated track pad and still use the bobcats on the street. The AWESOME thing about carbotech brakes that other companies don't offer is the ability to switch between their track and street compounds w/o taking the old pad material off the rotors. With other companies you need to either have the rotor resurfaced or sand off the old pad material. Did I mention that I used 1 set of rotors with 5 different sets of carbotech pads? I autoxed and street drove through a set of bobcats, then I went through two sets of panther XPs testing and running One Lap, then I tried the Panther + pad (which was a little overkill for autox), and went back to a new set of bobcats. All on my original 56K mile rotors. -Tom Carbotech RULES |
#9 | |
Member#: 24472
maybe that's why my OEM pads took so long to bed in after switching back from the Panthers. |
#10 | |
Member#: 32018
SCIC
Vehicle:2008 M3 Sedan Interlagos Blue |
I am currently in the process of upgrading to stage 2 cobb and plan to track my wrx. I have stock brakes so I was worried I might need to upgrade to BBK, hoping pads and new fluid is enough. thanks |
#11 |
Member#: 7492
South East
I had a full vishnu stage 1 with full boost mods when I did one lap. Right now I have ecutek w/o any boost changes. I estimate I was at 300 crank and now I'm at 275-280 crank.
If you have that much more power, the Panther XP will be the pad for you. You will destroy wheel bearings and cook CV joints before those pads fade on you ![]() If you will be doing a LOT of track events and driving hard, I would recommend some type of bigger rotor+caliper to dissapate the heat (carbotech pads still of course), but if you will do 4 or 5 a year, IMHO the stock brakes with XP pads, ATE Super Blue fluid, and brake dust shields removed will work great. It also wouldn't hurt to remove your foglights and run a very simple brake duct such as this thread http://forums.nasioc.com/forums/show...ght=brake+duct Granted we did not do a lot of laps at one time during one lap, but I did 4 20 minute sessions and 1 40 minute session at CMP (VERY hard on brakes) while testing with no brake fade. -Tom |
#12 | |
Member#: 32018
SCIC
#13 |
Member#: 43010
Vehicle:1974 2002tii silver |
I got to agree with Tom on this the Carbotech bobcats are some of the best pads I have ever used. They are very versatile and the only set of street pads I've had that I feel comfortable using on a track.
#14 |
Member#: 38932
So, now I'm kind of leaning towards getting the Carbotech Bobcats rather than the Panther+ due to the fact that I will probably only do maybe 2 track events a year... unless I'm addicted but even then work would probably limit it to 3-4 at most.
I think I'll try the Bobcats for this event and if I still feel like I need more braking power I'll get the Panther xp and just swap back and forth for track days. While I'm at it, should I go ahead and upgrade my brake lines to SS? Seems fairly logical to do, and not too expensive. After searching a bit I found that Suby Dude has a pretty decent package available. Approx $315 for front&rear carbotech pads and front/rear SS goodridge brake lines. I don't think I'll need rotors yet... pads, ss lines, and fluid seem like an adequate combo right now. |
| Thread Tools | |
| Display Modes | |
| Upcoming Car Show - Need Advice | DNA Motoring | Car Care & Detailing | 13 | 04-13-2010 06:45 PM |
| Upcoming Track Events | ewaher | Southern California Impreza Club Forum -- SCIC | 0 | 09-10-2008 04:45 PM |
| Auto-x / Track guys - need advice | JM530 | Mid West Subaru Owners Club Forum -- MWSOC | 6 | 10-17-2006 10:40 AM |
| Tire advice needed for track event... | 03WREX | Tire & Wheel | 2 | 05-24-2004 09:30 PM |
| Upcoming Track events (Not racing, unless you want to) | mhoward1 | South East Region Forum | 2 | 07-16-2003 09:35 AM |
