Old 05-18-2004, 12:33 PM   #1
V8VENOM
Member#: 42612
Default STI over 145 mph??
I'm probably gonna run Fontana next year and having run there before in my old race car I know I can easily hit speeds over 150 mph. So, I need to know:
1. Why is the STI speed limited to 145 (about)? Hood scoop issue?
2. Without doing a custom chip burn can the speed limiter be fooled or disabled some other way?
Thanks, Rob.
V8VENOM is offline   Reply With Quote
Old 05-18-2004, 12:54 PM   #2
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
i thought it was limited to 145 because of its 'brick' style aerodynamics.
Achilles38WRX is offline   Reply With Quote
Old 05-18-2004, 01:27 PM   #3
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
At least it is slicker than the 02-03 'tissue box' aerodynamics.
Capt Crunch is offline   Reply With Quote
Old 05-18-2004, 01:37 PM   #4
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
nope its electronically limited.
Somthing was mentioned about the tranny overheating above 145mph awhile ago, but havent seen anything to confirm if thats true or the reason for the limit.
afpdl is offline   Reply With Quote
Old 05-18-2004, 01:50 PM   #5
KoneKiller
Member#: 39191
2004 WRX STi WRB
Red 1990 Spec Miata
Maybe the lawyers overheat at 145?
I'd be worried about lift, personally. The wing probably does a good deal for the rear, but what keeps the front on the ground?
KoneKiller is offline   Reply With Quote
Old 05-18-2004, 02:03 PM   #6
makofoto
Member#: 25243
2006 Legacy Outback
That what I thought those mini stubby front "spoiler" things were for ... I need to check out my latest German car magazine with their big STI Nurburgring test ... included a wind tunnel/smoke photo showing how the wings/aero's work ...
makofoto is offline   Reply With Quote
Old 05-18-2004, 02:19 PM   #7
wistful
Member#: 745
2004 STi
Java Black Pearl
that's why I bought me a V-limited front spoiler.
for the record though, its NOT due to aerodynamics. the car pulls hard all the way to the limiter. not.. that.. you know.. I know or anything.
Don
wistful is offline   Reply With Quote
Old 05-18-2004, 04:01 PM   #8
10th Warrior
Member#: 2230
2000 2.5RS
Silverthorn, PGT #671
what's the gearing good for?
10th Warrior is offline   Reply With Quote
Old 05-18-2004, 04:02 PM   #9
jmott
Member#: 6713
2007 Prius
brown
multiplying torque
jmott is offline   Reply With Quote
Old 05-18-2004, 04:06 PM   #10
Prestige Motorsports
Member#: 13158
2002 Impreza WRX
Sedona Red
I have a customer who bought his STI, lightly modded it, then drove across the US in it. He called me from Texas raving about the stability of the car at over 150 mph. His Speedometer stopped going up at 158...his GPS tracked him at 156.8.
This is the only instance I personally know of where an STI owner has tried to find a speed limiter, but his car was equipped with a turbo back exhaust, a manual boost controller, and a panel filter.
Again, he raved about how the STI was more stable over 140 than his WRX was at 120.
Kent
Prestige Motorsports is offline   Reply With Quote
Old 05-18-2004, 05:11 PM   #11
V8VENOM
Member#: 42612
So nobody really knows? Dang!
Tranny overheating -- doesn't make sense to me -- plus why have a rear differential temp sensor if the tranny is the "hot spot".
V-limited front spoiler -- do you have any pics of this unit and exactly how it is connected to the car's frame and/or subframe? I'm a little dubious on the functionality of all the "aftermarket" kits I've seen so far -- aimed more at looks rather than real durable functionality. I like Gary S. custom front splitter, but that is apparently pretty heavy. A front splitter will certainly slow the car down (if it is really doing it's job) -- but I agree, it certainly is NOT the reason for holding at 145.
158+ hmmm... sure this person didn't have a custom chip burn? Anyone else have actual experience with their STI over 145?
Guess I'll just have to see what happens -- just very worried about my scoop/hood coming off.
Old 05-18-2004, 06:45 PM   #12
wistful
Member#: 745
2004 STi
Java Black Pearl
I don't have pix of its applicatino on MY car, but there's tons of pics floating around. just search in the member's gallery. SUPPOSEDLY, when combined with all the other aero equip on the car, it reduces the front end lift to exactly 0. Hey, its STi. Besides, it looks soo damn good.
Don
Old 05-18-2004, 09:00 PM   #13
mofugga
Member#: 19540
2000 old skool RS
BRP
i thought they were limited to 155?
mofugga is offline   Reply With Quote
Old 05-18-2004, 09:07 PM   #14
proliar
Member#: 55577
I have had a customer take his to 150+mph and he said he still had more power to go....he is a gear head and his partner that night vouches for it. so I, as a salesman, wish I had something to show a customer on "Top Speed"
Thanks Shawn
proliar is offline   Reply With Quote
Old 05-18-2004, 10:03 PM   #15
makofoto
Member#: 25243
2006 Legacy Outback
The current issue of the german magazine Sport Auto has a test on the STI. It said that the top speed is "boost limited @ 6,200 RPM in Sixth gear in order to protect the gearbox from high operating temperature." Redline is 7,500 except in 6th ... Supposedly the Euro STI has a longer final ratio ... 3.55 ... then the US model? Top speed is limited to 152 mph - in order to protect the gearbox.
The rear wing is apparently so effective that it produces lift in the front by pushing the rear down (too) hard.
Old 05-18-2004, 10:56 PM   #16
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The limiter is at 147 (150+ indicated).
It isn't anything to do with the gearbox or aerodynamics.
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 05-19-2004, 02:14 AM   #17
V8VENOM
Member#: 42612
Glenn,
Can you tell me what it IS rather than what it isn't -- I feel like I have to guess Door A, Door B, Door C
By process of elimination I down to:
1. Tires (not a concern since I don't use stock tires at the track)
2. Wheel bearings (big concern)
3. Motor can't handle extended durations at high boost
4. Scoop/intercooler produces excessive air cooling and exceeds operational parameters of the ECU?
5. Legal BS -- 147 was deemed "safer" than 165+ (but I'm not aware of any standards that require crash testing at those speeds)
6. Very bad drivetrain harmonics above that speed
I was going to suggest front glass also, but that is very much part of the car's aerodynamics.
Rob.
Old 05-19-2004, 05:26 AM   #18
RallyCSX
Member#: 4281
2010 2.5i, 2000 STI,
Ae86, CSX Rally Car
Hit 150 on my speedo
closed course of course
RallyCSX is offline   Reply With Quote
Old 05-19-2004, 07:52 AM   #19
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
145 definitely seems to be artificial and arbitrary. I have taken my lightly modded WRX up to 138 many times on the back straight at Road Atlanta. I could easily exceed that, given more room. I've had no issues at all with either the factory hood scoop or the STI replacement. There are quite a lot of fasteners and brackets holding that thing down.
Wish I could give you the specifics on the STI...sorry. Why don't you bring it down to Road Atlanta and let's test it out?
Scott
sdecker is offline   Reply With Quote
Old 05-19-2004, 10:21 AM   #20
kfoote
Member#: 39180
2004 WRB STi
Slash Ten - FBHIC
Originally posted by V8VENOM
...5. Legal BS -- 147 was deemed "safer" than 165+ (but I'm not aware of any standards that require crash testing at those speeds)...
I think this is the real answer. There are many cars that arificially limit top speed for various reasons. 147 MPH translates to almost exactly 225 kph, which makes sense for an arbitrarily chosen top speed.
kfoote is offline   Reply With Quote
Old 05-19-2004, 11:14 AM   #21
makofoto
Member#: 25243
2006 Legacy Outback
In Germany ... where some of the cars ARE artificially top speed governed ... the magazine specifically pointed out that their STI was not restricted for "political" reasons ... but instead for "very practical reasons," ie. to avoid gearbox overheating. Don't forget that in Germany you can CRUISE at VERY high speeds. I remember my 1802 BMW (1971!) manual said that it's red line was 6,200 ... but for extended cruising, do not go above 6,000.
Old 05-19-2004, 11:40 AM   #22
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Hit 150 on my speedo. Closed course of course
... on your way down to pick up a clutch slave cylinder and some bolts...
Fitz
Fitz is offline   Reply With Quote
Old 05-19-2004, 08:19 PM   #23
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Glenn,
Rob.
You are getting warm with 2 & 6. To repeat I am not sure if the issue remains on the 05.
Old 05-19-2004, 10:37 PM   #24
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
I've had my measely 2001 RS close to 130.. wish i had my GPS at the time to confirm it. This was at about 5500-5700 RPMs
And you think the 02-03 was tissue shaped..
trojan9x is offline   Reply With Quote
Old 05-19-2004, 10:44 PM   #25
kennethw
Member#: 48812
I run a bugeye Euro STi and have brought it up to 250km/h or 150mph, car still has power to pull, but I don't have to balls to go any faster.
With regards to the gearbox, we usually cruise around 200km/h for about an hour along the highway and the gearbox seems to be cooler than driving in the city.
For front downforce, I have the C-West lower air damper which seems to work great.
kennethw is offline   Reply With Quote
STI Drive by at 145 MPH MrTransAm Off-Topic 71 02-08-2005 08:18 AM
STI Drive by at 145 MPH MrTransAm Mid Atlantic Impreza Club -- MAIC 25 02-08-2005 07:49 AM
STI Drive By at 145 MPH MrTransAm Off-Topic 12 02-07-2005 12:53 PM
STI Drive by at 145 MPH MrTransAm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 02-07-2005 09:11 AM
Oops. 145 mph in a 65 mph zone. Jon [in CT] Off-Topic 50 01-05-2005 04:36 AM
