Old 05-18-2004, 06:04 PM   #1
Horten
Member#: 19790
Default when does your gas light come on?
I've noticed that my gas light comes on just under 1/4 of a tank every time I'm that low. This happens when I drive til about 1/4 tank then turn the car off, the next time I start it up, the gas light will be on. on the other hand, if I'm driving a long distance and I drop past 1/4 tank it won't come on until its closer to the bottom line.
This has been the case since I've owned my car (02 wrx). I don't see it as a big deal, but it makes me nervous when the light is on so I fill it up soon after. I usually put about 11-13 gallons in when the light is on. I think it's a 16 gallon tank though.
Is this weird, or pretty normal?
thanks for any replies
Horten is offline   Reply With Quote
Old 05-18-2004, 06:06 PM   #2
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Das ist weird
J
thrasher is offline   Reply With Quote
Old 05-18-2004, 06:14 PM   #3
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Default Re: when does your gas light come on?
Is it parked on a downgrade?
satrya is offline   Reply With Quote
Old 05-18-2004, 06:22 PM   #4
Horten
Member#: 19790
no. i considered that but its usually flat.
i forgot to mention...my gas needle doesnt move until i have about 60 or so miles on a full tank
Old 05-18-2004, 06:44 PM   #5
fliz
Member#: 30342
Mine stays up like that too.
Sucks...150 miles for the first quarter, 70 for the second.
My gas light comes on at between 13 and 13.5 gallons. Seems to be pretty consistent.
fliz is offline   Reply With Quote
Old 05-18-2004, 06:53 PM   #6
samwY
Member#: 31816
same here
samwY is offline   Reply With Quote
Old 05-18-2004, 07:09 PM   #7
BENSREX
Member#: 39718
2007 WRX
My gas light does not come on until the pointer is just about right on the last line... it's an 04.
BENSREX is offline   Reply With Quote
Old 05-18-2004, 07:16 PM   #8
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
You described the performance of my gas gauge perfectly as well. It doesn't budge for the first 60 miles, but the light comes on at about 1/4 tank after the car's been turned off, except when on the freeway (when it turns on much lower).
MB38 is offline   Reply With Quote
Old 05-18-2004, 07:20 PM   #9
Horten
Member#: 19790
ok then i guess its supposed to be set that way....kinda irritating cuz id like to drive on it a little further but then id have no idea when id really be empty
Old 05-18-2004, 07:51 PM   #10
hotrod
Member#: 14141
2002 Impreza WRX
Default gas gauge
If you start the car on a low tank and the light comes on, but the Needle is not all the way down to the E mark, the light will go out again after you've driven a while.
It will also come on with a very low tank on steep hills, etc.
It averages its reading over a period of time, and it measures the fuel level in the passenger side of the tank, which gradually fills up when you are driving due to the jetsiphon fuel transfere from the return line.
When you first see the light come on solid, zero out your trip odometer, you have about 50+ miles of fuel left. (at least thats as far as I have pushed it )
Larry
hotrod is offline   Reply With Quote
Old 05-18-2004, 09:01 PM   #11
dust12
Member#: 13417
I currently have 91k miles on my wrx and for the last 1k the gas light and gauge have been acting funny. The gas light comes on and the fuel gauge reads E, but when I go to fill up the tank I can only get 11 or 11.5 gallons of fuel in the tank.
I used to fill it up to 13.5+ when the gas light came on. I'm guessing something is wrong with the gas tank floater.
dust12 is offline   Reply With Quote
Old 05-18-2004, 09:40 PM   #12
wayoutwest
Member#: 14379
2007 Acura
gray
dont know where exactly it comes on, but if i fill up RIGHT after it goes on, i put in just about 14 gallons exactly.
wayoutwest is offline   Reply With Quote
Old 05-18-2004, 10:56 PM   #13
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
Car has 15.9 gallon fuel tank with 1.9 being the reserve. The fuel light comes on slightly before (or should) you get into the reserve tank fuel. When my light comes on I generally put in close to 14 gallons
MK19_ is offline   Reply With Quote
Old 05-18-2004, 11:39 PM   #14
subaru mike
Member#: 30749
2002 wrx
Do what i did... 5 times run out of gas then you know/remember...
-mike
subaru mike is offline   Reply With Quote
Old 05-18-2004, 11:43 PM   #15
MK19_
Member#: 49148
Dogs are forever in
I pushed 421 miles out of a tank once PRAYING I didn't run out
I made it, but I am really curious how far you can get in a wagon with gear on the interstate w/o running out ?
Old 05-18-2004, 11:49 PM   #16
Celly
Member#: 48724
I have an 04, w/ 5500 miles. I just realized... I have never seen the gas light... Hmmm, And if it is broken, I'll need to run out of gas to find out... Sort of a Catch-22...
Celly is offline   Reply With Quote
Gas light comes on early Cakesniffer Service & Maintenance 2 01-08-2009 02:38 AM
gas light comes on early hockeygm Service & Maintenance 10 12-09-2008 08:08 PM
Gas light comes on too soon 06AWD Service & Maintenance 22 03-20-2008 09:51 AM
When Cold Low Oil Light comes on. Anyone know why? nos Service & Maintenance 18 02-07-2005 10:25 AM
How much gas is left when the low gas light comes on? catass STi Forum Archive 11 06-30-2003 07:21 PM
