Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 10-06-2000, 09:42 AM   #1
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Question Changing MT oil, and Rear Diff. Oil in a MY00 RS??
okay i know it has been mentioned before, but what should i use (Redline oils)? also, does anyone have any detailed instructions on how to change the oils in both?
thanx for all of your help in advance,
justin
joostin420 is offline
Old 10-06-2000, 03:20 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
I put Redline 75W90 in the rear diff, and 75W90NS in the transmission.
Procedure is pretty darn simple. For the rear diff: remove drain plug, allow oil to drain, replace drain plug, remove fill plug, fill (probably should get one of those plastic fluid pumps they sell at AutoZone/Pep Boys/whatever) until fluid starts to come out fill hole. Yer done.
For the tranny: remove big drain plug (towards front of tranny, right in the middle, as I recall you access it through a hole in the crossmember), allow oil to drain, replace drain plug, remove dipstick (passenger side, about 8" below the filter box mounted to the throttle body), fill through dipstick hole. I don't remember what the capacity is - check your owner's manual. Yer done.
Pat Olsen
'99 Legacy 2.5GT 5speed sedan
Patrick Olsen is offline
Old 10-06-2000, 08:46 PM   #3
HomerJay
Member#: 1135
2005 WRX WAGON
Question
Does anyone know how much rear diff oil I'll need. I want to switch it to a redline synthetic 75w90. Also, shouldn't the tranny fluid be flushed with one of those cycling machines? Cause at 15,000 miles, I want to switch to a synthetic tranny fluid.
HomerJay is offline
Vibration after 5 MT and Rear Diff Oil Change jjbehren Transmission (AT/MT) & Driveline 2 03-17-2008 03:31 PM
front, center, and rear diff oil change? awdguy Transmission (AT/MT) & Driveline 4 04-28-2005 10:44 PM
change your tranny and rear diff fluid ASAP rwheelz Texas Impreza Club Forum -- TXIC 15 05-26-2004 01:08 PM
Tranny and Rear Diff oil for 99 RS? JohnP555 Transmission (AT/MT) & Driveline 0 03-10-2003 12:21 PM
Tranny and Rear Diff oil changes help WRXThis Transmission (AT/MT) & Driveline 5 04-30-2002 06:25 PM
