Old 05-19-2004, 10:08 AM   #1
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Default H6 Rear Rotor Options for WRX
I feel like I've never really gotten a full handle on the products available for this upgrade, and I imagine there are only a few... humor me.
What are the brand, model, part number, etc for H6-sized rotors that will fit on the rear of an USDM MY02 WRX with stock 1-pot calipers?
Make: Subaru / FHI
Model/Line: H6 (I guess that's what you'd put here)
Part#: Unknown
Design: Solid, non-slotted, non-drilled, uncoated hat (rusts)
Site(s): http://www.subaruwrxparts.com/wrx-braking.html
Notes: Of course... requires H6 rear brake upgrade brackets.
Make: Frozenrotors.com
Part#: 96359
Design: Solid, cryogenic treated, slotted and non-slotted, uncoated hat (rusts)
Site(s): http://www.frozenrotors.com/
Make: DBA
Model/Line: Longlife
Part#: 657
Design: Solid, non-slotted and slotted, only the slotted version has a coated hat.
Site(s): http://www.dba.com.au (Manufacturer's site)
Make: DBA
Model/Line: 4000 Club-Spec Series
Part#: 4657
Design: Solid, non-slotted and slotted available, coated hat (resists corrosion)
Make: Stoptech
Model/Line: Direct OEM Replacement Rotors
Part#: 50-47017-101 (left, slotted) and 50-47017-102 (right, slotted)
Design: Solid, slotted or cross-drilled available, coated hat (resists corrosion).
Site(s): http://www.stoptech.com/ (Manufacturer's site)
Notes: Of course... requires H6 rear brake upgrade brackets. Search on website under '2002-2004' Subarus and you will see an Outback H6 selection. Cross-drilled is a different part number than slotted -- look it up if you want those.
Make: Carbotech
Part#:
Design: Solid, non-slotted, slotted can be had from Boxer4Racing.com according to Carbotech sales.
Site(s): http://www.carbotecheng.com/ (Manufacturer's site)
Make: iON Performance
Part#:
Design: Available slotted or cross-drilled. Cryo treatment available. Cadmium plating available (silver, gold or black).
Site(s): http://www.ionperformance.com/ (Manufacturer's site)
EDIT: Deleted DBA 4653 290x18 which will not fit. Added DBA 657.
EDIT: Added Stoptech info based on email correspondence with them
EDIT: Added Frozenrotors.com and Carbotech info based on email correspondence with them
EDIT: Added iON Performance info.
jblaine is offline   Reply With Quote
Old 05-19-2004, 10:22 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The 4653's WILL NOT FIT.
You must use a 290x10mm solid rotor.
Your options are the 657's or the 4657's
See: http://www.dba.com.au/dba_catalogue_...Out/Subaru.pdf
http://www.dba.com.au/dba_catalogue_...subaru_web.pdf
I believe Stoptech and carbotech have this size rotor available as well.
Old 05-19-2004, 11:03 AM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Re: H6 Rear Rotor Options for WRX
Originally posted by jblaine
Make: DBA
Model: 4000
Part#: 657
Design: Solid, non-slotted, uncoated hat (rusts)
Make: DBA
Model: 4000
Part#: 4657
Some suggestions.
Describing either of the 657s as model 4000 is incorrect. You need to use just model or PN cause theyre the same.
IIRC DBA offers all their standard series in three configurations. Plain, slotted, or slotted/x-drilled. So in theory you would have:
657
657sl and sr(slotted left and right as theyre directional)
657x(non-directional)
You could call the 4657 a Club Spec rotor if you wanted to, its designed for more serious use. The 4657 is also slotted IIRC.
You might try PMing DBAStave for clarification of their current model lineup.
ss
subysouth is offline   Reply With Quote
Old 05-19-2004, 01:00 PM   #4
Siper2
Member#: 1134
2007 BMW 328xi wagon
FrozenRotors.com sells them, too. They're Brembo discs.
Siper2 is offline   Reply With Quote
Old 05-20-2004, 07:10 AM   #5
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Added all sorts of info.
Old 05-20-2004, 07:57 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
My dba 657S rotors have coated hats and have not rusted in the time I've had 'em
Old 05-20-2004, 10:07 AM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Are those hats coated a dark grey color and are your slots directional, one rotor for the left and right?
ss
Old 05-20-2004, 01:13 PM   #8
Calimoxo2
Member#: 34531
'84 1/10 BRAT
Red
TWR makes a real nice and cheap rear upgrade.....$349.00
Aluminum tophat with 290mm rotors and caliper brackets...
http://www.twrracing.com/
Calimoxo2 is offline   Reply With Quote
Old 05-20-2004, 10:14 PM   #9
rossscarbro
Member#: 34627
2006 Evo IX GSR
Graphite Grey
Is that H6 upgrade on subaruwrxparts.com all I would need to install them? It says rotors and brackets...is that everything? Seems pretty good for $225...
Are any of these options cheaper??
rossscarbro is offline   Reply With Quote
Old 05-20-2004, 10:34 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
ss
Indubitably...
Old 05-23-2004, 03:44 AM   #11
BobbyD
Member#: 27262
02 WRX
bump..
--bobby
BobbyD is offline   Reply With Quote
Old 05-23-2004, 10:46 AM   #12
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
BobbyD: Yes and no, in that order.
Old 05-23-2004, 03:29 PM   #13
BobbyD
Member#: 27262
02 WRX
thanks.. so the pads in the stock wrx bracket will fit in the h6 one? (just want to make sure =P)
--bobby
Old 05-23-2004, 04:51 PM   #14
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
The pads fit in the caliper, not the bracket.
The bracket attaches to the knuckle and to your existing caliper to move it the proper distance radially from the larger rotor vs. the stock one.
Old 05-23-2004, 05:24 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
'H6' = pads and caliper same....BUT....caliper attach(to knuckle) bracket different + rotor different...got it?
Same caliper/pads....new bracket/rotor....
Old 05-23-2004, 05:34 PM   #16
BobbyD
Member#: 27262
02 WRX
yep.. thanks
--bobby
Old 06-02-2004, 12:22 PM   #17
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Oh, and I meant to ask... this is probably well-known. Do H6 rears fit under stock WRX rims?
Old 06-02-2004, 12:45 PM   #18
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
yep.....they're the same diameter as the fronts.....so if the fronts fit....the rears will
Legacy777 is offline   Reply With Quote
Old 06-02-2004, 12:46 PM   #19
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Duhhh
Old 06-02-2004, 01:31 PM   #20
Legacy777
Member#: 4800
Old 06-02-2004, 02:05 PM   #21
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Where? I don't see it on the site.
FYI Carbotech gave me a 10% Nasioc member discount the last couple times I ordered parts from them directly.
mbiker97 is offline   Reply With Quote
Old 06-02-2004, 02:31 PM   #22
Mister_wagon
Member#: 30201
2002 wrx wagon
Rally blue
Dumb ass question but will the regular wrx front disk fit the H6 bracket ! I mean like putting some front 290mm disk in the rear since size is the same !
Mister_wagon is offline   Reply With Quote
Old 06-02-2004, 02:45 PM   #23
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
No. The H6 rotor isn't vented so it is much narrower. Plus if you were to put a front rotor in the rear you would lose your parking brake.
Old 06-02-2004, 03:25 PM   #24
Mister_wagon
Member#: 30201
2002 wrx wagon
Rally blue
Thanks !
Old 06-02-2004, 03:56 PM   #25
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Most of the info is great but a couple of points of order.
1. The pads do in fact fit into the caliper bracket, not the caliper. The caliper bracket dictates the pad shape more than the caliper itself does. The ears of the pads "snap" into the caliper bracket.
2. When discussing the rear brakes, the caliper bracket attaches to a heavy steel backing plate which is bolted to the rear knuckle. The caliper bracket doenst bolt directly to the knuckle. (The front caliper brackets, if so equipped, do directly bolt to the front knuckle.)
Rear hierarchy: caliper attaches to caliper bracket via slide pins, caliper bracket bolts to the rear backing plate, rear backing plate bolts to knuckle.
ss
SoCal FS: NIB H6 rear brake conversion for WRX - brackets and clips only Okita Souji Suspension/Brakes/Handling 1 01-24-2008 08:29 PM
FS: NIB H6 rear brake conversion for WRX - brackets and clips only Okita Souji SCIC Private Classifieds 1 01-24-2008 08:26 PM
What rear Diff. options for WRX 4EAT? Twiztidunreal Transmission (AT/MT) & Driveline 1 12-21-2007 10:55 PM
H6 DBA rear rotors won't fit WRX? WRXThis Brakes, Steering & Suspension 24 07-14-2002 05:00 PM
DBA H6 rear rotors that fit WRX WRXThis Brakes, Steering & Suspension 3 07-03-2002 01:05 PM
