Old 05-19-2004, 11:01 AM   #1
SupraTT&WRX
Member#: 12452
02 WRX
SRP
Default Can I run a VF39 with out tuning my car
Is it possibly or will I run way to lean? I will be running stock boost 14.7psi.
Chris
SupraTT&WRX is offline   Reply With Quote
Old 05-19-2004, 11:37 AM   #2
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
hell you can't run the stock turbo without "tuning" it
overdose is offline   Reply With Quote
Old 05-19-2004, 12:09 PM   #3
Twerthi
Member#: 30207
2005 Lotus Elise
Magnetic Blue
I would recommend against it. A few months ago, someone tried it and blew their motor at stock boost levels. I would recommend you get the supporting mods for any turbo upgrade.
Twerthi is offline   Reply With Quote
Old 05-19-2004, 12:34 PM   #4
ascott
Member#: 6545
Rally Blue Pearl
Default Re: Can I run a VF39 with out tuning my car
Chris
But at stock boost, that turbo is going to flow more air. You'll go lean, and it will pop.
Really, there should be a sticky or a FAQ or something.
Q. Can I do xxx to the engine without add-on management?
A. No
ascott is offline   Reply With Quote
Old 05-19-2004, 12:39 PM   #5
Twerthi
Member#: 30207
2005 Lotus Elise
Magnetic Blue
Default Re: Re: Can I run a VF39 with out tuning my car
A. No
It's funny because it's true
Old 05-19-2004, 12:48 PM   #6
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
stock boost is 13.5 and if you're gonna run a larger turbo without tuning, run it at even lower boost levels.
camz911 is offline   Reply With Quote
Old 05-19-2004, 12:50 PM   #7
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
YES YOU CAN RUN IT!!!!...........but you have to have it at much lower boost. If I were absolutly saet on running it without engine managment, I wouldnt run it any higher than about 8-10 psi.
And if you're going to run it that low, you're not going to have any fun with it so it will pretty much be a waste of time.
Old 05-19-2004, 01:19 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
if you had to you could run it off the wastegate spring but no more .. still not a good idea..
how ever
vf39 +injectors+cobb stage 2.5 +turbo back = huge bang for hte buck
350+350+595 +700.... ~2k should be good for at least 220whp
Old 05-19-2004, 01:20 PM   #9
ascott
Member#: 6545
Rally Blue Pearl
Well, you CAN do anything. You CAN drive the car off a bridge into a river, but you really shouldn't.
The computer runs the car. The programming is based on the components installed in the car when it was stock. *Any* change to a modern emissions-controlled vehicle is going to result in a non-optimal tune.
You've taken the computer program that runs the system and thrown out all the assumptions under which that system was designed. If the assumptions become wrong, the program becomes wrong, and the wrong program has a high probability of damaging the car.
If you plan on altering the power output of the engine, your first modification should be engine management and a competent tuner.
Old 05-19-2004, 02:09 PM   #10
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
ASCOTT, you quoted only one part of my post. If you would have taken the time to read the rest of it you'd realise that it was NOT a recommendation to do so, it was merely stating that he CAN do it if he wants.
Somebody needed to clarify for him his options. People who posted earlier said that it can not be done. I simply said that it can.
so correct me if i'm wrong. According to your post, engine managment should be gotten before a downpipe or even a catback.....WHY??? mods such as those are not great enough to necessitate the use of engine managment. It would help to utilize the power potential of the parts, but it isnt a do or die mod.
Old 05-19-2004, 02:22 PM   #11
Twerthi
Member#: 30207
2005 Lotus Elise
Magnetic Blue
I never said it couldn't be done, I said I recommend against it. You stated that you could do it if you lowered boost levels, he was talking about running 14.7 ... in which he would most likely run too lean. So, in the spirit of the original question, I would say it can't be done without the use of some sort of engine management.
However, this is starting to escalate into a flame war, so we should stop here.
Old 05-19-2004, 06:08 PM   #12
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
Originally posted by Jaxx
how ever
Just a turbo-back and reflash give you 220whp. Seen
HERE.
VF34 + injectors + Cobb Stage 2.5 + TBE = 270ish whp. Seen Here. Probably a little less because he has some other support mods. Maybe in the 250-260 range.
Mattr762 is offline   Reply With Quote
Old 05-19-2004, 09:41 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
on a dyno jet
but not on a mustang or dynapack
but the point is mute ... get the supporing mods and have fun
Old 05-20-2004, 02:25 AM   #14
sirwrx273
Member#: 37965
2003 WRX Wagon
I have seen a guy grenade a motor on the dragstrip at the 1000' mark because he had a VF39(running 20psi), UniChip, TBE, and no injectors...it leaned out, and POP!!!
Good Thing you're doing your homework
Steve
sirwrx273 is offline   Reply With Quote
Old 05-21-2004, 12:57 PM   #15
ascott
Member#: 6545
Rally Blue Pearl
And if you'd read the rest of my post, you'd realize you just repeated what I said.
He doesn't need his options clarified, he needs to do a ton more reading on how an engine works before he starts asking questions that have been answered innumerable times.
Everything between the MAF and the last O2 sensor is a system. That system is regulated by the computer. If you alter the system, you have to alter the control or you're asking for trouble. If you want to effectively modify these cars, the first thing you get is some kind of management. That's my story and I'm sticking to it.
Old 05-22-2004, 09:57 AM   #16
SupraTT&WRX
Member#: 12452
02 WRX
SRP
Well man you want to be like that about it. I know plenty about how a engine works and how the computer mannages it. Subarus act a little different than the car I was modifying (815rwhp Supra) now granted it was a fully built motor and AEM ECU with a monster turbo. I stock supra you can put a larger turbo on run the stock MAF and stock ECU with a SAFC and put out a little under 500rwhp. Now a engine is bassicly a air pump right, so the maf measures what is going in O2's measure what is comeing out. So by that measure the if you were to go with a larger turbo (like a supra) the maf would sense the extra air and richen the A/F. Now subarus will not do this to the extent a Supra will, and I know this, I was more asking how far it will compensate. No need to be a ass
Chris
Can I tune my car with Delta Dash? mrtrex Engine Management & Tuning 5 10-04-2005 03:49 PM
Who can tune my car/Houston/fast H.K. Phooey Texas Impreza Club Forum -- TXIC 11 01-05-2004 01:40 PM
who can tune my car good in socal? speshuled619 Southern California Impreza Club Forum -- SCIC 7 12-16-2003 03:30 AM
my company may be sold, can I get out of my car loan? Qbushido Off-Topic 6 09-25-2003 09:32 PM
