05-31-2000, 03:42 PM | #1 |
Member#: 126
Unorthodox Pulley Install - how do you break that F****ing bolt????
Those of you who have done this - how in the hell did you break the pulley bolt? did you invite Arnold over for dinner? I tried multiple times and gave up and had a friend bigger than me try and he also gave up. I'm using a very long 1/2" drive with a 22mm impact socket on the end. Any hints except for find stronger friends?
Tim
05-31-2000, 03:47 PM | #2 |
Member#: 717
NESIC
I pulled and pulled and finally gave up. Then, before turning out the lights, thought "I'll give it one last shot".
Of course, it popped right off! Lock the brakes, use a long breaker bar and be persistant! |
05-31-2000, 03:49 PM | #3 |
Member#: 242
Vehicle:MY05 PSM GGA !STOCK MY99 RS-RIP / MY95 MX-5 |
4' breaker bar. Or add a pipe to the end of your normal 1/2" breaker bar. It will moan and creak, LOUDLY, but it should come off. Recommended that you use wheel chocks to keep the car from moving.
Remember, that cast iron POS has been torqued at the factory to @130 ft-lbs. [This message has been edited by Revision (edited May 31, 2000).] |
05-31-2000, 03:52 PM | #4 |
Member#: 876
have someone step on the brakes and put the gearing to 5th. and to get it off by urself put a towel or something on the side of ur fenders and put both of ur feet there and pull with all ur might (it works)
05-31-2000, 04:17 PM | #5 |
Member#: 957
Vehicle: |
worse comes to worse, get out your hard hat..
suby |
05-31-2000, 04:18 PM | #6 |
Member#: 759
NESIC
Vehicle:2012 Regal GS 2000 SV650 |
I almost gave up too, mine didn't want to come loose. I had a buddy do the pulling becuase everytime I cranked on it I felt like I was going to hurt my car. Not being his car and telling him that if anything breaks I'll pay for it he just cranked all he was worth and it finally snapped loose. Tight sucker!
05-31-2000, 04:23 PM | #7 |
Member#: 1140
SCIC
Vehicle:2000 S201 #78, '95 L '13 F150 Ecoboost |
Don't be such a wuss! I've heard of people putting a large pipe over the breaker bar. Gives you a little more torque.
05-31-2000, 04:40 PM | #8 |
Member#: 911
TXIC
Vehicle:2005 Sti Silver |
I put some foam on one side of my car and put a rope thru the hole in my breaker bar. Then I tied the rope to the bumper of my race car and took off. It worked.
Oh hell i'm just joshing ya. |
05-31-2000, 04:49 PM | #9 |
Member#: 876
u can always just take out the radiator and fans and stick an impact there.. that bolt will be out in 2 secs
05-31-2000, 06:10 PM | #10 |
Member#: 1427
Why don't you try the starter? I heard that you put the wrench, let it rest on one side then just crank the starter and Voila!
05-31-2000, 07:09 PM | #11 |
Member#: 126
Thanks everyone, I'm going to try again tomorrow.
The starter idea sounds like a good way to send a wrench sailing, I think I'll just try better leverage first. Tim |
06-01-2000, 04:09 AM | #12 |
Member#: 420
SCIC
Vehicle:2001 Cr-V Silver |
I'm going to go out on a limb and say
Don't do what Mr. Gasket suggested. You might try soaking a little wd40 in there. I was pretty lucky, I just put it in 5th, set the eBrake(sounds like a website), and pulled. But I'm 6'2" / 270lbs. - every bit the man, mind you. - but seriously, a pipe or other extender - and make sure you're pullng the right way - is the bolt reverse-threaded, or am I high on the crack? |
06-01-2000, 04:44 AM | #13 |
Member#: 296
Whimps.. all of ya..
Just use a standard bar and socket.. and use those muscles...*assuming u have some* lol J. |
06-01-2000, 04:58 AM | #14 |
Member#: 1407
Vehicle:2000 2.5 RS-T BRP |
I had the same thing at first. Take a 2 foot piece of pipe and put that over the handle of the 1/2 wrench. Then pull like hell, it will pop loose.
06-01-2000, 05:36 AM | #15 |
Member#: 481
Do what mr. gasket said, i did! I think i mighta been the first to do that. everyone booed me too But hey- it works. Just blip the starter- 3 short birsts with the key. Be careful.
06-01-2000, 06:34 AM | #16 |
Member#: 874
RMIC
Vehicle:2005 Honda S2000 2021 Tacoma TRD Off-Road |
Putting the car in 5th and standing on the brakes worked for us. The starter idea, however, didn't . Keep cranking on it, you'll get it.
-Diz |
06-01-2000, 08:21 AM | #17 |
Member#: 126
As for reverse threading - the instructions on i-club say crank counter-clockwise which is normal threading. am i going the wrong way?
06-01-2000, 10:16 AM | #18 |
Member#: 420
SCIC
It's probably just my wackiness. I must hav ebeen thinking of something else - what, though?
06-01-2000, 11:30 AM | #19 |
Member#: 717
NESIC
cvalle, you're not high on crack, just remember:
Righty-tighty, Lefty-loosey. Except for the propane tank on your gas grill and model aircraft propellers............. |
06-02-2000, 09:55 PM | #20 |
Member#: 1110
Vehicle:1999 RS Silver |
It's standard thread. I was sure it would be reverse thread as well. I used Pentrating Lube (I love that stuff) and sprayed it several times and let it soak overnight. Then I broke it loose with a 2' piece of 1" pipe over my 1/2" driver, and I'm a pansy compared to Cvalle. You can do it.
Herman Miller Aeron Chairs, how do you break them down? | Mud Pig | Off-Topic | 6 | 06-26-2007 01:18 PM |
how do you properly "torque" a bolt? | FullContact007 | Service & Maintenance | 7 | 12-10-2004 03:22 PM |
How do you use the camber bolts? | jhong567 | Brakes, Steering & Suspension | 7 | 04-21-2003 05:01 PM |
WRX cd changer: how do you disconnect that fat black cable in back? | Fubaru | Car Audio, Video & Security | 3 | 11-19-2001 03:46 AM |
