Old 05-19-2004, 02:21 PM   #1
boxer02
Member#: 18037
Platinum Silver
Default 100 octane.... bad?
i plan on taking my car to the drag strip one week from sunday, and was considering my theory on higher octane is better. i typically fill up with 93 octane, no ethanol....
so, will running 100 octane in my car (2002 wrx) hurt it?
our ecu's takes a while to learn, so i was thinking of filling up with this a week before going to the strip up at cordova.
i'm not asking if its worth it, although with the recent spike in gas prices it might be....
i stopped by the local station and they had it listed at 3.60.....
i figure i'd run it for the week, then run it at the strip, then slowly start to mix 93 octane back into the mix
boxer02 is offline   Reply With Quote
Old 05-19-2004, 03:10 PM   #2
HoRo1
Member#: 15618
100 octane won't hurt. I don't think that you'll see more than +1% extra power though.
$3.60 for 100 octane!
HoRo1 is offline   Reply With Quote
Old 05-19-2004, 03:11 PM   #3
Skibum4444
Member#: 21914
2002 WRX/2013 BRZ
05 Legacy GT Wagon
I run 100 when i go road racing. My Ecu is tunned so it will eat up anything i throw at it. But yeah your drag racing so make sure you dont have that much gas in your tank anyway. I dont get 93 octane anyway in my state so your running a little better anyway.
$3.60 for 100 octane Ha, in Washington last i paid was $5.30, and that was last summer.
Skibum4444 is offline   Reply With Quote
Old 05-19-2004, 04:20 PM   #4
boxer02
Member#: 18037
Platinum Silver
yea, i figured w/ 93 being 2.27, the jump to 3.60 wasnt that bad.
there's only one station around that sells the 93 w/o the 10% ethanol in it, so thats were i always go to fill it up... luckily its right on the way from home to work....
so, no ill effects, means i'm gonna fill her up w/ it tonight....
Old 05-20-2004, 12:25 AM   #5
WRXedUSA
Member#: 26833
'07 Bugatti Veyron
'03 Chevy Silverado
It'll be just fine. Remember in Japan and most parts of Europe, 98 is almost standard.
WRXedUSA is offline   Reply With Quote
Old 05-20-2004, 02:25 AM   #6
makofoto
Member#: 25243
2006 Legacy Outback
Japanese/Euro octane is lower then our rating ...
WRX ECU can probably only take advantage of up to 96 octane ... anything more is a waste.
Toluene is 114 octane ... cost about $6.50/gallon ... you need less of it ... so it's quite a bit cheaper.
To speed up ECU resetting, see Shiv's advice in this thread:
http://forums.nasioc.com/forums/show...hreadid=302047
If you are using 93 and 100 octane fuels ... you need to mix about half and half to end up with 96+ octane.
If you are using 114 octane toluene ... and 93 octane gasoline .... mix 1.5 gallon toluene and 4.5 gallons of 93 gas ... to get 6 gallons of 96+ octane.
makofoto is offline   Reply With Quote
Old 05-20-2004, 04:24 AM   #7
PsychoSoldier
Member#: 17283
1998 POS Dodge Neon
They use a different standard then the US.
European 98 is ~93 in the US.
PsychoSoldier is offline   Reply With Quote
Old 05-20-2004, 02:18 PM   #8
deuce.five
Member#: 43800
NWR-SCCA Champ STS #22
Tolulene? Yeahright!! Go for it, dude! See you at the warranty office! Go buy decent race-fuel and don't try and be a chemist with your $25K car. I use ERC race-unleaded with chevron super, about half and half, 110 octane, mixed with 92, yields somewhere around 100, pulls noticably harder on top-end. Probably only worth a tenth or two at the drags though....
deuce.five is offline   Reply With Quote
Old 05-20-2004, 03:48 PM   #9
makofoto
Member#: 25243
2006 Legacy Outback
24,000 miles and going strong ... I also have a Vishnu/Shiv dual EcuTek dyno tune ... to take advantage of the extra octane.
Here is a BP FAQ Sheet suggesting Toluene to increase octane. "Regular" gasoline has toluene in it ... we are just increasing the amount.
See No. 2 "How Can I Increase My Octane"
http://www.bp.com.au/products/fuelnews/faq.asp
Commercial Octane Booster is mainly Toluene ... just marked up a huge amount. And when they say it increase ones octane by say 5 points ... they mean .5 points! :-(
I add a bit of Marvel Oil for cleaning and lubing ... or some ATF and Kerosene.
Do a Search here for a lot more info.
Old 05-20-2004, 04:52 PM   #10
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
ERC doesn't make 110 octane unleaded gas, they make 110 RON unleaded which is 104 octane R+M/2. But still 104 octane mixed with 92 half and half is about 98 octane. There was a place in Chicago selling 100 octane for $2.71/gal which is like .30 more than 93... Around this area I can get 110 leaded for about $3.70/gal but nobody sells 100 unleaded except one place at about $4.00/gal.
100 octane daily use....bad for motor? xsennaix Newbies & FAQs 17 09-27-2007 12:24 PM
Would 93 octane plus alky = 100 octane map notraceready Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-23-2007 10:05 AM
SMC alcohol injection kit: run 91 octane+ kit= same as 100 octane in the tank gnx7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-25-2002 03:57 PM
Where Can I Buy 100+ Octane In Miami or Surrounding Areas? ND4SPD2000 South East Region Forum 1 11-13-2001 12:05 AM
100 octane Scampy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-08-2001 01:40 PM
