Old 05-19-2004, 02:32 PM   #1
ProdriveRex
Member#: 53921
2011 STI Sedan- DGM
2006 E90 325- TSM
Default Window replacement instructions. Help needed.
i got 2 windows to replace today. on my 03 rex. front left. and rear right.... anyone know if its hard to do? any hints or directions with pictures? any help apreciated.
thank you.
peter
ProdriveRex is offline   Reply With Quote
Old 05-19-2004, 08:28 PM   #2
03WRXMA
Member#: 35081
2012 WRX
Try an autoglass shop, they dont charge much for install, its the cost of glass thats expensive.
03WRXMA is offline   Reply With Quote
Old 05-19-2004, 11:36 PM   #3
ProdriveRex
Member#: 53921
2011 STI Sedan- DGM
2006 E90 325- TSM
No need for autoglass shop. It was SUPER easy. 2bolts each window. no brainer.... and subaru told me its VERY TRICKY... yea... how tricky 2 bolts can be... hmm
Old 05-20-2004, 12:42 PM   #4
03WRXMA
Member#: 35081
2012 WRX
Good, I wont even touch glass at the body shop where I worked. Its not worth if you break it, it leaks, etc..
Old 05-20-2004, 01:04 PM   #5
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
Edit: Disreguard everything below, I did not read correctly to see that you got it handled.
Never done it on a WRX but in general this is what you do:
1 Remove the door panel
2 Roll the window up and down until you can see the mounting bracket (normaly there is one position that you can get to the bolts through a cut out)
3 Slide the new glass in from the top
4 Screw the new glass to the bracket (2 or 3 botls maybe)
5 Test the window function
6 Replace door panel
Should not take to long and the second one will be faster once you know what to do.
bhall is offline   Reply With Quote
Does anyone know or recommend a window company? I need a bay window replaced. higgins14 New England Impreza Club Forum -- NESIC 3 07-15-2008 04:23 PM
Need help..need instructions for install of B&G Coilovers 02 wrx pightr Brakes, Steering & Suspension 0 10-08-2004 08:51 PM
Northern IL window tint purchase help needed Purgatory-Z Mid West Subaru Owners Club Forum -- MWSOC 1 03-29-2003 01:39 AM
Help! Need install instructions for MRT brake bracket mturmel Brakes, Steering & Suspension 10 04-26-2002 02:05 PM
HELP...need window replacement ASAP mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 9 02-09-2001 05:12 PM
