Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 05-19-2004, 04:05 PM   #1
globalmike
Member#: 50553
Default uppipe/downpipe cel?
so i installed an uppipe and gutted the down pipe should i expect to to see and cel's?
globalmike is offline   Reply With Quote
Old 05-19-2004, 06:04 PM   #2
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
From what I have read about other peoples mods on exhaust I would say more then likely you will throw one. But there are fixes for that if you do.
Flexx999 is offline   Reply With Quote
Old 05-20-2004, 02:11 AM   #3
brianbot5000
Member#: 44000
2013 2013 WRX Hatch
1997 Toyota Tacoma
Couple threads I just bookmarked on this very subject last night...doing some pre-mod research.
mechanical CEL fix for catless downpipe:
http://forums.nasioc.com/forums/show...l&pagenumber=1
and
http://forums.nasioc.com/forums/show...666&perpage=25
For uppipde cel fix (aka, EGT sensor fix):
http://forums.nasioc.com/forums/show...hreadid=548451
brianbot5000 is offline   Reply With Quote
Old 05-20-2004, 10:24 AM   #4
bigbear522
Member#: 21304
2002 Impreza WRX
Funky Silver Party Wagon
You will throw your EGT CEL when you burn out your probe, it takes about 6 months.
you will throw your O2 CEL when your driving in 5th gear and your above 60% throttle.
So you have to do these mods if you want to go catless.
For your uppipe, you will need a RESISTOR fix.. 2.2ohm 1/2W resistor. The the two end of the resistor can be plugged into the harness side of the EGT probe.
resistor can be picked up at any electronic store
For your downpipe you will need a O2 sensor fix that can be picked up here. (REMEMBER TO RESET YOUR CAR AFTER THIS MOD)
ponyexpressperformance.com
hope this helps.
Byron
bigbear522 is offline   Reply With Quote
Old 05-20-2004, 01:02 PM   #5
globalmike
Member#: 50553
i thought that the mechanical fix was the only one that worked for an 2004.
also thanks for the help.
mike
Old 05-20-2004, 06:35 PM   #6
LowUFO
Member#: 36495
2004 WRX
Black Pearl
I don't know where I am going wrong, but I have both the resistor fix and the mechanical fix. Still got the CEL. Came on right after I installed the dp and haven't been able to get rid of it permanently.
I have an 04 wrx.
LowUFO is offline   Reply With Quote
Old 05-20-2004, 08:11 PM   #7
R.C.Y.K.
Member#: 10389
i have egt cel be4, now it is gone with the resister mod. and i only get the dp o2 cel when i am driving long time with 5th gear. but it will be gone after a tank of gas
R.C.Y.K. is offline   Reply With Quote
Old 05-20-2004, 11:30 PM   #8
bigbear522
Member#: 21304
2002 Impreza WRX
I did't know you have a 04... sorry I have a 02, old school fix!
Uppipe/Downpipe Cel fixes totalburnout Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 11-09-2006 01:14 PM
WRX 02 - 05 Up & Down Pipe Cel Fix uppipe downpipe jasonpig Private 'For Sale' Classifieds 18 06-29-2006 01:12 PM
Helix Uppipe, Downpipe and CEL - anything else..? prototypeWRX Texas Impreza Club Forum -- TXIC 4 03-09-2005 03:50 PM
CEL question related to uppipe/downpipe Moshpit552 Newbies & FAQs 3 08-21-2004 02:38 AM
Perrin Gen III Uppipe Install = CEL scoobyrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-22-2002 10:07 AM
