Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 05-19-2004, 05:05 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default exhaust confusion, im about to end my life?!
ok thanks to raykwoks stupidity i didnt know the up pipe i bought off of him was header specific so i used a routing bit and chewed my header flange up so that it lines up, so far so good on that
but
the stupid gaset doesnt look like its gonna seal at all
its the flex gpmoto uppipe and the seal ring on the gasket is inside of the hole on the gpmoto UP but fits find on the header
is it gonna leak?
wth should i do?
i was thinkin of making a gasket out of copper and just squeezing the crap out of it hoping itd seal
alex
Old 05-19-2004, 06:59 PM   #2
commador
Member#: 59227
1998 Legacy GT
Black w/ gold pearl
if the only way to make it work is custom, then do it. Get some high temp gasket material, and make one. Copper would work, but if you layeredit, it would probably work better.
commador is offline   Reply With Quote
Old 05-19-2004, 07:04 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
i heard that gasket material is garbage or does anyone know of any thats actually worth a damn
Old 05-19-2004, 07:23 PM   #4
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
The gooey liquid gasket material starts to break down at VERY low temperatures. It works great for grocery getters that are driven as such... but if your EGT's get much above 1,000 degrees expect to hear a *pop* and then suffocate soon after. There are places where you can get small sheets of the aesbestos/ceramic exhaust gasket stuff and cut it to the size/shape you need, any decent exhaust shop should have some of this stuff on hand.
no-coast-punk is offline   Reply With Quote
Old 05-19-2004, 07:33 PM   #5
commador
Member#: 59227
1998 Legacy GT
Black w/ gold pearl
thats the stuff I tried to say, but it didnt come out right. I didnt mean that blue rtv stuff, I wouldnt trust that on exhaust parts.
Old 05-19-2004, 08:37 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
thanks no coast ill try
i got a sheet of some steel reinforced stuff...not sure what temp rating its good for i got it from the guy i got my nur spec from...but i really dont feel like making a gasket and having to pull that damned turbo 4 miles later
thanks ill check around for some tomorrow
Old 05-20-2004, 10:45 AM   #7
Unsung Boxer
Member#: 37196
none of that gasket maker will work. even the exhaust liquid gasket will break down on up/down pipes because they get VERY hot. You must find a way to make sure the flanges line up flat, and use the metal gasket that is intended to go inbetween. sorry to say, but if its not flat, it wont seal.
If all your stuff is so close to fitting try this:
1. Loosen all the bolts up to the header/head bolts.
2. install the up/down pipe/turbo loosely.
3. Use a pry bar to positition the componants.
4. Tighten the bolts while you hold the parts in place.
Believe it or not, you can gain alot of clearance this way, because there is small amounts of slop in all those bolts holes.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 05-20-2004, 07:47 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
new plan
make a stainless spacer, and weld it to the flange then use a subaru gasket problemo solved
my ****in uppipe fit i cant believe it??!?!?!?!? im so close
Old 05-22-2004, 01:23 PM   #9
Unsung Boxer
Member#: 37196
what is the pipe made out of? instaed of making a spacer, the pipe can simply be cut, and have a small piece of pipe welded in to make it longer.
Dont you love all the obstacals of AFI? Dont get too pissed yet, there will be more problems to come
-Jake
Old 05-22-2004, 01:30 PM   #10
no-coast-punk
Member#: 49087
Thank god that I learned that any 3" exhaust for the WRX will fit our cars with some slight modification to the hangars.
Old 05-23-2004, 06:59 PM   #11
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
jake ive been lookin for pipe but i cant find any 1/8" thick 2" od
im about to wash my engine/bay ODiz413 Car Care & Detailing 56 04-23-2009 09:19 PM
I'm about to start my life as a Network Admin. epson1 Off-Topic 50 08-17-2008 05:35 PM
Ok, so Im about to finish my suspension, 27mm front AND rear Q's! Dubstar112 Brakes, Steering & Suspension 16 06-27-2007 05:30 PM
idle problem. Im about to punch my car in the face. BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 03-08-2006 06:24 PM
Im about to rip my hair out paul25RS Car Audio, Video & Security 6 10-26-2003 12:22 AM
