Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 05-19-2004, 06:16 PM   #1
commador
Member#: 59227
1998 Legacy GT
Black w/ gold pearl
Default quick question on wasegates
ok, do wastegates keep the boost where it should be all the time?? I read someone had a MBC and in 1st had 8psi, 2ng gear had 10psi 3rd 14psi or so..was this caused by the MBC?? why was boost affected by the gear he was in?? wouldnt a wastegate with no controller stay where it is suppose to??
Ok, I found springs, but how do I know which to get?? They have 38mm 40mm and 46mm. How do I know what my wastegate is??
commador is offline   Reply With Quote
Old 05-19-2004, 10:03 PM   #2
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
Dirt-01 Forester swapped
Wastegates are suppost to keep the boost steady and at a desired pressure determind by the spring in it.
Usually, some electronic boost controller can vary boost by gear but they are expensive. A manual boost controller cant do that unless it is a two step solinoid, and even then you need to flip a switch to activate it.
I believe you are refering to boost creep but that is generally in forth and fifth gear. I dont know of that extreme of a case were the boost raised itself that much by third gear, but anything is possible. If I had to guess the guy with the mbc had a vaccum leak and that was causing such a rise in boost pressure.
As far as the springs your on your own. I dont know what kind of wastegate your running to even steer you in the right direction.
If I'm wrong let me know
just trying to help
chris
25rstautoxr is offline   Reply With Quote
Old 05-19-2004, 10:33 PM   #3
commador
Member#: 59227
1998 Legacy GT
Black w/ gold pearl
The wastegate is the tial one that comes with the ludspeed stage 2. I just orderd the kit so I dont have it yet. Are there markings on the wastegate to say what it is?? Oh, and the boost creep thing, is in AFI with the title "holy overboost batman!"
Old 05-20-2004, 11:01 AM   #4
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Tial 38mm
Hitokiri is offline   Reply With Quote
Old 05-20-2004, 05:40 PM   #5
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
wastegates control the maximum amount of boost you can push. Air pressure pushes on the spring which then opens a valve to bypass the exhaust going to the turbo.
Boost controllers let you add boost by (in a way) limiting the pressure the wastegate sees thus the wastegate opening later, when there's more boost.
Another reason why your friend might be boosting less on lower gears is because 1st and 2nd gears are short gears and the the motor isn't providing enough exhaust gases for the turbo to provide enough boost.
cRayZee is offline   Reply With Quote
quick question on similarities on harnesses simprezl25 Subaru Conversions 1 11-29-2005 10:42 AM
quick question on 99 rims HydeX Brakes, Steering & Suspension 2 09-05-2001 10:21 AM
Quick question on Vent style : ) STi-Nismo Dood Interior & Exterior Modification 1 05-07-2001 08:00 PM
('93-'01) Quick Question On Taking Front Seats Out STORER Impreza Forum 4 04-09-2001 12:43 AM
Quick question on Heads The_extreme Technical Forum Archive 2 07-17-2000 07:57 AM
