Old 05-19-2004, 10:20 PM   #1
Suby1128
Member#: 33995
2002 WRX Sedan
Sedona Red Pearl
Angry Trunk slipping problems
I've searched but can't find the answer to what I'm looking for so I'll give it a shot here. I have a sub in my trunk but also use it for my book bag etc. on the way to school (02 wrx sedan). But the carpet in the trunk isn't stuck down at all or durable in the least, so I open the trunk to find my sub not where it was, and my carpet scrunched up in a corner. Does anybody know where to find a durable rubber mat for the trunk or atleast a solution to stop it sliding. I tried velcro but it did nothing, they came off after 2 days. Any help is appreciated.
Thanks,
Craig
Suby1128 is offline   Reply With Quote
Old 05-20-2004, 12:30 AM   #2
satrya
Member#: 5887
2002 GDAA
797
Default Re: Trunk slipping problems
I got one from
http://www.weathertech.com/
It was one of those generic trunk mats with general outlines for you to trim to fit individual trunks. It's very heavy duty and does a good job keeping liquid from spilling off the mat. Not inexpensive though. About US$100 iirc.
satrya is offline   Reply With Quote
Old 05-20-2004, 10:33 AM   #3
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
You could just glue it to the spare-tire cover.
scrappydoo is offline   Reply With Quote
Old 05-20-2004, 05:10 PM   #4
kenchan
Member#: 15106
Put a L bracket on the sub box and zip tie it onto the trunk floor.
Just in case you need to use the spare, cut the zip ties and you're set.
kenchan is offline   Reply With Quote
Old 05-20-2004, 05:37 PM   #5
Horten
Member#: 19790
i got some velcro tape and put it between the particle board and the felt cover on top...just use about 4 pieces in different areas, and it will hold everything down real nice. you can even put one between your sub and the felt to keep it from sliding on top if its still a problem.
Horten is offline   Reply With Quote
Old 06-21-2004, 12:33 PM   #6
Brad Pittiful
Member#: 34931
. is his name
∂³∑x²
Default Re: Re: Trunk slipping problems
Originally posted by satrya
I got one from
sweet find...im starting to look for one of these...ill have to check this out
Brad Pittiful is online now   Reply With Quote
Old 06-21-2004, 12:55 PM   #7
satrya
Member#: 5887
2002 GDAA
797
Default Re: Re: Re: Trunk slipping problems
Have had this for more than 2 years now. Imho it's good for carrying dirty & wet items. The surface also minimizes cargo sliding when used in normal driving.
I should reiterate the fact that it is heavy.
Old 06-21-2004, 01:28 PM   #8
Brad Pittiful
Member#: 34931
. is his name
∂³∑x²
Default Re: Re: Re: Re: Trunk slipping problems
excellent...thats what im looking for...the mat that comes with the car isnt good...if i put a bulk item on it...it slides all over...its annoying
Clutch slip problems on my swap speedymaker Transmission (AT/MT) & Driveline 0 05-20-2010 05:48 PM
Slipping Problem...? cgmwrxFTW Transmission (AT/MT) & Driveline 7 01-16-2009 03:26 PM
Missing/slipping problem e-type Pre-2002 Factory Turbo Powertrain 3 07-08-2005 06:09 PM
Trunk Release Problems Belvadere STi Forum Archive 11 07-30-2003 02:00 PM
Trunk alignment problems? SUV-ETR STi Forum Archive 6 06-21-2003 03:16 PM
Message Board Statistics All times are GMT -4. The time now is 12:57 AM.
