Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 05-20-2004, 10:19 AM   #1
AngryBlueRS
Member#: 51678
05 STI
87 Rocco dirt beast
Default APEXi S-AFC on a NA 2.5
Greets all,
I know this probably belongs in NA, but I wanted to try local first.
Has anyone installed the APEXi S-AFC on a 2.5 motor? Any numbers on the performance difference? I've already opened the intake and exhaust so I'm looking for the next bump.
Also, anyone sell and install them locally? I could probably do it myself, but then again I could probably screw it up pretty bad as well.
Thanks in advance,
Chris
AngryBlueRS is offline   Reply With Quote
Old 05-20-2004, 10:46 AM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
I had one on my old RS. Honestly, I didn't notice any change.
JGard is offline   Reply With Quote
Old 05-20-2004, 11:29 AM   #3
lucidmatrix
Member#: 34776
04 Z
le mans sunset
less than 5lb/tq, 5hp i'd guess..
lucidmatrix is offline   Reply With Quote
Old 05-20-2004, 11:31 AM   #4
Mumbles
Member#: 248
That's because it knew you were going to become a traitor!
Mumbles is offline   Reply With Quote
Old 05-20-2004, 11:44 AM   #5
Thug
Choke Artist
Member#: 603
Probably wont help HP or tq much, but you may be able to get your mpg up closer to stock.
Thug is offline   Reply With Quote
Old 05-20-2004, 05:25 PM   #6
AngryBlueRS
Member#: 51678
05 STI
87 Rocco dirt beast
Thanks for the great feedback everyone! Guess I'll save the $350 and invest it something else. Maybe muffler bearings.
Chris
Old 05-20-2004, 08:23 PM   #7
Longshot
Member#: 2359
2001 Impreza 2.0 WRS
I won't post my dyno results again cause I'm lazy. I gained 5hp and 10lb/ft torque from a quick tune of my AFC back in the day. It did make difference.
Longshot is offline   Reply With Quote
Old 05-20-2004, 08:35 PM   #8
AngryBlueRS
Member#: 51678
05 STI
87 Rocco dirt beast
Any intake and exhaust mods to really leverage it?
Thanks,
Chris
Old 05-20-2004, 09:44 PM   #9
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
It does make a difference, Chris. If you can get to a dyno and run 91+ octane you'll be able to manage what Korey mentioned. Also, I happen to have one I'll give you a good deal on (it used to be Koreys! Proven results! )
Darshu is offline   Reply With Quote
Old 05-21-2004, 12:19 AM   #10
Longshot
Member#: 2359
Yeah I had a COBB intake and Brullen exhaust on before I went to the Dyno.. I made more power than a stock RS before tuning, and then gained the 5hp and 10lb/ft beyond that.
I bet if I had more time to tune I could have eeked out more, and if I had any way to advance timing I could have gone further. The AFC is hella easy to tune, and I can give you my settings and dyno graphs if you'd like.
Korey
Old 05-21-2004, 07:21 AM   #11
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
Chris
also replace your giglin' pin.
thats good for an extra 15HP
iamrazor is offline   Reply With Quote
Old 05-21-2004, 07:54 AM   #12
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
I gained 6HP and 10 ft/lbs after a dyno tune with a 2.2 liter NA motor
I had an intake and exhaust though.
Bry.
BrysImpreza is offline   Reply With Quote
Old 05-21-2004, 07:58 AM   #13
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
I was messing around with my Greddy Emanage yesterday with airdlow in preparation for turbo. I can definitely say that the AFCish capabilities it had made a differance. Obviously to more mods you have screwing up your fuel curve, the more correcting it with the AFC will help. I think people with the more agressinve intakes would get the most out of it due to need for more fue. I have been actually removing a little fuel with mine for gains.
Todd
Hitokiri is offline   Reply With Quote
Old 05-21-2004, 08:05 AM   #14
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Todd
not to hijack, but did the obd scanner work for you?
Old 05-21-2004, 09:34 AM   #15
AngryBlueRS
Member#: 51678
05 STI
87 Rocco dirt beast
Cool feedback everyone, thanks!
I PMed Darshu on the unit he has for sale. Even if the gains are not over the top, it would be cool to have the unit just to be able to monitor intake pressure, mixture and the like.
As for mods, I'm running:
Injen CAI
Borla headers & CAT back
Random Tech CAT
One last question if I can be so bold. I have a Torque2 piggyback ECU in the car. Should I yank this before installing the S-AFC? Installing the chip didn't seem to boost HP or TQ but it did seem to make the engine rev quicker (lower 1/4 ETs). I would like to keep it if I can but don't want to screw up the AFC.
Thanks!
Chris
Old 05-21-2004, 10:07 AM   #16
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
You should be ok, the only thing the S-AFC does is modify your fuel map. Unless the ECU modifies the TPS or MAF / MAP (depending on MY) , you should be ok.
Bry.
Head Gasket Leak Problem on all NA 2.5? H5N1 Normally Aspirated Powertrain 621 03-23-2014 10:11 AM
WRX/STi axle back exhaust bolt on to NA 2.5? Kid Icarus Normally Aspirated Powertrain 10 09-04-2011 01:43 PM
apexi super afc on n/a 2.5 robsgotit Normally Aspirated Powertrain 59 10-17-2004 11:07 PM
apexi s-afc on 02 2.5 rs help! robsgotit Engine Management & Tuning 10 10-14-2004 11:39 AM
Blown head gasket(s) on a 63K NA 2.5? Andrew Bacon Normally Aspirated Powertrain 20 02-26-2004 03:24 PM
