Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 05-20-2004, 02:37 PM   #1
ScoobyMods.com
Vendor Sales Rating: (6)
Member#: 23928
1996 STi 555 RHD
Default JDM Power Goodies
Just got out japan shipment in, got some really neat stuff that I'm sure will move fast.
1. One (1) USDM STi intake manifold, complete with fuel rails, wiring, injectors, DBW ThrottleBody, Turbo Inlet. Price has not been determined yet.
2. One (1) USDM STi crate motor (2.5L). Brand new motor, with less then 10km on it. Comes complete as EJ257 USDM STi Long Block w/AVCS Heads, Drive By Wire Throttle Body, Tumble Generator Valves, Fuel Rails & STI Yellow Top Injectors, Intake Manifold, Turbo Inlet, Turbo Oil Drain & Feed, Ignition Coils and Spark Plugs, Alternator & AC Compressor, Oil Pump & Pan, and Headers. $5500 + shipping
3. One (1) STi Version 8 RA crate motor (2.0L). Brand new motor, with less then 10km on it. Comes complete as EJ207 JDM STi Long Block w/AVCS Heads, Throttle Body (Cable Style) , Fuel Rails & STI Pink Injectors, Intake Manifold, Turbo Inlet, Turbo Oil Drain & Feed, Ignition Coils and Spark Plugs, Alternator & AC Compressor, Oil Pump & Pan, and Headers. $5000 + shipping
(note --> the 2nd picture is of the last one we got prior to this shipment installed into my GC8)
I should be adding more stuff to the list later today as we check in more inventory.
Kevin
Kastle's Korner
www.kastleskorner.com
[email protected]
623.825.4825
ScoobyMods.com is offline
Old 05-21-2004, 01:22 PM   #2
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Got a bunch of STi Intercoolers in (4 of them actually) minus the hoses. Will post pics later today.
Old 05-21-2004, 01:29 PM   #3
Maicca
Member#: 29143
2000 IMPreza
Camo
Are the intercoolers USDM or JDM?
Maicca is offline
Old 05-21-2004, 01:31 PM   #4
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
They are JDM. Direct bolt on. The only issue that I found was they don't come with the STi hoses. I was able to install one yesterday on a WRX (02) that had Samco hoses, but that required some extending of the Samco's...
Old 05-21-2004, 05:31 PM   #5
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Side note... The JDM STi Intercoolers are brand new, never been used. They just didn't come with the Y pipes.
Here is a good side by side pic w/ the WRX IC (used).
And another pic of it installed
Old 05-21-2004, 05:45 PM   #6
Berman
Member#: 17826
2002 WRX Sedan
Pearl Blue
Default STi manifold
How much is the STi intake manifold?
Berman is offline
Old 05-21-2004, 06:09 PM   #7
03WRXMA
Member Sales Rating: (7)
Member#: 35081
2012 WRX
Price?
03WRXMA is offline
Old 05-21-2004, 07:03 PM   #8
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Price on the IC's (without hoses) is $400 shipped anywhere in the continental US.
Price on the Intake Manifold w/ injectors (etc) is $400 + shipping.
Old 05-21-2004, 08:23 PM   #9
Hotrodguru
Member Sales Rating: (8)
Member#: 37210
2002 Tarmac Bugeye
2012 Hyundai Veloster
How many IC do you have and could you get the hoses???
Thanx, Guru
Hotrodguru is offline
Old 05-21-2004, 08:28 PM   #10
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Thanx, Guru
I have 4 of the IC's left (of the 5 that I got). I have been searching high and low, but can not source the hoses.
My personal recommendation is to re-use the WRX cast pieces (are held on with 2 12mm bolts) and aftermarket (like Perrin or Samco) hoses.
The fix to extend them requires cutting the IC hoses and extending it using a piece of metal (either steel or aluminum) that is 3.5" long with a diameter of 2" and some hose clamps. This is what I did on my wifes wagon.
I'll post some pics soon as the car is cool enough to work on...
Old 05-24-2004, 07:44 AM   #11
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Still got a bunch of goodies here...
Old 05-24-2004, 12:58 PM   #12
Leonardo
Consigliere
Super Moderator
Member Sales Rating: (3)
Member#: 185
2009 Civic EX
I have someone for ya for an STi IC!
Leonardo is offline
Old 05-26-2004, 06:36 PM   #13
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
bump
Old 05-26-2004, 06:44 PM   #14
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
Price on the Intake Manifold w/ injectors (etc) is $500 + shipping.
I was interested in an intercooler, but am getting an FP 20g or Green and will need a front mount. Now for this Intake Manifold, it's the red one right and are the injectors STi Pinks????
Thank You, Guru
Old 05-26-2004, 06:53 PM   #15
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
It comes with the STi yellows, as it's off a USDM STi (not a JDM which would have the pinks).
Old 05-26-2004, 07:10 PM   #16
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
Is this intake a DIRECT bolt on for an 02 WRX ej20? And I searched high and low for the flow rates of the STi yellows. Would you happen to know them?
Thanx, Guru
Old 05-26-2004, 07:25 PM   #17
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
IIRC, the STi Yellows are 545 or so. Ever so slightly less then the STi Pinks.
As for direct bolt on, yes it will. You will need to have some sort of engine management to control the injectors though. Same thing as if you installed a set of STi pinks. You'd need something to control the injectors.
Other then controlling the injectors, it's a direct replacement for the stock EJ20
Old 05-27-2004, 09:49 AM   #18
Maicca
Member#: 29143
2000 IMPreza
Camo
How much for shippinng on one of the JDM intercoolers to 20166?
Thanks!!
Maicca is offline
Old 05-27-2004, 12:06 PM   #19
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
USPS Priority Mail (2 - 3 days) will run $25 USD. We can go Parcel post (7 - 9 days) for 20.
Fedex ground would run about $15 and take between 4 - 5 days.
Old 05-27-2004, 04:26 PM   #20
lobsterhat
Member Sales Rating: (9)
Member#: 42599
16 Subaru STI LTD
Other than pretty red paint, what is the difference between the STI Intake Manifold and a stock WRX manifold?
lobsterhat is offline
Old 05-27-2004, 04:44 PM   #21
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
The injectors are STi yellows (vs. stock WRX), the intake manifold on the STi is ported more (IIRC) and the STi throttlebody is drive by wire (which can be swapped for the WRX throttlebody).
-Kevin
Old 05-31-2004, 03:16 AM   #22
thesmokingman
Member Sales Rating: (5)
Member#: 17751
2002 WRX Wagon
944 Turbo track
Hey Kevin, can ya hit me up with a proce on the manifold, thanks.
thesmokingman is offline
Old 05-31-2004, 12:44 PM   #23
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
PM'd you.
Old 05-31-2004, 03:15 PM   #24
1984
Member Sales Rating: (4)
Member#: 16461
WRB w/paintchip flake
From what version STi are the IC's from? They have a dip in the top of the intercooler that I have not seen on other STi ICs.
Reference Pic:
1984 is offline
Old 06-01-2004, 06:00 PM   #25
randyspeed
Member#: 62609
2005 EVO 8 GSR 2005
Im interested in the IC let me know Im the guy Leo told you about
Randy
My zip code is 00926 I live in PR you ship here? If so send me a PM with the price quote for the IC, thanks.
randyspeed is offline
Closed Thread
P&L Motorsports, built shortblocks, rotated turbo kits, and other power goodies! P&L Motorsports Inc. Engine/Power/Exhaust 19 04-21-2009 08:35 PM
lots of power goodies 123mara Engine/Power/Exhaust 11 11-26-2008 11:29 AM
97 OBS power goodies with timing belt work? darkwaterz Built Motor Discussion 0 04-26-2008 02:49 PM
Lot's of Power Goodies in stock...Helix, K&N Typhoon, STi and more :) Z1 Performance Tri-State Area Vendor Classifieds 0 01-18-2005 08:55 AM
