Old 05-21-2004, 12:46 AM   #1
wickedscooby
Member#: 55963
99rs sti v5 LISC #57
Default turbo kit = CEL?
if i put in a turbo kit into my rs would i throw a CEL and have trouble with emmisions
wickedscooby is offline   Reply With Quote
Old 05-21-2004, 01:09 AM   #2
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
I'm going to keep it short. Yes.
NeaD is offline   Reply With Quote
Old 05-21-2004, 01:22 AM   #3
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
If you're worried about CELs popping up, you need to keep the turbo kit out because that is the last of your worries.
benjaminetanyahoo is offline   Reply With Quote
Old 05-21-2004, 01:41 AM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Ding, we have the winner!
kastle is offline   Reply With Quote
Old 05-21-2004, 01:50 AM   #5
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Hey stop post whoring Mod
I got to regulate on a Mod... Oh Yeah!!!!
I'm joking so don't regulate on me please
Old 05-21-2004, 06:03 PM   #6
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
the only cels ive had so far are:
0420
0301
0302
0303
0304
and the one for the o2 sensor, not too bad id say and as of rite now theres no cel.
Derk1127 is offline   Reply With Quote
Old 05-21-2004, 08:39 PM   #7
wickedscooby
Member#: 55963
ok cool, im not worried about the CEL poping up im just worried about having it inspected in NY. but if i need too i can make a cheater pipe and put a second cat on it.
Old 05-21-2004, 11:56 PM   #8
Unsung Boxer
Member#: 37196
OBD2 cars can't pass emissions w/ a CEL present.
A "turbo kit" should not throw any CEL's. This is what make's it a kit. They have had all the bugs worked out of them which should make them bolt on directly, and simulate/satisfy OBD sensors.
Just throwing a turbo on your car WILL throw CEL's. MAP sensor will go out of range, injectors will go out of range, O2 sensor will read to lean, etc... There are fixes to all these things.
I am running OBD2 98 Impreza L with a Pieced together turbo setup. I worked through all the sensors, either with boost nanny, fuel managment, etc so that I have no CEL's. I passed emissions a couple months ago. This MAF based OBD2 is most likely the hardest car to turbocharge, and ive done it, so anyone can.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 05-22-2004, 06:49 PM   #9
wickedscooby
Member#: 55963
thanx jake, you definitly helped me out
Old 05-22-2004, 07:00 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
So, what happens if they plug into your OBD-II port and start reading the datalog?
Old 05-22-2004, 08:41 PM   #11
Unsung Boxer
Member#: 37196
its called Datastream, and its not what your imagining. Its not like the ECU knows that it has a Turbo hooked up to it.
The data simply shows what the inputs to the sensors are. If a MAP sensor is supposed to read 0-5v, then its gonna know that Atmospheric pressure is somewhere around 4.7v. SO... if you throw a turbo on there, its gonna excceed 4.7v and throw a CEL. Since state law says you can't pass emissions with a CEL, you now FAIL.
How do you fix this particular problem? the Boost nanny (a series of checkvalves) will keep the MAP sensor from seeing higher than Atmoshperic pressure, thus the MAP sensor doesnt go out of range, and the ECU is happy... no CEL, pass emissions.
-Jake
Old 05-24-2004, 07:29 PM   #12
wickedscooby
Member#: 55963
where could i get those boost nanny (check valves)
New turbo kit = CEL 06mattsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 12-25-2008 03:01 PM
Ft: So Cal: Gt35r .82 Ar Turbo Kit For Stock Location Turbo Kit EvO KiLLeR 2005 Engine/Power/Exhaust 4 06-02-2008 01:21 PM
GT35R Turbo kits CEL after install Caballero_STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 12-28-2006 10:30 PM
AVO Turbo Kit vs TSI Turbo Kit Mechkiller31st Normally Aspirated with bolt-on Forced Induction Powertrain 6 12-01-2004 07:02 PM
Wanted: Turbo Kits or Turbo Kit Parts Acejam2k Private 'Wanted' Classifieds 1 01-05-2004 01:34 PM
