Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Vancouver Impreza Club
Old 05-21-2004, 12:57 AM   #1
Alfa
Member#: 10178
2012 Forester
Ice Silver
Default CEL problem: Subaru orders new me ECU
I received a CEL a couple of days ago, not knowing what was the cause
because my car has and is still running fine. I took it to the dealer.
Diagnose was a faulty ECU, they said they will order a new one, with modifications to it. Thats all they said. Nothing about my mods.
I've been reading threads on a faulty 02 sensor.
"Check engine light, caused by map sensor failor/problems
- Subaru has defective map sensors in general."
I'm not sure if that is my problem.
Anyone here have this problem here with there CEL.
Do you think they will blame my mods when the ECU arrives and gets installed.
(Also without telling me they changed the cruise control clips/recall!
Everything was under warranty.)
Alfa
WRX sedan 2002
PDE Upipe
STI intercooler
intake
Alfa is offline   Reply With Quote
Old 05-21-2004, 02:26 AM   #2
Tricky
Tu ne cede malis sed contra audentior ito
Member#: 28960
2002 Stock WRX Wagon
MBP with door dings
I had the same thing too. Replaced my ECU. When I saw your post i thought "that's gotta be another 02".
Who's the dealership? DD? I had no probs with them so far, Andrea is very cool. (My CEL was a MISFIRE.) Apparently a known problem with the MY02s...
Tricky is offline   Reply With Quote
Old 05-21-2004, 02:52 AM   #3
aawen
Member#: 27167
2015 FXT
so i'm still da 2 ecu replaced recorder
aawen is offline   Reply With Quote
Old 05-21-2004, 03:48 AM   #4
Happy_Days
Member#: 35049
2011 Mercedes C63
OE Tune 538/500
Default Re: CEL problem: Subaru orders new me ECU
Alfa
WRX sedan 2002
PDE Upipe
STI intercooler
intake
I'm surprised your untuned intake hasn't blown up your engine yet.
Do you have a boost guage?
Happy_Days is offline   Reply With Quote
Old 05-21-2004, 02:17 PM   #5
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
My car just threw a CEL last night.
AllWheelDrift is offline   Reply With Quote
Old 05-21-2004, 02:51 PM   #6
Happy_Days
Member#: 35049
2011 Mercedes C63
OE Tune 538/500
sorry to hear that bro ... get the codes pulled quick!
Old 05-21-2004, 04:26 PM   #7
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
I hope to borrow and OBD2 cable tonight and pull them myself.
Old 05-21-2004, 04:58 PM   #8
scoobysport
Member#: 1671
'02 '13 WRX
I had my ECU replaced less than 6 monthe after buying my car (March 2001). I was getting a faulty vent control solonoid CEL code. No problems since.
Brian
scoobysport is offline   Reply With Quote
Old 05-21-2004, 06:23 PM   #9
tony_subaru
Member#: 22742
Whats wrong with having an intake? It shouldn't kill the motor heh
tony_subaru is offline   Reply With Quote
Old 05-21-2004, 06:37 PM   #10
Happy_Days
Member#: 35049
2011 Mercedes C63
OE Tune 538/500
read his car model
Old 05-22-2004, 01:36 AM   #11
Alfa
Member#: 10178
2012 Forester
Ice Silver
Default Intake
Hey Happy Days,
I haven't heard anything about intakes causing problems or damage.
Plus I do have a boost guage. Tell us!
I'm glad to hear I'm not alone.
Alfa
Old 05-22-2004, 02:17 AM   #12
Happy_Days
Member#: 35049
2011 Mercedes C63
OE Tune 538/500
Default Re: Intake
Hey Happy Days,
Alfa
Not to personally pick on you, I would have gotten an intake if I knew it did something benficial to the car.
As of what I've researched there are only 2 short ram intakes that match the STOCK intake diameter and allows the stock MAF sensor to read correctly.
For ones that don't match stock diameter... you end up giving false MAF readings to the sensor.. and the car doesnt know when to give more gas... or more air.
Do a search.. I've found pages and pages of stuff regarding this, and they will definately explain it a lot better than I will.
Even the ones that match the stock diameter, I've read that if you aren't going big power (350bhp+) you will never need an intake for the WRX (STI is another story). And it's just more of a sound mod than anything else.
Old 05-22-2004, 02:56 AM   #13
SubaruBen
Member#: 20948
04 STi
Snow Plower
also to add to what happy_days has found..
You could also buy a filter replacement that replaces the stockbox but still retains the stock intake pipe (cause of it's DIAMETER) all the way through to the stock turbo inlet.
Again, it's more of a sound mod.
This is just a company's opinion but it's a good read:
http://www.cobbtuning.com/tech/airflow/index.html
Edit:
Also wondering if you're running a bit under stock boost because of using the STI intercooler without a larger turbo or proper ECU re-tuning.
SubaruBen is offline   Reply With Quote
Old 05-22-2004, 12:01 PM   #14
tony_subaru
Member#: 22742
No ecu reflashes allow you to use an intake. But, if you don't get your ecu reflashed....an intake isn't going to blow up your motor. Just think about it.....more air into a motor isn't going to blow it up. It might not give your ecu the correct readings, but it's still gonna give you the cool noise and a bit of power if your lucky.
Old 05-22-2004, 12:51 PM   #15
Happy_Days
Member#: 35049
2011 Mercedes C63
OE Tune 538/500
haha... again, you're talking about NA cars. If you're interested in finding out more, do a search on CAI or short rams. I don't want this to turn into a debate.
and Yes, there are custom flashes that companies offer for aftermarket intakes, but usually they will note that you need your stock intake for their off-the-shelf flashes.
If you don't want to bother reading the Cobb link Subaruben has posted up, simply go to the 2.0 litre forum and make a new thread saying "Which Intake Should I Get?" .. and you will be given tons of links saying why you shouldn't or you'll just be flammed.
Old 05-22-2004, 01:05 PM   #16
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
More air without more fuel = lean
You're not going to try and tell me that running lean isn't bad for an engine, are you?
Old 05-22-2004, 11:51 PM   #17
tony_subaru
Member#: 22742
Well in town there are about 12 cars that I can count that have had over 50,000 km on them that have an aftermarket intake....I know it should lean out things and isn't the best...but their motors are running perfectly fine. Any reason why?
Old 05-23-2004, 12:29 AM   #18
Happy_Days
Member#: 35049
2011 Mercedes C63
OE Tune 538/500
Are they turbo-charged 2002 - 2004 Subaru Impreza WRX's? (not STI)
Old 05-23-2004, 01:27 PM   #19
tony_subaru
Member#: 22742
yah most of them are 02 wrx's. There about 3 03 wrx's, and theres one 04 wrx and one 04 sti. Otherwise the other 7-8 are 02's.
Old 05-23-2004, 01:36 PM   #20
Happy_Days
Member#: 35049
2011 Mercedes C63
OE Tune 538/500
Well if they just replaced the stock snorkel piece and put in a cone filter or something (which still uses the stock MAF housing) they will be fine, with extra noise.
Common aftermarket CAI's or Short-rams that replace the MAF housing with a greater diameter will cause you to run lean, and will eventually lead to engine damage.
So you won't actually know if they have the complete intake or just the cone unless you ask or look at it.
Old 05-23-2004, 11:40 PM   #21
tony_subaru
Member#: 22742
No their complete intakes. The majority of them are AEM CAI or Short rams.
Old 05-31-2004, 02:54 PM   #22
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Took my car in today and it was the front O2 sensor (I already knew as I'd pulled the code.) Anyhow, they just called me and told me it was the oygen sensor and that the replaced it under warranty.
Old 06-14-2004, 05:19 PM   #23
spyd3rr
Member#: 59019
2004 WRX STi
which intake are you using?
and Happy_days, which two intakes are you talking about that match the stock diameter?
spyd3rr is offline   Reply With Quote
Old 06-14-2004, 06:22 PM   #24
Kevin
Member#: 1082
2014 Fiesta ST
Orange of course
.... because they just doddle around town and never go WOT for more than 14 seconds at a time?
Kevin is offline   Reply With Quote
Old 06-14-2004, 07:21 PM   #25
Happy_Days
Member#: 35049
2011 Mercedes C63
OE Tune 538/500
This is an over debated topic. By simply typing CAI or anything to have to do with intakes into *search*, people can read about its potential damages.
I believe it's Perrin and TXS's intake that retain stock diameter. But those are shortrams... which = hot air intake.
Pre-Order NEW NEW NEW Flat Black Advan RS-D!! SpeedElement Wheels/Tires 3 12-04-2009 02:08 PM
help me get back in touch with my inner subaru - whats new for the STI in 2007 jmott Texas Impreza Club Forum -- TXIC 34 06-09-2006 05:05 PM
ATTN OT music snobs & art ****: doing a mail order, reccomend me some new music doubledribble Off-Topic 45 09-08-2005 06:33 PM
Announcing a New Community for Subaru Do-It-Yourself ECU Tuners wackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 10-05-2002 04:33 AM
