Old 06-06-2010, 06:03 PM   #226
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
You can put 02 struts on an 03. The strut and rear tophat design did not change until 04. You can only use STi V7 springs and struts (i.e. JDM). Though you may be able to still source these new from the dealer. They were offered as an upgrade back in the day. The 04 STi stuff will not fit without modification, as outline above.
Arnie is offline   Reply With Quote
Old 06-10-2010, 07:54 PM   #227
Rexxin
Member#: 144693
'03 Swap'd Wrx
'95 drift e36
ok i am a little confused too ... this thread has been helpful but ... i would like to confirm ... cause im hearing a little different from other ppl...
I have 06' lowering springs i'd like to put on my 03' sedan ... aside from changing out the rear top hats for 04+ .. do i also need this spacer cause im using my stock struts .... any insight to this is greatly appreciated ...
Rexxin is offline   Reply With Quote
Old 06-10-2010, 08:02 PM   #228
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Yes, you will need these spacers if you are planning on using those springs on your stock struts. However, if you are going to go to the effort of swapping springs, i would suggest getting new struts as you 03 struts are most likely on their way out. DSpecs or AGX's or, better yet, 04+ koni inserts and you won't need the spacer! jUst the rear tophats.
Old 06-01-2011, 10:01 PM   #229
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Bump cause I need to use some of this info...
Seraphinwolf is offline   Reply With Quote
Old 06-01-2011, 10:39 PM   #230
nhat
Member#: 140163
03 STi
hellaflunctional
some of what info exactly?
Old 06-03-2011, 06:14 AM   #231
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Old 02-21-2012, 12:23 PM   #232
Weird Nev
Member#: 311021
2005 WRX PPP Wagon
hi guys!
Sorry to dig up this tread and drag out the corpse, but the information here is the closest I've come to sorting a problem I have.
Car is a UK spec 2005 built (5 in the VIN!) WRX wagon.
The rear struts are knocking, so I looked at getting KYB's. however, the parts supplier were very dilligent and spent a long time checking for me, and it turns out that KYB does NOT make rear struts compatible with my car!
So that lead me on a wild googling spree, which brought me here..
however, my struts don't even look like the ones posted in the very helpful ID picture!
This is what mine look like:
And here's the top mount:
they're creacking and clunking.... So, what I'd like confirmation of is this:
Can I build the equivalent of a 2002/2003 strut, with KYB bottom end, 2003 top hat, and a compatible spring, and bolt that in to have a working replacement?! Many thanks guys!
Weird Nev is offline   Reply With Quote
Old 11-20-2012, 12:09 PM   #233
The Duke
Member#: 264877
So all that's needed to run Version 7 struts on an 04 STi are the proper version 7 springs/tophats?
The Duke is offline   Reply With Quote
Old 11-21-2012, 03:19 PM   #234
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
You could do that but that is an expensive solution. If you want to run 02-03 Impreza Struts with 04+ Impreza Top Hats and Springs. All you need to get is these Scooby921Strut Spacers from Turn In Concepts.
http://turninconcepts.com/product_in...roducts_id=234
kayen is offline   Reply With Quote
Old 11-02-2015, 04:30 PM   #235
Dan4451
Member#: 377694
2002 wrx sedan
I'd make my own thread for this question but I don't have 3 legitimate posts yet to make my own thread. Long time reader only second time posting. Ive been finagleing with this for a month now. Trying 2004 group n mounts that dont fit the springs. Now I have 2002 group n mounts coming in but i dont think that they will make any difference from the 2002 wrx stock mounts? can anyone confirm?
the current setup:
-stock wrx strut mounts
-2002 wrx KYB struts
-2002 JDM sti v7 springs (I think)... bought off ebay, were actually labled as 2004 springs so i bought scooby 921 spacers and 2004 sti group n mounts but the mounts are not for this spring. the 2004 mount is too small for the spring. the springs do not curl inward toward the top and retain the same radius around the entire spring. They flatten out on the top instead of maintaining that rounded shape. They look exactly like the springs in this nasioc link.
http://forums.nasioc.com/forums/show....php?t=2175303
and here
http://i255.photobucket.com/albums/h...451/images.jpg
I have a saggy butt now... very low and when I was putting the springs in I noticed that they were not as tight compared to the stock springs.
If anyone has advice who has done this swap before your saving me from massive headache
Dan4451 is offline   Reply With Quote
Old 01-10-2016, 08:52 PM   #236
Cmurray902
Member#: 432345
2000 JDM WRX STI
Maybe I missed it but it seems this thread is mostly about fitting 04+ springs/tops to 02-03 struts. What about vice versa? Can I put V8 sti struts/springs/tops on my 2000 Bugeye STI and if not what needs to be modified to fit?
Cmurray902 is offline   Reply With Quote
03 GR2 with 05 sti prodrive spring with 04 top hat qualityracer Brakes, Steering & Suspension 2 05-20-2009 08:50 AM
WTB: 02/03 WRX Engine or compatible with same Balantz Private 'Wanted' Classifieds 0 09-26-2007 09:40 PM
FS IL: 02/03 WRX struts, V7 STI springs awgrimm Suspension/Brakes/Handling 6 09-10-2006 10:34 AM
FS IL: 02/03 WRX struts, V7 STI springs & more awgrimm MWSOC Private Classifieds 3 09-10-2006 10:33 AM
Why is it that 02/03 rear swaybars aren't compatible with 04+ Imprezas? mr_yellow Brakes, Steering & Suspension 10 03-30-2004 05:32 PM
